Question about Briggs & Stratton Garden
What is the power difference between classic 35 briggs & Stratton motor mower engine and B&G Quantum 50 ? Brian
tmandink
  • 30 Answers
SOURCE: What spark plug should be used for a Murray Quantum XNP 6.5hp mow
Home Depot has the plug you need for briggs 6.5hp engines. Don't worry about it being a Murray. Buy a Briggs 6.5hp plug.
Posted on Jun 26, 2009
  • 8 Answers
SOURCE: briggs a stratton 35 lawn mower
Turn the mixture screw on the carburator slowly counter clock wise till the idel stabalizes.
Posted on Jul 01, 2009
  • 110 Answers
SOURCE: where can i get a manual for a briggs and stratton
You can download a manual for the engine from Briggs & Stratton's web site - you just need the numbers off the blower shroud. No manual exists for the actual mower.
Posted on Sep 22, 2009
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Posted on Oct 25, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I can crank my murray gas lawn mower 6.5 quantum
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 15, 2010
Briggs & Stratton 35 Classic. How to fit the cable to drive the tines. Help!
briggs and stratton 35 classic is the model of engine not the rotavator
May 06, 2015 | Briggs & Stratton Garden
Manual for briggs and stratton 12000 series mowers quantum
B/S makes the motors for several brands of mowers. Go to the web site and search your model for a download.
Oct 07, 2014 | Briggs & Stratton Quantum Lawn Mower...
Repairing a Briggs and Stratton Quantum 35 mower engine. How do you replace the metal starter pawls in an older Briggs & Stratton mower engine
take cap off drive the pin out the bottom from the top replace starter pawls and springs put back to gether drive the pin back in checking making sure not to thight if it is drive pin back some until it spins freely
Aug 22, 2014 | Garden
Servicing a briggs & stratton 35 classic
Clean exterior of engine and frame. Remove and sharpen blade. Clean blade compartment, scrap off old residue and wire brush. Repaint if necessary. Replace spark plug with new. Drain oil and replace with new - DO NOT OVERFILL!!. Replace air filter with new after cleaning filter compartment.
Jun 30, 2014 | Briggs & Stratton Garden
What sroke is a masport 635. is it two or 4 stroke. it has an openping for the petrol and a seperate opening for the oil.
Judging from what discription you are giving me I would say it is a 4 stroke, so make sure you have either sae 30 or 10/w30 oil in crankcase where it says oil and petrol (gas) in the other tank. 2StrokeJim
Oct 27, 2011 | Garden
Briggs and stratton 35 classic. Need piccy of arrangement of carb/choke links and springs as think someone has changed them and mower no work. Model 9D902. Lever which may be choke, does not stay in place...
check youtube,guy on there has pics of spring set up,and still pics to follow the video.
check this name on youtube:4 HP Briggs & Stratton Quatro Motor Spring & Linkage Close Up Detail
Apr 25, 2011 | Briggs & Stratton Briggs Stratton...
Where can i get a manual for a briggs and stratton pwr400prma 35 classic petrol rotary mower
Sep 12, 2009 | Garden
Garden Logo
55 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
