Question about Whirlpool Microwave Ovens
I have just brought and installed a whirlpool underneath oven and was looking for a manual for it on line
    Sergeant:
  • Whirlpool Expert
  • 445 Answers
Model # would help many manuals model specific
Replacing underneath lights
If the owner's manual does not address it, then some disassembly may be required.
You didn't mention your model number or even your brand, but since you posted it under Whirlpool, maybe it's a Whirlpool.
You can download Whirlpool owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Always be sure to unplug the oven or turn off its breaker before removing or installing the bulbs.
Failure to do so may result in damage that could require circuit board repair.
Oct 27, 2013 | Whirlpool GH8155XJ Microwave Oven
User Manual Whirlpool Magicook 22G
Nov 28, 2012 | Whirlpool GH7155XHS Microwave Oven
I need to replace light bulb in Whirlpool built in microwave model # RMC 275PD. Is it necessary to remove unit from wall to replace the light bulb?
It looks like it, but if you look at the diagrams, maybe not.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven
here.
Oct 02, 2010 | Whirlpool RMC275PD Microwave Oven
Whirlpool microwave GH7145XFseems to have shorted out. Is there a circuit breaker somewhere on the oven itself that can be reset? History: Trying to turn off the oven light when the door was open, I...
There should be a line fuse inside, and a less likely culprit would be the oven cavity thermostat.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
mini_manual_behind_grille_small.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find your mini-manual, or if you want to look at it before removing the controller, you can download it here (just enter your full model number without dashes).
Accessing the oven cavity thermostat for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If both of those components are bad, it may be a damaged control circuit board.
We can repair that for $39.95 in most cases, or you can buy a new "microcomputer" circuit board (part number 8169379) here for $146.66.
Jul 16, 2010 | Whirlpool GH7145XF Microwave Oven
My over the range microwave oven light(underneath) does not work. The bulbs were tested, they are OK. Is there a fuse to replace?
Maybe. In some Whirlpool models there are several fuses.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
I doubt that it's a fuse, though. We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jan 09, 2010 | Whirlpool Microwave Ovens
WHAT IS THE TRICK TO CHANGING THE UNDERNEATH LIGHTBULB IN MY JENN AIR MICROWAVE?
You can download owner's manuals and installation instructions for several brands (including Amana, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Dec 06, 2009 | Jenn-Air Microwave Ovens
Whirlpool MH1150XMQ 1000 Watts Microwave--NO HEAT
About 95% of the time it is the magnatron. If the microwave is under 5 years old that part is often covered under warranty. I would check your manual. If not the p/n is 8206335 and it's about $80 and fairly easy to install. I just looked and the magnatron is covered.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0523111.pdf
Labor to replace it would be about $125
Mar 04, 2009 | Whirlpool MH1150XMQ Microwave Oven
I need install instruc. for a Whirlpool wallmount microwave.
sears should be able to get you the installation instructions and maint manual for this also, get on line go to sears.com and look up uour microwave part number like you did and look for the manuals
Dec 08, 2008 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Cooking light inoperable, everything else working fine
just did further testing...I stated incorrectly before, appears to be one/both relays for this light
Nov 12, 2008 | Whirlpool MH1150XM Convection/Microwave...
Fan cover reinstall on inside of microwave
Oddly enough, Whirlpool calls these fasteners "nails". They hold that waveguide cover ("inlet cover") in place.
You can find helpful exploded view diagrams and order needed parts by entering your full model number here: http://tinyurl.com/gv383
See diagram number 6 on the resulting parts list.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 10, 2008 | Whirlpool MH7140XF Microwave Oven
Microwave Ovens Logo
102 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
