2 G service closed how to use my Nokia6301i to receive 3 G signal
    Top Expert:
  • Televison & ... Master
  • 48,356 Answers
Unfortunately there is no conversion fix for your phone as it is made to run 2g system
the solution is to buy a new phone that is 3g or better compatible
Posted on Dec 08, 2016
How to unlock sony dvp- sr320
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Unlock procedure and to override the password lock to many popular brand TVs are given.
Aug 10, 2015 | Sony Televison & Video
How do I connect Active speakers to my Denon 3805 AV receiver?
Your Genelec 1037C monitors are professional design with balanced inputs. Balanced inputs expect a low impedance signal with pin 1 earth, pin 2 hot and pin 3 cold. Because the Denon amplifier supplies a pre out for the front speakers (the first pair in the set of pre outs) at 1.2 volts and high impedance, you will need to convert the signal close to the amplifier with a stereo active DI box. Plug the pre out directly into the input of the DI with a SHORT lead and then plug two standard balanced microphone type cables ( XLR to XLR) into each of your active monitors. You cannot make a cable that is RCA to XLR by shorting pin 3 to earth to do this job properly. The inputs on your Genelecs expect a signal in the range -6dBU to +6dBU for rated output. A suitable DI box would be for example a Klark Teknik DN200. Hope that helps.
Cheers, Don.
Dec 06, 2014 | Denon AVR-3805 Receiver
Red light inside the freezer part stay on for my side by side Kenmore refrigerator
Hello William;
My name is Peter. I am a retired field service refrigeration technician.
The, 'Red' light is a infra red light. This light assembly on the right hand side of your freezer is the transmitter.
Directly across is the receiver. On the receiver is a spring loaded plastic flapper.
This is a safety device for your ice maker. When the freezer door is closed, the flapper is closed, allowing the infra red transmitter to complete the signal to the receiver. This allows the ice maker to discharge ice cubes. When the door is open the signal is broken, the flapper springs out blocking the circuit signal, and the ice maker will not discharge ice cubes.
There is a On/Off switch on the red transmitter. I do not know why you would want to turn it off. If you turn it off and the transmitter stays on then you have to replace both the transmitter and receiver.
Nov 11, 2014 | Kenmore Refrigerators
All ready used box once. Now going back to antenna. Not receiving display or menu on T.V. screen.
All TV over the air is transmitted as a digital signal now. In order to see it on an older TV (read Analog), you must have a signal that you can receive(antenna hook up) and a digital to analog converter box. That box allows you to see your digital signal on older TVs. The signal is sent from the antenna to the box via a RF connection, and decoded to channel 3 or 4 (your choice). for further information see Consumer Report at:
Jan 09, 2011 | Insignia Digital-to-Analog Converter for...
My RCA has a black block come up in the bottom of the screen? We have Dish Network Satellite and have programed the remote from the remote code guide. TV volume and channel changer work, but picture is a...
This has hopefully been resolved for you, but if not, here are some steps to go through. The black box that comes on the screen is usually signaling that closed Captioning is activated on the tv. Closed captioning does not run through the DISH Network receivers, so you can turn that feature off in your tv settings. The fuzzy picture could be a few things. You will want to check that all of your cables on the back of the receiver box and tv are tight as possible, and also make sure that the tv is on the correct channel. If you are in the room with the receiver, the tv will need to be on channel 3 or 4, and sometimes an input; usually video 1 or 2. If you are in a number two room, where there is no receiver, than you want to make sure that the tv is on channel 60 or 73. I hope that this helps!!!!!
Becki Barned
DISH Network Customer Service
Sep 11, 2010 | RCA F36650 36" TV
How to go wireless on laptop
You need three things
1) An Internet service provider. Once you sign up and agree to pay the fee they will provide the internet service.
2) A wireless router. This is a unit that receives your internet service by through a connection to your telephone line. Then it transmits a radio signal (wireless signal) that your laptop can receive.
3) A Wifi card in your laptop or an external USB Wifi Dongle. This is a radio or wireless receiver that picks up the signal from your router.
The router is usually security protected with a keycode. All you need to do is set up your Wifi card or dongle with the same keycode and you will be able to receive the internet wirelessly.
To check to see whether your laptop has a Wifi card already installed, do the following:
Click Start>Programs>Accessories>Communications>Network Connections> and look for "Wireless Network Connection." If you have this, then your computer has a Wifi card installed and ready to go.
Aug 27, 2010 | Computers & Internet
I have almost no signal and yet other phones on same network have full signal. Can I strenghten the signal?
First ensure that it is not a network related issue by using another sim card (if possible).
Try moving out to an open area for a better signal reception.
If your mobile still receives no signal, the radio transceiver might need to be replaced. If the phone is in warranty take it to the service center for free repairs. If the warranty has expired, you will have to pay for repairs.
I suggest you get a repair estimate and if it is close to a new handset, buy a new one.
Nov 30, 2009 | Samsung S8300 Ultra Touch platinium-red...
Weak or no signal
the actual tv was not on channel 3 and the av1 port was wrong
Jul 09, 2009 | Samsung SIR-T451 DirecTV DTV Receiver
Baby monoitor reciever piking up no sound or delayed sound - link light flashing
A delay may be caused by interference from other radio sources. I heard of one case where a woman's cell phone call overpowered the transmit power of her baby monitor.
Other things that can cause interference or other receiver problems:
1. monitor in contact or close proximity to running appliances or their cords. (induced electromagnetic field)
2. neighbor with baby monitor on same channel ('cross-talk')
3. distance between transmitter and receiver too far (the strength of a radio signal fall dramatically over larger distances. think of how often you lose cell phone coverage)
4. reduced power: low battery strength or cooked power supply
5. transmitter or receiver insulated from signal (if your monitor was transmitting/receiving through any metal obstruction)
May 07, 2009 | Kitchen Appliances - Others
Get closed captions on some channels, but not all, even though it is CC
RCA have choices for different methods of CC in user CC menu. Labelled T1, T2, etc. . Different selections are for different types of close caption. Tune to a signal (on your other TV) that has closed caption working.
Tune your RCA to the same signal. Change the T1,T2, etc settings until the closed caption for your signal appears.
If this doesn't work, try connecting analog video or VHF channel 3 (or other specified channel) to the TV. check CC. When TV stations, sat channels, sat receivers, cable boxes etc, convert analog video signals to HD, problems can result. Some equipment causes RCA TVs to do unexpected things with sound and closed caption.
If you use RF or video output, old analog video may look better on CH3 or video than on HD input and the CC will work more consistently. Watch HD signals on HD input, Analog signals on Video in or through the TV tuner . Many HD channels and programs are converted analog video and look poor on TV HD inputs.
Nov 03, 2008 | JVC AV-48WP30 48" Rear Projection...
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
