SOURCE: Blanco dishwasher error d06 faulty motor.
I have a Blanco BFD10X Dishwasher which had the same D06 error, being a Electrician i investigated the fault which Blanco report as motor over current. After testing the motor, i tested the motor Run capacitor and found it to be faulty, these capacitors are common to failure and will cause the pump to draw more current than usual.
A genuine replacement 2.5uf capacitor was quoted at $120.00, however i purchased a equivalent from RS online for $14.30 + delivery. RS P/N 769-4267
Dishwasher working fine again.
E8
Temp too high on low temp washesNormally this will be the wash temperature thermistor or NTC that's faulty, please contact us if you need the thermistor with the model and serial number.
You can find more about your Samsung Washing Machine error codes at:
http://www.keepingupappliances.com/repair-help/appliance-repair/washing-machine-help/samsung-washing-machine-error-codes/
or
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3069-samsung-washing-machine-fault-codes.html
