Question about Keurig Coffee Makers & Espresso Machines
Comes on says not ready then goes to prime - Keurig Coffee Makers & Espresso Machines
On Vienna Deluxe after the beans are ground and ready to drop the espresso shots, nothing comes out and the red light goes on? I shut the unit off for a minute or so, turn it back on and it works ok, but...
Solid red light is a ventilate light.. Try Priming the machine to see if the light goes away.
Something may be in the flow meter. Its the while device between the water tank and the pump of the machine. You would have to open the machine and clean out the flow meter.
Also, if you haven't descaled the machine already, I would start there.
Saeco Espresso Parts Brew Groups Pumps Boilers Water Tanks Drip trays
Mar 07, 2015 | Saeco Vienna De Luxe Espresso Machine
How to prime
Lift the reservoir, then reseat it. This will clear the prime message. If it repeatedly comes back then your machine is dead. If in the year warranty, call Keurig they will ship you a replacement. A common problem.
Mar 21, 2014 | Keurig Platinum B70 Coffee Maker
Cannot get past prime funtion
Dirty tubes, manually clean,
Nov 17, 2013 | Keurig B60 Coffee Maker
Ran out of gas, prime the fuel injectors
No priming needed
When you turn the key on, if
the fuel pump comes on, you get fuel
Any air goes into the cylinders
You probably ruined the pump running
out of fuel or it is just old & worn out
Sep 06, 2013 | 1989 Isuzu Trooper
Starbucks Saeco Italia Digital Barista Fully Automatic Coffee Machine will not prime!
Here is what is said in the manual:
"Direct the steam arm on the drip tray.
Open the steam/hot water knob until a
steady stream of water is dispensed. Close
the knob. Insert the filter holder into the
brew head to pre-heat the filter holder.
The machine is now ready to dispense
coffee."
Apr 26, 2017 | Starbucks Saeco Italia Digital Barista...
Can't prime Starbucks Estro Vapore espresso machine
I can't get that screw off that holds the screen down. I'm trying to change the rubber gasket. The screw just goes round and round in both directions! I'm afraid to just pry it off!
Jul 08, 2008 | Saeco Vienna De Luxe Espresso Machine
Nespresso Magimix M300 'Fill Water'
it just means that the pump needs primed. Turn on at the wall and on the machine, wait until screen says ready (make sure water tank full), then turn steam handle on RHS to on (do not push the steam button). the pump will prime until water comes out of the steam nozzle. now turn off the steam handle and you are ready to go!
Sep 16, 2007 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
27 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
