Question about Singer Sewing Machines
Bobbin won't fall out of bobbin case for me to put thread on it. Singer tradition machine
  • Singer Master
  • 11,493 Answers
Are you lifting the lever on the bobbin case to release the bobbin?
If the bobbin is that tight in the bobbin case, it is possible the wrong bobbin has been used. Singer has several bobbins that are very similar in size and appear to be interchangeable but are not.
Posted on Dec 08, 2016
How do I fix it when the bobbin thread won't rise?
Make sure that your needle is ALL THE WAY up in the needle clamp and the flat side of the needle is away from you.towards the back.
Review the steps for inserting a bobbin in the bobbin case and raising the thread in your user's manual; if you don't have it, you can download it free at the Singer Sewing Machine site.
If you have done these things and you still can't get the thread to come up, then your timing has gone out of synchronization, and you will need to get a technician to reset it for you. If you cannot find a sewing machine technician willing to adjust a Singer, Sears supports all brands of sewing machine.
Jun 24, 2014 | Singer 2250 Tradition
Bobbin housing has come out, I cannot get it back together
Hi This machine uses the standard class 15 bobbin. It sits inside a bobbin case that has a finger that needs to be located in a retaining slot. It the whole lot, bobbin, case, hook assembly and retainer have come out simply turn the machine over so that these parts can be fitted downwards. fit the hook, then the retainer and lock it into position. Put bobbin into case pull thread under spring. Lift tab on case and put it over the hook's central pin and release tab. It should now be locked in position
Feb 17, 2014 | Singer 2250 Tradition
Singer 8280 (prelude) I had 2 threads coming out from my bobbin area, so I decided to open it up and take a look. I accidentally took out the whole bobbin shuttle. The manual doesn't tell me how to...
Ok, hang on! This can get tricky! Remove the bobbin. Remove the presser foot and the needle. Remove the throat plate. This gives you plenty of room to monkey with your bobbin case. NOW, lay the bobbin case in its correct area and gently rotate it until it falls into place. It may take several tries. Once you're satisfied that it's secure, snap the holding clips into place and it should all fit nicely. THEN place your bobbin in the case correctly...check the diagram in the manual. Depending on the machine, some bobbins have the threads coming off counterclockwise and others have them coming off clockwise, but your manual should show. Sometimes, there's even a diagram on the throat plate or the bobbin case as well.
Good luck. Hope this works. If this solves your problem, please come back and rate my answer!
Jun 07, 2011 | Singer 8280 Mechanical Sewing Machine
My machine is a singer 2259 tradition my machine is making knots, i can sew two points and then it s totally locked aqnd won t work any more because it's full of knots
Machine threaded incorrectly. Insufficient tension on upper thread. Bobbin case spring broken. Lint clogging thread path. Bobbin wound incorrectly.
Jun 05, 2011 | Sewing Machines
The bobbin on my machine isn't working properly; the top thread doesn't complete a full rotation and the thread keeps breaking. I can't get past a few stitches without creating a jam. I have tried taking...
have you taken the bobbin case out and cleaned it. Its a simple process if you look directly at where the bobbin goes in you will see two latches one on either side of the bobbin case, release those and clean this area and oil it, reassemble and then reload. bobbin thread could be old or if the bobbin was wound on a different machine the tension could be wrong for this machine. when reassembling bobbin case make sure that all parts are seated corectly, also sometimes the actual case that holds the bobbin may need to be replaced, if its an older machine it could be worn.
Oct 29, 2010 | Singer 2250 Tradition
The casing that the bobbin sits in is out how do I put it back in. The Bobbin holder below the tension feet is out and so is the bobbin how do I set it back in with out undoing the two latches on the side...
put the bobbin in its case then pull some thread out and pass it thru the bobbin case slot and under the tension spring .. put the bobbin and case over the shaft that is in the main unit .. the open side of the case goes in first .. make sure the bobbin doesnt fall out .. rotate the bobbin case until its finger lines up with the notch in the main case .. the bobbin case should latch in place on the shaft notch .. place the top thread under and to the back of the pressure foot then turn the machine one turn .. that will loop the top thread around the bottom (bobbin) thread ... now use a card or screwdriver to push both threads from under the pressure foot toward the back of the machine ..
Jun 21, 2010 | Singer 8280 Mechanical Sewing Machine
Thread jamming on the bottom of fabric
The tension must have gotten loose during use, try adjust the tension on the thread, and the bobbin casing.
Jul 29, 2009 | Singer 2250 Tradition
I have a singer cg 550 sewing machine and I am not sure which slot to put the bobbin thread in first
If you put the bobbin in the case with the thread coming off in a clockwise direction, the thread should just fall into a slot and gently tug on the thread and it will slide through the tensions. Lay it across the bobbin case and then pick up the thread with the needle.
Dec 20, 2008 | Singer 5050 Mechanical Sewing Machine
Sewing Machines Logo
204 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
