Question about Air Tools & Compressors
Air flow control with a Accuspray 10 series cup gun.
I'm marrying an Accuspray 10 series cup gun to a Wagner 2900 4-stage HVLP turbine (8 CFM). Neither the gun or the turbine provide any means of air flow control. The gun has a .9mm tip and a #7 air cap. It will be used for spraying Valspar nitrocellulose lacquer for cabinets. With the set-up as it stands, do you think I will need to be able to control my air-flow. Accuspray makes an air regulator, but it's for taming the air that comes from a compressor. The inlet fitting is for a 1/4'' NPT fitting, not the turbine fitting. Any suggestions or do I really need the air regulator?
Thanks in advance.
    Problem Solver:
  • 6 Answers
You shouldn't have to control air flow - just adjust fluid to provide a good spray pattern. If you feel you need to slow down application rate you can buy a garden hose shut-off valve at your local hardware store that will thread onto your air line just before the quick disconnect at the gun.
They look like this
Posted on May 31, 2011
Can i thin Valpar Bond Primer no 46620 to apply with a Wagner sprayer?
If you have an airless sprayer yes , you can thin with a small amount of water or use flotrol for latex available at home depot or other box stores. If you have hvlp system no you can't. The hvlp uses a turbine wheel to compress air to around 3-5 psi. You did not say model Wagner sprayer you have. I use my Wagner to 1800-2000 psi. If the job is small you will have to consider the clean u time usually abound 30-45 minutes. Good luck
Jul 30, 2017 | Wagner Air Tools & Compressors
Old Wangner Cap Sprayer & Compressor
The Wagner Capspray 9000 HVLP is about 20 years old, but you should be able to find parts, at least for the HVLP gun. The manual for the turbine is #0276989. If you are in the US try Scott at American Airless Wagner Titan Graco Paint Sprayers or in Europe try us at:
Home Lion Industries
Jul 28, 2013 | Wagner Spray Tech Cap Spray Paint Sprayer,...
Air bubbling up in cup when air trigger is pulled this is a gravity fed hvlp spray gun
it means the air holes in the nozzle are blocked the air couldn't get out in the front so instead it went back to the cup makes it bubble
Aug 20, 2011 | Campbell Hausfeld Husky Gravity Feed HVLP...
The hose on my accuspray turbine Hvlp system is collapsing once it gets hot. Do hoses wear out like this, and can I replace re hose with a standard garden hose, or do I need to buy an accuspray hose?...
The hose supplied by Accuspray does soften as it warms up but should not be collapsing. Most hvlp turbine system manufacturers supply a hose with a helix reinforced hose that will not collapse.
The majority of hoses for hvlp systems are 3/4" inside diameter hose like the Accuspray hose and will work with your system.
The fittings will work with any 3/4" garden hose. Problem with using garden hose is that the cheap ones will collapse and kink and the quality ones will be heavy.
May 31, 2011 | Garden
I need a kobalt hvlp spray gun manual where can i get one?
Go back to where you bought it and have them photocopy the book from another unit. Good luck!
Jun 19, 2010 | HVLP 10 Piece Hvlp Paint Spray Gun Set
Finish is rough
Spraying smooth needs both the right airflow and right viscosity. Since your getting lap lines I would say your putting it on too thick. Thin down your coat, it should be approximately the thiness of water.
Apr 03, 2009 | Accuspray 4 Stage Turbine Sprayer...
Air Tools & Compressors Logo
302 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
