After storing for a season I pulled out oil heater n plugged it in...I turned on and heard crackling sounds n a funny smell...is that normal after being stored?
chispitas
  • 69 Answers
SOURCE: CAR CRANKS OVER BUT NO START I SMELL GAS UNDER HOOD
your pick up coil or parts inside the distributor have failed you may have to check and replace some parts or maybe your whole distributor. sorry.
Posted on Feb 26, 2009
  • 398 Answers
SOURCE: Yardbroom II pull start hard to pull
put a teaspoon of mix oil into the spark plug hole, some times the metal starts to bind in the engine. keep the wire off and the plug in and pull the cord a bunch of times until it starts to get easier, if you need to add more mix directly to the hole then do it. hope this helps
Posted on May 17, 2009
  • 13 Answers
SOURCE: driving home check engine light stated flashing truck lost power
Try checking the map sensor this is a common problem with these vehicles
Posted on Jun 25, 2009
john224
  • 1378 Answers
SOURCE: last season raypak 2100 heater would light but
Thank you for posting your question here on Fixya.com.
Along the manifold there will be several gas ports feeding gas into the burner tray tubes. The tubes are the narrow steel tubes that extend under the heater from the gas line. We use a piece of #12 solid wire and run it in and out of the tubes from under the manifold. Spiders like nesting in the tubes and their silk blocks the gas flow. Once the gas migrates over from further away from the pilot you get the 'whoosh' of ignition. As you clean the tubes and recheck the heater be sure you pay attention to the flame color. Anywhere you see orange flames above a tube you need to shut down and then clean the tube. Orange flame means poor combustion and needs to be fixed to prevent sooting.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Mar 10, 2010
SOURCE: Troybilt self-propelled mower - model 556 won't start
pipe from carb to engine broken. couldn't tell until covers & fuel tank removed. also part of deck holding engine came apart on mine. due to excessive vibration???
Posted on Mar 16, 2010
My delonghi oil heater is very noisy whilst hearing up
This is perfectly normal as the oil gets thicker the colder it is and over a period of time it's viscosity changes.Once the temperature gets above a certain point the oil will melt and the heat will flow through more freely so the popping/crackling stops.
Sep 23, 2014 | DeLonghi Heating & Cooling
Laptop making crackling noises
Lol. Any sparks flying and smoke and funny electrical fire smell? If not, have you played the volume at max and turned up the equalizer bass very high? Might be you popped one or both speakers. (I did that once so I have to only use one speaker or it sounds like crackling garbage). If that isn't it, might be motherboard's sound chip might be fried. You'll need to be a bit more specific in order for us to help you. <:0)
May 28, 2013 | Dell Studio Computers & Internet
Laptop makes crackling sounds
I have a blueflame probane heater ventless and when burning it has a slight smell. Is that normal for this ventless heater.
It depends on what it smells like. Initially, when the unit is installed it should be burned on HIGH for 45 minutes to an hour. Doings that, burns off all the oils and seasons the heater. Sort of like seasoning a cast iron skillet. After that, the newness odors should be gone. It's normal to get a whiff of gas when the burner lights or turns off. It should dissipate rather quickly.
Although Vent-free (ventless) heaters are very safe to use and are 99.5% efficient, their one drawback is that pick up strong household odors, like strong cleaning products, carpet shampoos, new paint or stain odors, strong cooking odors, etc and make them worse. That's why it's always best not to use the heater during or after painting, for at least 2 weeks. Although your nose may not detect the paint odor, the heater can and will make it worse. Also, always use your range's exhaust hood when cooking. Hopefully, it's the vented type and not one of do nothing recycling hoods.
Also, thoroughly cleaning the heater inside and out , at least once a season, will go along way in reducing odors and maintaining the longevity of your heater.
One other caution, do not burn scented candles and operate the heater at the same time. Scented candles soot anyway, but adding the warm moist, comfortable heat from the vent-free heater, will cause them to soot 50 times worse. Trust me, it's not the heater, it's the scented candles sooting.
Hope this helped explain some of the things that you asked about and more. If I can be of further help, please ask me through the Leave a Comment link.
Apr 22, 2011 | Procom MN300HGB Heater
My Lakewood oil-filled electric radiator makes some crackling noises when first heating - is this normal?
Yes, it is normal. the sound is from the oil heating up and moving through the fins. It will stop after a few minute. After the heater is used for a few months the noise will stop altogether. j
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE Comment is really appreciated for the FREE answering of your question.
Capt. Spock said: "An ancestor of mine maintained, that if you eliminate the impossible, whatever remains, however improbable, must be the truth."
Feb 22, 2011 | Lakewood Oil-Filled Electric Radiator...
Oil filled dimplex leaking oil and funny smell
oil smells funny when its hot you heater is porous needs to be replaced
Nov 29, 2010 | Dimplex OFC2000 Oil Filled Radiator Heater
Water temp is reading 180 while driving is that okay? is that normal
Hi.Yes,normal operating tenpeture for these vehicles is anythere between 180 an 205. At about 205 degree,the ECM turns on the coolant fans.The only time the coolant fans are on at all times is when the a/c is on.As far as the funny smell,it could be the heatercore starting to leak.If it smells like coolant,it will be the heater core.I suggest you take it to your local dealership.This repair will be covered under the factory warrenty.
Sep 28, 2008 | 2008 Pontiac G5
Delonghi "The Incredible Heat Machine"
blows the house fuse after being on a few minutes
Feb 13, 2008 | DeLonghi EW0507 Oil Filled Radiator Heater
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
