Question about Electrolux Ovens
I have an Electrolux double wall oven EW27EW65GB6. On Thankgiving day, the top oven was being used.
After we finished using it we shut it off and the fan continued to run for a while as you would expect as it cooled off. Suddenly smoke filled the kitchen and a burned electrical smell ensued. I threw the breaker to shut off power. Troubleshooting by a technician found the lower oven convection fan was burned and was smoking. It wasn't even being used at the time and has only been used once or twice in 6 years. The upper exhaust fan pulled the smoke from the burning motor on the lower convection fan and filled the kitchen with smoke. I repeat, the convection fan wasn't being used at the time and it burned. What is wrong with this thing!
SOURCE: Electrolux Icon Mystery issue
Check to be sure your racks are all slid in to the back. Are you getting a error code?
Posted on Dec 25, 2007
  • 4889 Answers
SOURCE: F2 fault, continuous fan after clean cycle for Jenn-Air electric convection wall oven
The "F2" means the oven control senses runaway temperature. The cause of the problem could be the oven sensor, the oven sensor wire harness or the power relay board.
PS:please disconnect your oven from power supply completely before continuing.
Open the control panel and measure the oven sensor resistance at the control board. It suppose to be about 1100 Ohms at the room temperature.
If the reading is wrong do the same test at the oven sensor connection (where the sensor wires goes through the back panel).
If the reading is still wrong - replace the oven sensor.
If the reading is correct, check the wire harness and the connector itself (it's better to eliminate the plastic plug and hardwire the oven sensor).
If there is nothing wrong then the power relay board has to be replaced.
Posted on Nov 07, 2008
  • 311 Answers
SOURCE: No power and door locked after starting self cleaning cycle
Thermal fuse went out by door latch and thermal fuse on back of oven probably tripped too; once failed they need to be replaced. This is probably a job for the repairman as something caused fuse to go out in the first place; unless resolved it will recur. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Posted on Nov 30, 2008
  • 3463 Answers
SOURCE: bosch convection double oven,ovens won't heat,only broilers work
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Posted on Dec 17, 2008
  • 979 Answers
SOURCE: Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Posted on Jan 30, 2009
How do I set clock?
Hello Duane, thank you for your post!
Based off the information you have provided you need help setting the clock on your Electrolux wall oven. I have researched that information and located a manual for you. You would need to press the "USER PREF" button until you receive a "CLO 12:00". Then use the number keys to set the time of day, you can also use the "hi" or "lo" buttons to set time as well. Then press "START" to accept the time of day you have set it to. If you would like to review the manual it is located on page 28. I hope this information is helpful to you. -Matt
Dec 29, 2015 | Electrolux EW30EW65SS Stainless Steel...
The top oven is over-heating with no change in temp display. A red-hot heating element on the left side of the oven (facing it) shows through the floor of the oven.
Good Morning Eileen, thank you for your inquiry!
I understand that your Electrolux double wall oven is having over heating issues. It is possible that this could be a faulty thermostat, control panel, or element. Since it could be anyone of these underlying having a technician out would help avoid any unnecessary part purchases. If you need help locating a technician you can visit your manufacturer's website for additional assistance with locating a technician. I hope this information is helpful to you. -Matt
Aug 09, 2015 | Electrolux 27" Built-In Double Electric...
Top part of oven not heating up
Thank you for your post, friend!
Based off what you have described your Electrolux double wall oven is not heating up inside the top portion. It could be a miscommunication within your oven and you can usually perform a reset to clear that out. In order to reset your oven you would need to flip the household circuit breaker off for roughly ten minutes. If you restore power and continue you having an issue with your oven I would suggest you could have a possible fault with the control panel, thermostat, element, or connectors. Typically, this is not a simple DIY job. You may need to look for assistance with replacing any electrical components and I would highly suggest having a professional technician help with that. Hope this is helpful. -Matt
Feb 23, 2015 | Electrolux 30" Built-In Double Electric...
I have an Electrolux EW30EW65GS7 double wall oven and want to replace the baking element for the top oven. Is this done from the front or the back. I have the part and the oven is out and on the flo
Thank you for your post, Richard Gardner!
I understand that you need to replace the element inside of your Electrolux wall oven. I was unable to locate any specific step by step instructions on the removal and installation of your element. I have attached a copy of your parts manual and that provides a breakdown of all the available parts within your wall oven. If you need further assistance I would recommend having a professional technician out to properly remove the element and install the replacement part. I hope this information is helpful to some degree. -Matt
Jan 17, 2015 | Electrolux Ovens
How do I set the timer on the EOG9330XN oven
If the oven is switched off on the wall or there is a loss of power, the clock will stop and you will not be able to use the oven. This also applies when you switch on oven for the first time.
Always you have first to set the time of day, then is possible to turn on the oven. Read user manual.
Oct 09, 2014 | Electrolux EOG9330 Gas Double Oven
Electrolux oven racks how do they go in oven?
Hi Friend, that's a great question!
I see that your post is listed under Electrolux Wall-Oven. May I have your model number please? You can normally find the serial tag (which lists your model number) on the front of the oven, on the left side, as you open the door. With this material I can provide you the correct instructions on how to place the racks in your Electrolux wall-oven. Thank you! - Z
Jul 20, 2014 | Electrolux 30" Built-In Double Electric...
Tried to clean single Electrolux wall oven. The cycle began, the door locked and then the oven shut down with the door locked. I shut off the breaker for 10 minutes and then back on, no change. I checked...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Jan 20, 2011 | Electrolux ICON 30 in. Double Wall Oven
Electrolux 30" electric double oven
Some oven elements are "plug-in" style, held in place with spring clips, It is possible that they have dislodged during cleaning. Good luck, Rob
Dec 31, 2010 | Ovens
Using both ovens at the same time
Both ovens should be able to be used at the same time. Most likely problem is the control board or user interface. The oven should have a 1yr. warranty. Call your local authorized servicer but first please rate this post.
Dec 14, 2009 | Electrolux 30" Built-In Double Electric...
Kitchenaid double digital convection conversion oven keypad went out. Any ideas on the problem. Electric panel circuit breakers are okay. Sharon C.
I think these use the same controller board as the Jenn-air units, they have a weak capacitor (C3) on the control board (Timer/control Display). Remove the top panel and look for a discolored or leaking capacitor (usually black about 1/2" high 3/8" in accross). Replace the capacitor and the problem goes away, until next time you use the self clean cycle which seems to overheat the control board and ruin the capacitor.
Sep 23, 2009 | Electrolux 30" Built-In Double Electric...
Ovens Logo
Top Electrolux Ovens Experts
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
