My tv model number TD2401 does a count down to turn itself off, there is nothing in the manual telling me how to stop this.
5 Suggested Answers
SOURCE: Microwave turns on and counts down but won't heat up/cook
Ok just figured this out! It is a problem with the alignment on the lower door switch. I took the cabinet off and lifted up on the door switch slightly and voila! It works. You could probably fix this without taking it apart, just lift up on the door ever so slightly. I hope this works for you.
Posted on Mar 06, 2009
rapanSF
  • 150 Answers
SOURCE: Recording stops when i turn off the tv
Maybe setting for hdmi on dvd player is set to synchronize with tv, check manual to disable.
Posted on Mar 25, 2009
blueextc3221
  • 15935 Answers
SOURCE: Ge Adora washing machine counts down, but won't wash.
It appears your timer/controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
  • 6771 Answers
SOURCE: stopped turning and heating
The problem is one or two bad door switches, "more than likely" the less likely is the keypad control board.
Posted on Apr 12, 2012
My Audiosonic td2401 keeps turning itself off, have checked the internal clock and timer, sleep mode is set to off, any other advice on keeping it running for more than 5 hours before it turns itself
HI. If you are 100% sure that no timer is active, then I guess it is a thermal problem in the TV. There can be bad solderings, mostly in the horiz., or vertical powerstages, causing the TV to shut down after 5 hours. At least, this time should be different if the ambient t° from the set is higher or lower.
If the "turn off" time is always exactly 300 minutes, no second more or less, then there might still be a processor problem in the TV. Not easy to find. Also, these replacement micro-processors contain a
pre-programmed booting section where all characteristics and alignment data from your set are stored as a factory setting....
Huge problem, which can only be solved by an Audiosonic service center. Good luck.
Oct 02, 2014 | Televison & Video
Turn the TV on and the TV clicks on and the green light goes on then goes to red and starts flashing - nothing comes up on the screen.
There is a problem inside the tv which is shutting down the tv to avoid a much more serious problem.I assume that it flashes the same number of times every time the set is turned on.If you count them that will tell you what area the problem is providing you have the code list.
Sep 25, 2010 | Televison & Video
Tv wont turn on. power button blinks
if your tv is blinking you are still okay but your set needs service, maybe some board or circut is defective. this happens with panasonics, they have a blink timer. they blink a certain number of times. this blinking feature is called safety mode, you find the part that is fualty according to the number of blinks, you can find out what fualty part is cuasing the tv not to go on by downloading a service manual in pdf format or finding the blink codes, how many times does it blink count it carefully i may have a manual here and maybe can tell you what to replace.
Jun 03, 2010 | Panasonic TH50PZ80BPED 50 in. Plasma TV
Tv turns on for two seconds, shuts off, begins binking.
The problem is most likely a power supply related problem.
The TV is in protection mode right now. It's keeping the other parts inside the TV from being damaged by automatically turning itself OFF. The 9 blinks should be an error code for the problem with the power supply. I don't have the Service Manual for your TV model number to tell you what the code means and which part to replace. Every brand of TVs have a different meanings of the code.
If you have electronic experience, you can find a factory repair manual over the internet. Normally, it's called a Service Manual. It costs about less than $20.
Jul 31, 2009 | Panasonic TC-26LX70 26 in. LCD Television
Mar 25, 2009 | Televison & Video
Jan 28, 2009 | Washing Machines
Our sony tv keeps turning itself on stand by. you press the standby button on the remote and it comes back on for a few minutes then does the same again until it will not turn back on. you have to then...
When the Sony shuts down, the standby light shoulb be blinking a repeated count. Can you please post the model number and that count? The count will indicate the circuit that had a problem causing the set to shutdown.
Thanks,
Dan
Jul 24, 2008 | Televison & Video
Mitsubishi Power Problem -turns itself off.
Sounds like CRT coolant leak onto signal board = check
for work....................................................T.
Nov 10, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
