Question about SkyGolf SkyCaddie Handheld GPS Unit
SG5 won't sync
Recognizes the SG5 but then stalls and redirects to the software download page
How do I install HTC Sync on my computer
You can download HTC Sync for Brew MP from the HTC support page. The HTC Sync software can be installed on a computer running Windows 7, Windows Vista, or Windows XP.
  1. On your computer, go to www.htc.com.
  2. Click Support.
  3. Select your phone model.
    Available phone software updates and the HTC Sync version compatible with your phone are displayed under Downloads.
  4. Click the Download link for HTC Sync for Brew MP, and then follow the steps on the subsequent page to begin downloading the HTC Sync software.
  5. After download is complete, double-click the HTC Sync installer, and then follow the installation wizard to install HTC Sync on your computer.
Visit the HTC support page from time to time to check for the most recent HTC Sync upgrade that you can download and install on your computer.
Feb 20, 2013 | HTC Cell Phones
What is procedure to delete courses from the hand held devise? i have the SG4 Model. Thanks
Hello.
GPS receiver units are designed to translate signalsreceived from a satellite into recognizable graphic information using mappingsoftware. These systems are dependent on the installed software, butlike all computers they can experience problems up to and including unexpecteddeletion of the software. Because of this, many GPS systems have providedsolutions to some of the most common problems.
Operating System Deletion
If the hand-held unit does not display any functionality when activated,first try restarting the system. If the unit is a hand-held GPS, try removingand then re-inserting the batteries to reset the system. If the system still displaysno operating system, contact a professional for service. GPS software can alsobe bundled or purchased as part of a more comprehensive device, such as aniPhone or other smart phone. In this instance, it is possible that the softwarewas deleted from the system during a sync with a computer. Try re-syncing thedevice with the computer and ensuring that the GPS application has beenselected to be loaded onto the unit. If this does not solve the problem, thesoftware may be corrupt. Delete the program from the computer and download itonce again to the hard drive. Then, re-sync the newly downloaded application toyour device.Update Deletion
Occasionally, an error in the download or an error insyncing with a GPS hand-held can cause updates such as operating systemadvances, bug fixes and new map information to be deleted or corrupted. If thisshould happen, re-download the update information and sync it with the GPSunit. If update information comes in the form of an SD or other data card, thecard itself may be corrupted. Contact Thanks.
Sep 21, 2011 | SkyGolf SkyCaddie SG5 Car GPS Receiver
How do I download golf courses to my sg5.
To download courses:
  1. Launch CaddieSync and sync your SkyCaddie.
  2. Select COURSES from the upper navigation bar of the CaddieSync desktop.
  3. Select the Favorites link next to Course Search.
  4. Check the box at the left of each course you want to download to your SkyCaddie.
  5. If you want to remove a downloaded course, uncheck the course in this step.
  6. Click the Download to My SkyCaddie >> button above the Favorites list.
  7. Checked courses will be downloaded to your SkyCaddie.
  8. Unchecked courses will be removed from your SkyCaddie.
  9. Click the Disconnect button in the lower navigation bar and close CaddieSync.
If you experience problems downloading courses:
  1. Turn off the SkyCaddie and disconnect the USB cable.
  2. Close the CaddieSync application.
  3. Reconnect the USB cable from the computer to your SkyCaddie.
  4. Launch CaddieSync.
  5. Click the Sync button in the lower navigation bar to resync the SkyCaddie.
Sep 01, 2011 | SkyGolf SkyCaddie SG5 Accessory Bundle Sky...
I've a movie in Avi format when i open it plays just for 16 seconds with "codec error: use windows media player Aborting video redirecting to microsoft codec download page" on the screen....
sounds funny anyway i know when i want to watch a movie thats all i want to do. dont want to be download any software or anything... anyway please download vlc player ( http://www.videolan.org/vlc/ ) this will play almost anything u throw at it...it just works period. it sounds like a virus but i would need some more info make sure ur antivirus software is up to date and please run windows update and also make sure all third party applications are up to date.
Jun 11, 2011 | Microsoft Windows Media Player
How to solve if my iphone 3G cannot be on, it stuck at the apple screen?
  • The quickest way to fix your iPhone 3G is to sync it to a different computer. When you do this the computer will recognize it as a new device and install the software on it like it's never been used before, that said everything you have on it is gone. It may take a while so be patient.
  • 2 If step one is successful you can sync it to your computer. It will recognize that it is synced with another computer and ask you if you want to sync it to this one; go ahead and do it. This may take a while too because you will install the applications, songs, data, etc. you had on it before.
    WARNING! DO NOT DISCONNECT YOUR IPHONE 3G WHILE SYNC IS IN PROGRESS OR ELSE YOU WILL BE STUCK IN RESTORE MODE AGAIN!
  • 3 If steps 1 and 2 did not work or you do not have another computer to sync it with the following steps will help.
  • 4 Backup your music, videos, and applications. Typically it would be the iTunes folder in the My Music folder. This is a precautionary step to the following steps to come, your music should be unaffected but stranger things have happened.
  • 5 Uninstall iTunes, Quicktime, and other Apple component software from your computer. Follow the steps listed on the Apple Support page, "Removing iTunes, QuickTime, and other software components for Windows XP" the link is available in the resources section. Restart your computer when done.
  • 6 To be sure everything is uninstalled completely run the Windows Installer CleanUp Utility. This program removes remnants of uninstalled programs from your registry and deletes files that the uninstall fail to catch. You can download and read more about this program from the Microsoft Help and Support Page, "Description of the Windows Installer CleanUp Utility" the link is available in the resources section. Restart your computer.
  • 7 If you have a registry cleanup utility like Registry Mechanic or CCleaner run the program and restart your computer. It is sad to say but the Windows Installer CleanUp Utility may not catch everything so having a secondary cleaner could be essential.
  • 8 Install the latest version of iTunes. Currently iTunes 8 is the latest, it could change tomorrow so download it from Apple.com. Restart your computer.
  • 9 Open iTunes and connect your iPhone 3G. It may take a while for it to recognize the phone, be patient. Once iTunes recognizes your phone it will prompt you to download the latest iPhone software, the current version is 2.1. Follow the installation instructions in the Apple iPhone - Software Update page, the link is available in the resources section.
  • 10 Hopefully these steps helped you recover your iPhone 3G. It is possible that even after a successful recovery your phone may revert back to being stuck. In my experience I was able to save my iPhone 3G from restore mode but when I downloaded the software update it got stuck again, luckily steps 1 and 2 fixed it.
  • Oct 06, 2010 | Apple iPhone 3G
    Upgraded to the SGX and now the Caddy Sync won't work.
    Had the same problem when i first tried to sync on 2 different OS (XP and 7) as soon as I put skygolf.com into my antivirus software as a trusted site, it worked like a charm. Hope this helps someone as this is a great gps.
    May 08, 2010 | SkyGolf SkyCaddie SGX GPS Receiver
    Lost power mid download
    I think there is a way to reset the unit by holding down one or more buttons while turning it on. This varies from brand to brand, read your manual.
    Feb 09, 2010 | SkyGolf SkyCaddie SG5 Car GPS Receiver
    Cant past personal info page of skycaddie sync.
    Well first of all try to reset your GPS receiver, just go into the main menu/settings and then select the reset option..... (note. resetting the GPS will erase all the data from your GPS and set all the settings to the factory default). after resetting the GPS again try to sync. it. please post some comment if further you have the same problem.....
    Good Luck!!
    Thanks
    Dec 14, 2009 | SkyGolf SkyCaddie SG5 Car GPS Receiver
    I reformatted the wd my passport hd. now my computer won't recognize it. I need the installation softare
    Here is the WD page, pick your Passport type, on the next page download the software you need:
    Select the software to download: http://support.wdc.com/product/download.asp?level1=2&lang=en
    If I could be of further assistance, let me know. If it answers your post, please be kind to rate it.
    Joe
    Mar 15, 2009 | Western Digital WD Passport 250GB Portable...
    SkyGolf SkyCaddie Handheld GPS Unit Logo
    305 people viewed this question
    Top SkyGolf GPS Experts
    Steve
    Steve
    Are you a SkyGolf GPS Expert? Answer questions, earn points and help others
