If you have input voltage 110 volts. On the white and black wires. No output voltage at the red and white wires. It's garbage there's nothing serviceable on the unit.
Most all travel trailers are set up for 30 amp single pole service which means 110 volts. Always check with your service manual and make sure, if you hook it up wrong you will burn up/smoke some electronics and it can be a costly problem. Also, a 30 amp service for travel trailers are not like a regular receptacle, it takes a special type of recept. Most any good electrical supply store can lead you in the right direction but you MUST know how to wire it up to code in your area! If your not a licensed electrician or at least know what I am talking about, I wouldn't recommend you doing this! It may have to be done in GFI and/or waterproof connections.
