Question about Bosch Dishwashers
MY BOSCH SILENCEPLUS 14 PLACE SETTING DISHWASHER IS NOT RESPONDING TO COMMANDS. HOW DO I FIX THIS?
4 Suggested Answers
  • 228 Answers
SOURCE: I have a bosch dishwasher, SHU535E05UC/14. The
the spray arms are not rotating check they spin freely if they do remove them and clean any residue food deposits blocking holes for water spray.
Posted on Jan 19, 2010
Testimonial: "You gave me some information how to get my dishes clean, it was very helpful. I cleaned all the arms out, there were food particles stuck inside.Thks"
pdub57
  • 13 Answers
SOURCE: dishwasher not completely draining
Make sure the drain screen is not clogged at the bottom of the dishwasher or that you water drianline is not pinched or clogged behund the dish washer. if you are confidant in doing this you may be able to troubleshoot it. It possibly could be a water pump issue too.
Posted on May 16, 2010
foss52722
SOURCE: where to buy timer motor for my bosch dishwasher SMU2042UC/14
I have had success finding appliance parts on Amazon of eBay, especially if you have a part number or Model number.
Posted on Nov 03, 2013
Hii My dishwasher is working well until yesterday , I think the water pressure is not working well , it is Bosch silenceplus any help please
Turn off the water and remove the inlet hoses. There is a small stainless steel gauze filter that can get clogged with particles.
If that doesn't fix it, you may need a new water inlet valve.
Feb 19, 2018 | Bosch Dishwashers
Bosch silence plus showing fault E24. Have lost our manual . How do we fix this ?
Check the manual online:
https://www.manualslib.com/products/Bosch-Silenceplus-She45r55uc-3787557.html
Jul 01, 2017 | Bosch Dishwashers
SHY66C05UC/14 turns on but stops after 10-15 seconds, yet wash cycle button and time are still on. Replaced water flow part but no change. Suggestions?
Many Bosch dishwashers have a design flaw...the door will not fully close and pops out after you start it. When this happens the D/W will not run. You can go to the Bosch website to order the part to fix this and no they will not reimburse you nor acknowledge your email to customer service.
Sep 25, 2016 | Bosch Dishwashers
Bosch SilencePlus shows E:15, Aquastop, and Watertap!
Hi Greg,
E15 on the Bosch units indicated the base switch is activated. There is a safety switch which will activate the drain pump to avoid the base overflowing. Basically you either have a leak or possibly rodents living in the base of your dishwasher.
Easy way to check is first make sure no water is inside the washing area or sump (where the filter is). You will have a dribble there which the drain pump won't pump out but make sure it is mostly empty. The dishwasher always drains at the beginning of a cycle if you need to manually activate this, just turn you tap off so it doesn't try to fill. unplug your dishwasher then pull the machine out and place some old towels along the base and tip if forward. If water run out from the base then you got a leak.
If you are a bit handy then you can take either the front kick plate and cover off or a side panel to look in the base. The float switch is a polystyrene disc which raises and hits a micro switch when the base fills up.
Common place for these to leak is the sump, wash motor or water path / distribution unit. Look for chalky white residue around the seals. Depending on the age of your unit some parts are more serviceable than others. Bosch are pretty good with spare parts so you should be able to source most items you need.
If you are not handy or technical and are concerned about taking on this work, call in a technician. Remember disconnect power before attempting any work. please.
I hope this helps.
Apr 13, 2014 | Bosch Dishwashers
Where to buy timer motor for my bosch dishwasher SMU2042UC/14
Nov 03, 2013 | Bosch Dishwashers
Bosch silenceplus 50dBA won't start
After 3 seconds of reset (start), turn the dishwasher off, wait a few secconds, turn it on, and use the arrows to select the washing mode (try Auto, perhaps) and see if this solves your problem.
Apr 12, 2012 | Dishwashers
Jan 15, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Soap dispencer won' t dispence soap
My Bosch intergreted dishwasher is only 3 years old. For the past year, the dishwasher dispenser refuses to open on the second cycle. We have had the repair man here 3 times, and each time he says it's fixed,but it clearly is not. Does anyone know what to do about this??
Barbara Berger
Sep 30, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwasher won't let water in
this will help you more as has videos to help you find the problem https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/34-129--/Bosch-Dishwasher-won-t-fill. and here are some files that may help you as well http://www.appliancepartspros.com/parts-for-bosch-shu66c02-uc-14-fd-8211.html
Dec 23, 2017 | Dishwashers
Dishwashers Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
