SOURCE: Blue-ray disc causing Sony blue-ray player to shutdown
No memory issue check on Sony's Website for Firmware update for your specific model and doenload and update your player
SOURCE: blue ray player wont play blue ray ''Kung Fu Panda'' disc.
i fixed this exactly as previous posted solutions, however a couple of points.
a) recordable CDs work if you don't have a DVD burner.
b) I didn't have a CD burner that would do an "image burn", I downloaded a free copy of "Express Burn" and that worked fine. The disk needs to be "finalised" or "fixated", it should do this automatically, or it may be a tick box selection.
c) I got a "No DWLD 09" when I put the disk into the player. I found this was an incompatibility with the CD-R (Maxwell) I was using. I changed to JVC and it worked fine.
SOURCE: Letter box picture when viewing blue ray discs on Sony BR player
All blu-ray movies are in Widescreen format. So your tv converts the picture to make it look like letterbox. There will be some movies that will have those little black bars at the bottom. There will be some movies that don't. There is nothing to worry about it is normall.
Hope this helps
SOURCE: vizio tv code for sony blu-ray disc player ''remote''
I put the Mitsubishi code, 04 as well for my visio 22 inch LCD. Worked just fine now!
SOURCE: My Sharp Aquos Blu Ray player cannot play my blue ray disc.
goto sharpusa.com and put in your model number. download the update to flashdrive and the update your blu ray..and it will then play
