Line flashing through the middle of tv interminted
  • Brad Brown Dec 08, 2016
    Hi Kathy Alloco, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? what make and model and is it a vertical line or horizontal
Black line Down middle of 50" plasma screen tv
The tv T-CON board it is dying to causes this problems.This T-CON board sit in the middle at the bottom of the tv plasma screen panel.Try website like to buy a whloe new refurbish T-CON board for the replacement.
Jul 18, 2011 | Samsung 50 in. Plasma TV
Intermintent cruise contol on 2007 ion coupe 2.4 not red line. I've had it to the dealer several times, and it seems to work for them thats Bull### what else can I do to fix this? Thanks
My 2007 Ion 2.2L sedan has the same issue. Every now and then when I am driving, the Cruise Control fails to engage. If I turn the car off, re-crank it, it works fine. Dealer cannot find the issue and it only happens about once a month. No bad computer codes or anything, just annoying.
Mar 25, 2010 | 2007 Saturn ION-2 Quad Coupe
Flashes on and off,intermintent will turn on all
This is most likely a connector fault to the radio. Particularly check any inline fuse that may be fitted.
Remove the radio from it's mountings and check all connectors. Check all wires into the connectors that they are not loose.
Keep connected while you turn the radio on with it out of its fixed position. You can sometimes find wiring faults by moving wires while connected.
This is most likely to be the fault.
Oct 01, 2009 | 2002 Chrysler PT Cruiser
Horizontal line through the middle with sound. If you hit the side of the TV the picture will come back and then go away again.The TV is about 10 years old. Every now and then the picture will flash...
sounds like an intermittent problem. it could be a cold solder and it needs to be resolder it at the VERTICAL IC or transistor section , if your good with tools , you can do it yourself , otherwise take TV to a nearest repair shop, hope this helps , AJ
Jul 07, 2009 | JVC AV-27230 27" TV
Weird blue flash when tv turns on or off
TV will need service soon, blue CRT is on its way out, will need replacing
Mar 25, 2009 | Sony KP-51HW40 51" Rear Projection...
Wipers quit intermintantly
Both the 4X4 control module and the windshild wiper motor share a common ground point . G-301 , probably a lose connection. G301 kick panel, LH side
Oct 11, 2017 | 2003 Ford Expedition
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
Sony kv27v22 TV
check horizontal drive tramformer for intermitance is common problem some time blows horiz transistor to or vertical IC intermintence to
Apr 01, 2008 | Sony KV-27V22 TV
Black Vertical Bar
It will burn into the screen overtime. The Akai units have a resistor on the address board that feeds the PDP that usually has a crack in the solder on one or both ends of it. There are about 4 address boards that are right below the panel itself and the suspect one is the board right below the line that is appearing. Have someone with solder skills repair it.
Jun 02, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Line in the middle of screen
You have a bad component in the vertical circuit of your set. If you hit it on the back of the cabinet with your hand which will "jar it" and the picture flashes back on then you have loose connection. If nothing happens then the vertical circuit has a bad component most likely the Output IC. (Chip) Stargazer
Mar 27, 2007 | SansuiS2001 20" TV
Televison & Video Logo
Top Televison & Video Experts
