Question about Kyocera Office Equipment & Supplies
My problem in my machine Kyocera Taskalfa 620 an error c3300
sir fixalot
  • 146 Answers
SOURCE: Kyocera KM 3050 - error C3300
Error C3300 is a CCD Automatic Gain Control issue.
It could be poor contact in the connector terminals from the SHD PWB to the CCD PWB.
It is more likely a defective exposure lamp or inverter board that powers the lamp.
Try lifting up the Document feeder so you can see the optics frame through the platen glass and turning off and then on, the main power switch to see if the green exposure lamp illuminates.
A better, but more complicated way to check the lamp is to enter the service mode and run the exposure lamp test simulation. I will outline this procedure below. BE SURE NOT TO MESS WITH OTHER THINGS IN SERVICE MODE OR YOU COULD RENDER YOUR UNIT COMPLETELY UNUSABLE.
To Enter Service Mode:
Hit the "Status" button
Hit the following sequence on the numerical keypad:
1 0 8 7 1 0 8 7
You should be in service mode.
Use U601 by typing 6 0 1 and then "Start"
U601: Turning the exposure lamps on
Description: Turns the exposure lamp on.
Purpose: To check the exposure lamp.
Display:
CCD: Main Exposure Lamp
CID: Document Processor Exposure Lamp (inside the feeder)
Method
1. Press the start key.
2. Select the item.
3. Press the start key. The selected lamp lights.
4. To turn the exposure lamp off, press the stop key.
Completion
Press the stop key. The screen for selecting a maintenance item No. is displayed.
After checking the lamp(s) operation hit "reset" a few times to back out where you can type 0 0 1 "Start" to Exit Service Mode.
Posted on Jun 03, 2008
SOURCE: i also need a service
call service c3100
Posted on Nov 09, 2010
sodeep
  • 3267 Answers
SOURCE: installing a new kyocera TASKalfa 250ci and i got
C3100 Scanner carriage problem
• The home position is not correct when the power is turned on or copying the document placed on the contact glass.
Poor contact of the connector terminals.
Defective scanner home position switch.
Defective engine PCB.
Defective scanner motor.
This copier may need a service adjustment. The problem could be something as simple as a switch not being in home position. Please troubleshoot accordingly. Unplug device when troubleshooting.You should also troubleshoot it by looking to see if anything is blocking or stuck causing the carriage to not go into position.
Posted on Dec 22, 2010
shawn38
  • 200 Answers
SOURCE: my kyocera taskalfa 180 showing
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Cursor / highlight "Execute".
Press "Start / Print key.
The machine will turn off and should come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
Shawn
Posted on Mar 02, 2011
SOURCE: reset all originals in DP
reseat orignals on DP.
Posted on Sep 05, 2011
Error code taskalfa 500ci , c3300
C3300, AGC Error. something in the copy lamp or optical section
Jul 08, 2014 | Kyocera Task Alpha 400ci / 500ci Yellow...
Error Code C 7460 On Kyocera Taskalfa 8000i
Developer shutter locked - open front cover and slide the developer shutter to open/unlock, restart the machine. The shutter is locked to prevent developer spilling when transporting the machine.
Oct 30, 2012 | Office Equipment & Supplies
C3300 error in kyocera taskalfa 820
I have actually discovered another cause of the C3300 error on Taskalfa machines .. Mainly the 250ci - 552ci (300ci, 400ci included) .. If you look at the mirror assembly there are 4 plastic pads that glide on the rails. I discovered 2 on the left side damaged causing the mirror assembly to sit at a slight angle .. Got these replaced and it works great!! I hope this helps!!!
Sep 11, 2012 | Kyocera Office Equipment & Supplies
How can i clear an error c3300?
Hi anonymous, Firstly read your user manual. Secondly search online for "error code c3300 kyocera km5050". I did and therefore can't see any reason to spoonfeed any further.
Aug 25, 2012 | Kyocera KM 5050 Toner Cartridge 34000...
My kyocera taskalfa 180 asking me to call service C6000. How can fix this error?
My kyocera taskalfa 180 shows an error.call service c6000.what should i do
Jun 30, 2012 | Kyocera TASKalfa 180 Copier
My kyocera taskalfa 180 showing c6400 error please help.
To reset -
Shawn
Feb 25, 2011 | Kyocera TASKalfa 180 Copier
Free service manual with code for kyocera TASKalfa 180
Pls. send Free service manual with code for kyocera TASKalfa 180.
My email itechf2@gmail.com
Especially interisuet off hibernation.
Aug 05, 2010 | Kyocera TASKalfa 180 Copier
62 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
