Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
BAD CONVERGENCE BOARD
I have a RCA D52W20 HDTV and its about 3 years old. I believe the convergence board is going bad. There is a blue shadow around all the images. When you try to adjust it the color is all spread out. I don't want to spend $ 700 to fix it. Is there anywhere that I can just buy the board?
  • godzilla73 Nov 20, 2007
    Thanks. I feel the TV is probably only worth 300-400 so I would hate to pay to get it fixed. I would like to get the board and try to fix it myself.
    What does this board look like? If the lenses are not lined up correctly could that cause the blue ghost image?Sorry to sound like a noob.
  • 143 Answers
Yes you can but the going rate for this fix is 250-350 if you would like to fix it your self let me know and ill give you step by step k good luck
Posted on Nov 20, 2007
  • marco amezcua
    marco amezcua Jan 02, 2008
    the board is not gooing bad this is what a lot of techs that are trying to get money out of you say the only thing that goes bad is the convergance ics they only cost 12-15 dollard each and there are 2 or 3 of then get back to me k
Double vision, believe one of the guns went bad
If the auto convergence feature is still listted under the setup menu then you need a convergence power supply board. If the auto convergence feature is no longer listed under the setup menu then you just need a repair kit. You can get either one from www.tvrepairworld.com
Sep 25, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Screen lookes like colores separating
Here's all I find regarding bad convergence from the techrepairCD:
RCA ~ITC222 D52W20~Convergence bad~~~ITC222~Replace leaky DL032 on
deflection board~~~~~~
RCA~D52W20Y ATC221~Convergence goes out/bowed after on for a few
minutes~~~ATC221~Problem may be on the deflection board. Was unable to
pinpoint where in this case.~~~~~~
RCA~D52W20BYX1 ITC222~Convergence way off after replacing small signal
board~EEPROMS were transferred over to new board~~~IK210 was
defective..transfer the new EEPROM back over.~Remember on these
sets*when replacing the SSB* if there is a small P on corner of
screen*hold volume on remote for 8 seconds after it reaches minimum.~~~~~
RCA~D52W20BYX1 ITC222~Can not align blue convergence* bottom really
bowed* possibly either color after replacing SSB.(Or no auto
convergence.~(Service menu: turn power off for 30 seconds* press vol dn
and ch dn* simultaneously for 8 seconds* set turns on with service menu
options)~~ITC222~In service menu* select convergence. If sensor
calibration was performed when convergence was too far off* it will not
alighn.~Get crosshatch with straight lines* perform sensor calibration*
then attempt convergence alignment again. Be sure to store settings*
then do sensor calibration again.~You must get a green flash of the
screen after sensor cal and a check in the box. RED flash indicated
convergence settings are too far off~~~~
RCA~D52W20BYX1 ITC222~no convergence correction~~~ITC222~LP650
(259271) DP670 (259246) & RP632 (259564) 4.7 3W on convergence power
supply board~~~~~~
Oct 28, 2008 | RCA R52WM24 52" HDTV Projection Television
This tv have convergence problems,it dead.Red,green,blue misaligns colors,have colors shadows,3d colors pic like.All these problems are the convergence board have 2 STK convergence ICS some or all it resistors are dead.These parts must change to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 07, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Red shadow on tv
If this is a projection tv a shadow usually indicates bad convergence. If you cannot adjust convergence from customer menu have a professional replace convergence amplifiers and reconverge
Apr 08, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
CONVERGENCE WILL NOT ADJUST ON SIDES
First you need to read the supply voltages to the STK's. Black things, size of 2 match books on a big heatsink. Sounds like your supply voltage is low, could be a bad STICK STK. usyually stk 130-20 or 150, etc..
Mar 07, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P56812BL big screen porblems
this is a complete loss of convergence. FIrst question do you have the convegence option under setup in customer menu... if you dont then it might be the fl231 fuse problem common with these sets. if you do then try autoconvergence... if fails then you probally have a bad convergence power board. there are three diffrent boards that can affect convergence. convergence power, convergence amp, and small signal board..
Nov 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence problem
your model has two boards that control convergence. One is the convergence board. the other is the convergence board power supply, usually when more than one color is off its the Convergence power supply that is bad. You can get replacement circuit boards at the following link.
http://servicemanuals.vstore.ca/
Jul 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a rca hdtv r52wh77 1 year old ,i have color problems ,i cant get to the convergence set up ,please help.thks
Try looking at the main board very near the flyback and you should see 3 fuse links (they look like hard capacitors) one of them is probably open causing lack or power to the convergence board by way of the ribbon seated close to the vertical output IC
Dec 22, 2007 | RCA P52937 52" Rear Projection Television
HDTV convergence going bad
convergence is tricky.. there are three seprate boards that it is split with.. do you have NO convergece at all.. could be convergence power board...one color... convergence amplifer board.. it it could be the signal board.. there's even a chance it could be a descrete fuse... shoot me some more info..
Nov 20, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w2052 d523c10df itc222
The issue is the Deflection board. The Fl1231 is open. The Deflection board needs replaced
Nov 11, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
140 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
