Question about Huawei Cell Phones
Huawei G8 P8 Lite the network signal is dropping out calls missed & problems making them,
Phone set to LTE auto my network provided checked settings & confirms the phone is compatible to the network & sim is in the correct slot. I have no problems with my old 3g phone in same area
  • 42 Answers
SOURCE: video call at nokia E71
this fasility is not avalable in india
Posted on Apr 04, 2009
  • 193 Answers
SOURCE: i9/168 + sci phone vodafone & vigin work on sim1 slot only ?
Make sure the sim cards are inseted properly, SIM 2 wich is the bottom slot the gold chip has to fase up, (yoe see it when you insert it) sim 1 wich is the top, the gold chip faces away from you, so basically with both sims in the chips face each other. also make sure both sim slots are turned on in your phone settings.Settings => Dual SIM settings => Choose the proper SIM setup => OK in this case you would select Dual SIM open then OK.
For full help topics I have a cd available for 10 us dollars. Has 100's of mp3 ring tones wallpapers, and java games and opera java browser. Guaranteed help on every question ever asked on these phones. And all settings for all cellular services. I have answered 100 questions with this CD. If interested contact prestorose@aol.com Pay Pal only, will send out First CLASS Mail in padded envelope. If interested I will send Pay-Pal invoice that can be filled out and returned with instructions. Guaranteed safe transaction.
Posted on May 04, 2009
SOURCE: My cellphone can read my 3g sim card but I get no signal from SP.
Hello
I have to inform you that China sells alot of "unlocked" phones some of them are legit some are not.There are alot of conterfeit phones coming out of China you have to be careful. It's clear that the sim card is fine if you used it previously in another AT&T phone.
The problem is the phone itself, either A. it is not unlocked as it was advertised to be or B. the phone is bunk period....can you post the website you purchased this from ?
There is not much we can do from this site, AT&T was your best bet. Typically they will not deal with "unlocked" phones did you mention to them that you purchased it from China ?
Post back with the link to the site or any other questions you have for further assistance. Thank you for choosing Fixya!
Posted on Jul 09, 2009
  • 74 Answers
SOURCE: bad signal i9 3g
maybe your phone signal probleam so better u add your phone signal boost up strip u can buy it and if u put it inside your mobile signal will be ok
good luck
Posted on Jul 14, 2009
SOURCE: iPhone 3g Dropped Calls
I've got the solution! Join our petition to have AT&T reimburse us for all their dropped calls!
http://www.lessbarsinmoreplaces.com
Posted on Nov 13, 2009
Help me pls unlock my huawei p8 lite pls
I suggest you can approach Unlocking4u.com and specify the country,locked network of Huawei P8 Lite .Based on the availability you can get the permanent unlock service along with free instructions.
Feb 09, 2018 | Huawei Cell Phones
Hello is there a way I can change the network setting on my LG phone LGL63blight now it's set to Lte and I can be next to my WIFI and I can only get 2 bars
The LTE indicates the phone network signal strength and not the Wifi signal strength. Go to your wifi setup and connect screen to see the Wifi signal strength.
You can try changing your connection to 4G and seeif you get a better connection in your area
Settings ->> Mobile Networks
Sep 26, 2017 | LG Cell Phones
I dont know how to do any of this i have a new huawei vision 3 lte model:G620-A2 and i need to unlock it so i can use my sim
To unblock your SIM card, you will need to use something called a PUK(Personal Unblocking Key). The phone provider can supply this.
Phones are often locked to a particular network as the network operator subsidises the cost of the device in exchange for network loyalty.
Jul 23, 2016 | Huawei Cell Phones
How can I turn off the busy signal on my phone?
Check your iPhone settings
  1. Turn airplane mode on and off. Tap Settings > Enable Airplane Mode, wait five seconds, then turn airplane mode off.
  2. Check your Do Not Disturb settings. Tap Settings > Do Not Disturb.
  3. Check for any blocked phone numbers. Tap Settings > Phone > Blocked.
  4. See if Call Forwarding is turned on. Tap Settings > Phone > Call Forwarding.
Update your software
  1. Check for a carrier settings update.
  2. Check for an iOS software update. Some updates might require a Wi-Fi connection.
Remove and reinsert your SIM card If your iPhone has a SIM card, remove the SIM card, then reinsert it. Update your Preferred Roaming List (PRL) The PRL determines the cellular towers that your iPhone uses for cell service and selects those with the best signal strength.
  • If you're on the Verizon network, dial *228 and select option 2.
  • If you're on the Sprint network, dial ##873283#.
Contact your carrier When you contact your carrier, check the following:
  • Your account is set up to use your iPhone.
  • There aren't any localized service outages.
  • Your account doesn't have a billing-related block.
  • Your calls don't have errors on the carrier system.
Check your network settings
  1. Reset your network settings. Tap Settings > General > Reset > Reset Network Settings. This will erase all current saved settings, including Wi-Fi passwords, preferred networks, and VPN settings.
  2. Try to make or receive calls in another location.
  3. Switch to a different network band. Tap Settings > Cellular and turn off Enable LTE, 4G, or 3G (this option will depend on your carrier and device model).
Still can't make or receive calls? If you still can't make or receive calls, restore your iPhone as new.If restoring doesn't fix the issue, contact Apple Support or take your iPhone to an Apple Retail Store or Authorized Service Provider.
Mar 14, 2016 | Panasonic Lands Phones
My phone doesn't have network.can't make or receive call.and I can't email or receive sms's
Check WiFi setup. If looks ok, you should contact Customer Service of your mobil's service provider.
Apr 23, 2015 | Huawei Cell Phones
Huawei B890 won't connect to cell networks
reset all settings to default. or try master reset? it helped me.
Dec 10, 2013 | Computers & Internet
I HAVE THE HUAWEI ASCEND TOUCHSCREEN PHONE FROM METRO PCS. I CAN'T GET A SIGNAL WHEN INSIDE MY APARTMENT IN TAMARAC FL. I HAVE TO GO OUTSIDE TO MAKE CALLS OR SEND TXT. OTHER FAMILY MEMBER HAVE MET
I think this is a network operator signal strength, try with other service provider network.mean try to change simcard of other company.
Jun 28, 2012 | Huawei Ascend
Cell Phones Logo
55 people viewed this question
Top Huawei Cell Phones Experts
Aaron Galvan
Level 1 Expert
Phillip Whisenant
Phillip Whisenant
Kenneth Walker
Are you a Huawei Cell Phone Expert? Answer questions, earn points and help others
