Fanuc lathe spindle stops when switching to handle
What parameter to change to keep spindle from stopping when switching from auto to handle?
5 Suggested Answers
SOURCE: i need fanuc ot cnc parameter discription for 900
The parameters 900 to 940 are different for each type of machine. You need to specify the control
Posted on Aug 06, 2010
  • 3567 Answers
SOURCE: i am having cnc lathe
I assume this posting was a test. I answer it simply to remove material that does not apply to the motorcycle category...
Posted on Sep 15, 2010
jyackle5
  • 8197 Answers
SOURCE: Where ca I get parts
Sorry mastercraft tools are made by Canadian Tire. You can not get parts for the item They will not sell parts or supply them. We get a lot of requests for parts and have called Canadian Tire and they will not tell us where to get parts. You can try to call them at (1-866-746-7287) or here is the mastercraft tool direct line. 314-429-3333
Posted on Mar 30, 2011
  • 42064 Answers
SOURCE: How do I change the spindle direction on my fagor control on lathe
I take it that you have tried all the buttons on the panel. As a safety feature it a may require a combination of switches according to the fagor manual item 4 which is he set of 9 buttons bewteen the to turn switches"quote: - keyboard which allows the spindle to be controlled, it is possible to activate it in the desired direction,stop it or vary the programmed turning speed between the percentage values established by means of a spindle machine parameters MINSOVR an MAXORV with incremental steps established by means of the spindle machine parameters SOVRSTEP "
go on line and type in fagorautomation.com/downloads/manuals/en.amn_8055t_opt.pdf for a user manual download.
Posted on Dec 10, 2014
I have a Mondale Celtic 14 lathe what is the electric clutch brake design to do
it is designed to stop the chuck from rotating when the machine is switched off or the cutting process is stopped
it is a safety requirement to prevent personal involvement with a rotating chuck
Oct 16, 2016 | Tools & Hardware - Others
Looking for a live centre and drive end spur for a Mastercraft 554508-0 cast iron wood lathe
Such accessories tend to be universal rather than dedicated to any particular make or model of lathe.
Such accessories are available from many outlets and catalogues containing items for the wood-turning enthusiast.
The tailstock of most lathes would be produced with a Morse taper numbers 1, 2 or 3 and with a variety of adaptors a number of live or dead centres, drill chucks or morse taper drill bits can be used.
Similarly the headshock spindle should be found to have a standard thread capable of accepting a number of chucks, faceplates, drive spurs and so forth.
The headstock spindle thread and the tailstock taper should be listed in the machine specifications and then armed with that information you can shop around a multitude of suppliers to find the best deal.
Apr 19, 2016 | Tools & Hardware - Others
Dec 10, 2014 | Cars & Trucks
JML 1014 Lathe - Just stopped Working
check for loose connections in the controller box
May 12, 2013 | Jet 708375VS JML-1014VSI 10 Inch X 14 Inch...
Motor stopped while turning. It does have power but will not run.
Motor should have red push botton on back or bottom of motor. This is reset over load breaker . Should be out, just push in until it clicks.
Feb 15, 2013 | Powermatic 1352001 3520B 20x35" Wood...
Blows breaker and groweling noise
It sounds like the motor is bogging down due to bad bearings or something is making the shaft too hard to spin. Make sure all the spindles are free. If its happening under load, make sure the lathe gets up to speed before trying to make any cuts.
Oct 18, 2012 | Ammco Combination Disc/Drum Brake Lathe
I have an aamco 4000 brake lathe, the disc feed is not working
The cross feed drive shaft is connected to the cross feed spindle via a coupling that resembles a universal joint that is threaded onto the end of the cross feed spindle. Either one of the roll pin holes in the drive shaft coupling has worn and the roll pin fell out or it has broken, or the coupling could have came un-screwed from the cross feed spindle. Remove the 4 bolts that hold the cross feed gearbox on and slowly pull it away from the machine and you should see the coupling I'm describing. My guess is that the roll pin broke or fell out due to wear. You can buy a new drive shaft and coupling or drill and install the next larger roll pin. Either way you should download a parts list for your machine. Just search for it, they can be downloaded free.
Aug 22, 2012 | Ammco Combination Disc/Drum Brake Lathe
Instructions for changing an ammco 3000 brake lathe to a 4000. Parts needed?
Yes, an Ammco 3000 brake lathe can be converted over to a 4000 model--most any year 3000.... preferably the later years after 1970.
The problem with some of the early 60's models is that the cross-feed bore is not perfectly perpendicular to the spindle.
If you convert one of these models, you will cut the rotor at an angle and then jam the machine.
Later models can easily be converted.
You will need...
1) A complete disc feed gearbox.
2) A driven pulley (the big one) set-up for a with a pin drive.
3) A complete spindle lock assembly for the Infimatic gearbox.
4) Possibly need a longer guide bar for the cross-freed. If you have a round guide bar, this is possibly long enough. If you have a "Double-D" guide bar (flat on each side), you most likely will need a longer bar.
5) A complete twin-cutter, with tool guides, tool holders, knobs, etc.
We have all the parts you need for a conversion--or we can convert it expertly for you...
Buy Sell Used Brake Lathes Brake Lathe Parts
Aug 03, 2011 | Ammco Combination Disc/Drum Brake Lathe
We need a used manual for a Whedco Drive # SMD-3041-1-A to complete a repair.
no luck finding a manual online. you will need to call them.
Corporate Headquarters
1800 Lakewood Blvd.
Hoffman Estates,IL 60192
binarywriterservlet?imguid=343dc937-2e42-42d4-9e68-0a04ae5ea95a&ubasvariant=33333333-3333-3333-3333-333333333333 1-847-898-5000
binarywriterservlet?imguid=e5d59637-68bc-46df-99b5-0805a6c8116f&ubasvariant=33333333-3333-3333-3333-333333333333 1-847-898-5001
Department binarywriterservlet?imguid=343dc937-2e42-42d4-9e68-0a04ae5ea95a&ubasvariant=33333333-3333-3333-3333-333333333333 Phone binarywriterservlet?imguid=e5d59637-68bc-46df-99b5-0805a6c8116f&ubasvariant=33333333-3333-3333-3333-333333333333 Fax E-mail Part Sales 1-888-FANUC US (select-1) 1-847-898-5021 binarywriterservlet?size=2&imguid=8ff70218-92bc-02f4-33d2-58cc02986030&ubasvariant=33333333-3333-3333-3333-333333333333 Service 1-888-FANUC US (select-2) 1-847-898-5011 binarywriterservlet?size=2&imguid=8ff70218-92bc-02f4-33d2-58cc02986030&ubasvariant=33333333-3333-3333-3333-333333333333 Repair 1-888-FANUC US (select-3) 1-847-898-5590 binarywriterservlet?size=2&imguid=8ff70218-92bc-02f4-33d2-58cc02986030&ubasvariant=33333333-3333-3333-3333-333333333333 Training 1-888-FANUC US (select-4) 1-847-898-5319 binarywriterservlet?size=2&imguid=8ff70218-92bc-02f4-33d2-58cc02986030&ubasvariant=33333333-3333-3333-3333-333333333333 Option and CNC System Sales 1-888-FANUC US (select-5) Option Sales (select-1) 1-847-898-5006 binarywriterservlet?size=2&imguid=8ff70218-92bc-02f4-33d2-58cc02986030&ubasvariant=33333333-3333-3333-3333-333333333333 CNC System Sales (select-2) 1-847-898-5691 binarywriterservlet?size=2&imguid=8ff70218-92bc-02f4-33d2-58cc02986030&ubasvariant=33333333-3333-3333-3333-333333333333 Accounting 1-888-FANUC US (select-6) 1-847-898-5016 binarywriterservlet?size=2&imguid=8ff70218-92bc-02f4-33d2-58cc02986030&ubasvariant=33333333-3333-3333-3333-333333333333 Service Contracts 1-888-FANUC US (select-7) 1-847-898-5031 binarywriterservlet?size=2&imguid=8ff70218-92bc-02f4-33d2-58cc02986030&ubasvariant=33333333-3333-3333-3333-333333333333If you have technical, service or parts related questions, or request requiring immediate attention, please contact us directly at our toll-free number 1-888-FANUC US (1-888-326-8287).
Good luck
Please rate FIXYA
Apr 07, 2011 | Computers & Internet
I need fanuc ot cnc parameter discription for 900 to 940
Mar 30, 2010 | Computers & Internet
21 people viewed this question
k24674
