Question about Honda Garden
Ki need honda prssure washer GCV190 - Honda Garden
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: I have a honda GC160
Hiand welcome to FixYa, I am Kelly.
GC160 is the engine number.... It does not tell me that pressure pump is on the unit.
There should be a large knob on the side of the pump head. That is the bypass / unloader valve. Removed that and clean the pump housing where the flat plunger mates to the bousing. Then disassemble the unloader vavle. Remove the lower part of it from the knob and clean off the corrosion and dirt from the plunger and spring. Clean everything brass.... Reassemble using what you could consider abnormal amounts of WHITE GREASE. Place a GOB of white grease into the pump housing be re-installing the unloader / bypass valve. Just remember when you hook up water for a funtional test, that your going to spray some off that extra white grease through the pump and wand nozzle.
This should get you going again. If not I need a model number for either the pump body or the whole pressure washer vs the Honda engine number of GC160.
Thanks for choosing FixYa,
Kelly
Posted on Aug 01, 2011
What kind of pump oil for simpson gcv190
I need to know the model of the pump you have. You are giving us the model of the engine which is a Honda GCV190. Can you tell me the model on the pump itself. It is more than likely an AR pump but I need to know . It is more than likely going to take 30 weight non detergent but some pumps take specific oil. You can also call Barens at Pressure washer parts catalog quick links Pressure Washers High Pressure... They can hook you up with the correct oil for your pump. Good luckOADXAV
Feb 21, 2015 | Simpson Garden
I need a Honda GCV 190 operation manual that is on a Ryobi 3100 psi power washer
Please click on the link for the operators manual for your engine a Honds GCV190
Hope this helps
Brad
http://cdn.powerequipment.honda.com/engines/pdf/manuals/00X31Z8B0240.pdf
Jul 29, 2014 | Garden
Honda specifications
Hello, The compression ratio is:8.5:1.
You can go here for all the info you need.
May 15, 2014 | Champion International Champion& Small...
Honda gcv 190
If it begins to catch then you definitely have ignition. Try replacing the plug with same type. If same result, the main jet in carburetor is clogged or the needle valve is stuck and not allowing fuel to enter into motor.
Mar 29, 2014 | Garden
I put 2 cycle gas in my 4 cycle Honda gcv190 pressure washer
did you pull the spark plug out and clean it ? if you did , did you also put the starter cord and turn the motor over without the plug installed to get rid of the 2-cycle oil out of the cylinder ? if not do so.
Jul 19, 2013 | Honda GCV190-N5AP 187cc GCV190 Series OHC...
I bought my new husky/ honda gcv190 about a month ago, i haven't even started it yet. I didn't realize that the owners manual was for a totally different power washer. I don't want to bid on one,buy one or...
http://www.apwdistributing.com/
You should be able to download a pdf version of the owners manual here.. you will need your model number.
Model number HU80432 uses the Honda GV190 Motor
Best of luck!
Apr 12, 2011 | Garden
Garden Logo
90 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
