Question about Sewing Machines
Ladies short sleeved knitted top knitted sideways from knit 2 purl 2 cuff of sleeve across chest with a round neck. the front and back are a square knitted from bottom to underarm then cast off.
I am looking for the pattern for this short sleeved top described above, that my mum knitted for me in the 1970's, as I would like to knit it again.
  • David Ellis Rhea Dec 08, 2016
    Hi angela , I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Do you have a question?
  • angela
    angela Dec 08, 2016
    I a looking for the knitting pattern for this top.
SOURCE: My Brother KH-270 knitting machine
What you do is load the yarn into the carriage and draw it accross the bed of chosen needles once.
After that hang on the cast on comb on these loops that are formed and put on some weights, and then start knitting. Push the carriage back & forth forming stitches. It will then form stitches and when removed from machine won't run. Read you manual, it explains all this.
Thanks for asking.
Posted on Mar 16, 2009
SOURCE: when using 2 yarns, main color is suppose to be
i need a manual
Posted on Apr 02, 2009
SOURCE: Kids singer knitting machine manual - how to cast on
go here
Posted on Jul 05, 2009
  • 739 Answers
SOURCE: The cam on my Brother KH- 830 knitting machine is
Please check with the more detail about your model of sewing machine, because when I find the model you gave is not in the list of Brother's website. The model is very important for you to ask for technical help or download the guidelines.
CLICK HERE to make sure the model you mean.
Posted on Apr 19, 2011
  • 1564 Answers
SOURCE: trou ble with chain knit scarf/pattern
This question should really be asked at a knitting site. Try your question here where the pro knitters hang out.
Posted on Jul 20, 2012
Pattern "Simone" in Neck Effects book - should Rows 2,4,6 be purl instead of knit? It says it is stockinet the but if you knit it will be garter stitch
Then knit purl to keep stockinet st. unless it changes in the pattern. what does the picture look like?
Feb 09, 2018 | Sewing Machines
Knitting: if I'm slipping the first stitch of each row purl wise, with the yarn in front, should I also slip the first stitch when I bind off?
If you are binding off on a purl row (or at least stitch 2 in the row is a purl), then yes, you should slip the first stitch of the bind off row.
If, however, the bind off row is a knit row (or a least the second stitch in the row is a knit) I would knit the first stitch.
A lot depends on the pattern being worked. Personally, I would try it both ways and see which way looks best with the pattern.
Dec 23, 2017 | Sewing Machines
I need a sweater pattern that has raglan sleeves, v-neck in Double knitting wool
Go to or lion brand yarns or berocco on line.
Oct 16, 2017 | Sewing Machines
What do yon and yfrn mean in a knitting pattern?
yon is usually Yarn On (or over) Needle. This is a yarn over between a purl and a knit stitch. (After the purl stitch, keep the working yarn in front of the needle. Then place the right needle into the next stitch so that the right needle is behind the left needle in the stitch. Wind the yarn around the needle and pull the loop through.)
yfrn is a Yarn foward and round the needle. This is a similar yarn over to the yon but is a little larger. The difference is that the yarn over is done after a knit stitch and before a purl stitch. After the knit stitch, bring the yarn in front of the needle. Wrap the yarn anti-clockwise around the right needle so that the yarn is again at the front of the work. Place the right needle in the front of the next stitch on the left needle. Then do a normal purl stitch.
You can see some videos and still photos here: .
I hope this helps.
Oct 22, 2016 | Sewing Machines
How to increase a knitting pattern Gingersnap
Usually increasing stitches is accomplished by knitting (or purling) twice in the same stitch.
How to Increase and Decrease Knitting Stitches For Dummies
Decreasing is accomplished by knitting (or purling) two stitches together.
Jul 14, 2016 | Sewing Machines
How do I add knit band to pajama pant on McCalls pattern 7975. I have lost the directions.
Usually the cuff ribbing is cut double the required length plus doubled seam allowances (ie 3" x 2 = 6; add two 5/8" for seams = 1.25"'; equals 7.25" long). It is doubled so when it is folded in half and stitched to the leg, there will be no seams showing outside). The width of the ribbing is probably an inch or so shorter than the leg bottom--it should be large enough for the foot to fit through but tight enough that it hugs (not squeezes) the leg.
Sew the cuff together lengthwise to make a circle. Fold it in half with the stitched seam inside. Then fold the circle widthwise with the seamline at one end. Mark the halfway point opposite the seamline. Then fold in half again with the seamline and the first pin matching together. Mark the other two ends. You've divided it into equal fourths. Repeat the same procedure marking the pajama leg in fourths. Then match the seamline of the ribbing to the seamline of the leg (right sides together). Match the other three marks on the cuff to the three marks on the pajama leg bottom. You'll have the stretch the ribbing because it should be a bit smaller in circumference than the leg bottom. Stretch the ribbing to match the leg bottom and stitch the ribbing and leg bottoms together. Turn right side out.
How to Attach Knit Cuffs to Sleeve Shirt Sleeves
sewing with knit fabric how to sew sleeve cuff with knit fabric
Jan 02, 2016 | Sewing Machines
I need help with a cardigan. It is the Imperial Yarn Arrowhead Cardigan. It is worked in the round with two colors and has steeks. I have just finished the armholes and have binded off the armhole steeks...
I think that's a question for the folks at Knitting Paradise. They have more knowledge than I could have ever imagined and have always answered my knitting questions.
Aug 26, 2014 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
