Question about Hardware & Accessories
I have a Aqua Twin Outlet Two Dial Electronic Tap timer,it is set to turn on at 6.45 am how do l change this to PM operation
SOURCE: candy aqua 10t user settings
http://service.candy-domestic.co.uk/manuals/pdfs/AQUA%201000T.pdf
I have found you a user manual, to download and read, this should help you resolve your issue.
Posted on Jun 03, 2010
SOURCE: I have the Sentry -
Ginger,
It sounds like an older Intermatic timer
Does your timer look similar to this timer? EJ351
Here are the instructions for this timer:
Usually if the timer is still made, I can find a manual and piece together a solution... but I don't know this timer, and if it is malfunctioning ....
It may be time for a new timer > the EJ351 is inexpensive, simple to install (just 2 wires) and simple to program >>> one knob controls both AM-PM.
Posted on Oct 07, 2010
  • 3 Answers
SOURCE: can't find battery compartment on
Batteries located inside, accessible from behind unit. ie under round cover, just unscrew...
Posted on Dec 21, 2010
aquaman987
  • 927 Answers
SOURCE: I have lost my instructions
http://www.toro.com.au/product_files/314_GardenMate%20Automatic%20Tap%20Timer%20-%20Dual%20Outlet%20LCD%20(1017649).pdf
Here is a link to full instructions.
This should do it.
Gary
Posted on Jan 10, 2011
aquaman987
  • 927 Answers
SOURCE: I'm confused about the timer operation. If I
I believe it is possibility #2.
Gary
Posted on Aug 12, 2011
Noma 052-8870-6
OUTDOOR DIGITAL BLOCK HEATER TIMER 052-8835-2 Instructions Plug timer into grounded outlet
To Set the Current Time: Press the HOUR button as many times as necessary to advance the display the correct time. Note, the time can only be set in 30 minute intervals. The LED display will display the hour (1-12) and on the half hour a light will illuminate in the upper right corner, next to the number 30. To change from AM to PM toggle 24 times, a dot will illuminate in the lower right corner of the display next to the letters PM.
To Program the Timer: Press the PROGRAM button once, the letter P will flash. Press the HOUR button to set the ON time. Press the HOUR button to set the ON time. Press the PROGRAM button again, the letter E will flash. Press the HOUR button to set the OFF time. Press the PROGRAM button to exit program setting mode. Press the HOUR button to review the ON/OFF setting.
To Connect/Operate the Timer: Plug device in to the timer and turn the device on.
To Revise the ON/OFF Setting: Unplug the timer and plug it back in. Repeat the programming steps above.
To Override the Timer: Press the PROGRAM button if you want the device to turn on before the preset time, but note the device will turn off at the preset time. For example, if the preset ON/OFF period is 3 pm - 4 pm, users can manually press PROGRAM to turn the device on at 2 PM, the timer will keep running until the preset off time at 4 pm.
Suitable for use with outdoor appliances. Raintight when mounted vertically with the receptacle facing downward. Use a three-conductor GFCI protected outlet. Do not immerse in water. DO NOT EXCEED RATED CAPACITY. Not for permanent installation. Do not install or use this product for more than a 90-day period per year.
Dec 02, 2013 | Hardware & Accessories
Problem programming timer settings. Is it supposed to be random or continuous?
1) Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#50006
2) How to set analog timers by experimenting with features:
http://waterheatertimer.org/How-to-set-timers.html
3) 50001 timer is not random vacation timer like the 50003.
50000 series timers by Woods have 1 year limited warranty, and they are a new design released this year. However the analog timer design has been around for many years.
4) If timer is acting randomly, then
a) timer is defective,
b) the override switch is not fully positioned at 'timer on,'
c) segments are not lifted fully in position,
5) ... other more remote causes: outlet might not test 80% rated voltage?, outlet might have reversed polarity?
5) Try timer on different outlet with different light.
6) As the timer dial rotates, the segments push small lever, and the lever moves switch that turns lights on-off. I suppose if this lever was broken or switch was broken, then timer would act more randomly.
Dec 06, 2012 | Woods Hardware & Accessories
The auto mode isn't working on my zilla digital 24-7 power center, when on auto mode no lights come on?
Copy following link to identify timer:
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
Is this a new timer??? Or old timer that stopped working?
Replace battery.
Press reset button to clear all memory traces before programming.
Check programming for overlaps and mismatched day(s) of operation.
Test outlet for correct polarity and grounding using circuit analyzer.
Make sure light bulb is turned ON. Timers do not reach out and rotate on-off switch.
Make sure outlet has at least 80% rated voltage shown on load label. For example 115 volts x 80% = 92 volts
About your specific programming needs:
Zilla selects 12 o'clock as changeover time between am-pm.
So if you want 8:02 to 7:59 operation, then that is under the 12 hours, but it crosses the 12 o'clock am-pm changeover.
Workaround: Shorten your times to less than 12 hours just like you have done.
But set current time differently so 8-8 falls under either am or pm, but does not cross am-pm. The timer does not actually know what the current time is, so simply fudge by amount needed.
Nov 18, 2012 | RTO Zilla 24/7 Digital Timer Power Center
How do I operate the pins. I get the Current time and can set the on time but am confused about the off time because it seems like the off time ends up to be pm and I am turning it on in the am.
Open following link to see photos of pins and tabs:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Pins-tabs
Here's a generic instructions for plug-in timers.
Locate pins on dial: move 10 pins in a row. This will be for testing purpose.
Plug timer into outlet located on kitchen counter-top so you can see what is happening.
Turn lamp on. Plug lamp into timer.
Manually rotate dial clockwise and watch when lamp turns on-off.
This will tell you how to position the pins.
Most of these timers have a slide-switch.
Move the slide-switch one direction and then the other.
Manually rotate dial each time and see which way slide-switch should be positioned.
Set pins for on and off times.
Dark background is pm. Light background is am hours.
Final step is to set current time. Manually rotate dial until current time lines up with arrowhead located on inner dial.
As time passes, the dial rotates, and the pins click a lever that turns lamp on-and-off
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 10, 2011 | Woods 3C 24 Hour Indoor Mechanical Timer...
Got a brinks EZ- dial timer model42-1034B @ Walmart a few days ago can not seem to get it to work, Inst, seem so easy too. I read on some forum online someone thought the am/pm may be backwards to how it...
1) This Brinks timer is a bit lightweight for an appliance (unless for coffeemaker or tiny gerbil-feeding motor)
You might need 1/3 HP (horsepower) appliance timer like Woods 59201
http://waterheatertimer.org/Woods-timers-and-manuals.html#59201
http://www.amazon.com/Woods-59201-Appliance-Grounded-3-Prong/dp/B001Q9EFTQ
Intermatic HB113C is for heavier appliances
http://www.amazon.com/Intermatic-Hb113c/dp/B000GHKO6C
http://waterheatertimer.org/images/Intermatic-HB114C-plug-in-4.jpg
2) How to set the Brinks:
I will use lamp as example since you can easily test the timer using a lamp.
Turn lamp ON. Make sure bulb is good.
Leave lamp turned ON and plug lamp into timer.
Move slide switch one direction.
Plug timer into outlet.
Manually rotate timer dial clockwise and see if lamp turns on-off
Move slide switch other direction, and rotate dial clockwise again to see if lamp turns on-off.
Now you know which way switch has to be moved.
Push down trippers and rotate around dial until they line up with 1:00 on dark part of dial and 5:00 on dark part of dial. Dark is for pm hours.
Last step: Set current time: rotate dial clockwise until current time lines up with arrowhead located on inner dial
Dial rotates at time passes, trippers push lever that turns circuit on-off.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Jan 29, 2011 | Hampton Technologies Brinks Timer
How do I set a plug in timer GE 24 hour Model 15075? There are tiny switches for every hour and can be pushed towards the inner circle or pushed outward. And there is a turning arow near the center and a...
Following link has a close-up photo of on-off pins on GE 15075 timer
http://waterheatertimer.org/GE-timers-and-manuals.html#15075
Pins are located around timer dial
The pins divide 24-hour day into 1/2 hour segments
Pins are out for ON
Pins are inward for OFF
Notice that numbered dial is divided into dark and light areas ... the dark areas are PM, light areas AM.
For example you are connecting chicken coop lamp to this timer.
Turn lamp on and make sure bulb is working.
Set pins in and out as follows: all pins outward between 4:30 pm on light part of dial to 8:00 pm on dark part of dial. And then set all pins outward between 5:00am on dark part of dial to 7:00 am on light part of dial.
Move switch located on top to TIMER ON
Manually rotate timer dial clockwise to see lamp turn on and off.
Lastly, set current time: Manually rotate timer dial clockwise until current time lines up with arrowhead located on inner dial. So if current time is high noon, then rotate dial until 'sun' symbol located on light part of dial lines up with arrowhead.
As time passes, the timer dial rotates, and the pins click circuit on-off.
To override timer, move switch to outlet-on.
Jan 09, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
How do you set the timer? It stays on after it has been tripped "off"
15004 timer with 2-prong polarized outlet is carried by Amazon
1 reviewer said OFF pin broke soon after timer was in service.
http://www.amazon.com/review/R1Z9VUX53Y61C1
Jasco does not have 15004 manual posted yet,.
I looked yesterday, and will continue searching.
15004 timer operates by putting green and red trippers in place at times you want timer to turn on-off.
Motor rotates clock dial as time passes.
Plastic trippers located on outer edge of dial contact a lever.
Trippers flip lever back and forth.
On tripper flips lever one direction.
Off tripper flips lever other direction.
Lever closes and opens electrical contacts that turn lights on-and-off.
Since this $7.35 timer is made of plastic, and has trippers, it will break easily. Which is confirmed by Amazon review.
GE markets heavier duty timer that costs more.
http://www.amazon.com/dp/B002HEY300/?tag=picc-20
This type of timer has segments located around edge of dial.
When segments are down, lights are ON
Lever rides along segments until a segment is pulled up.
When segments are up, lever springs inward which opens electrical circuit and turns lights OFF.
This system is more reliable than trippers, and timer lasts longer.
But it's still made of plastic.
Woods markets similar 3-prong timer.
http://www.amazon.com/59366-Appliance-3-Prong-Outlet-Repeats/dp/B001D8VIKE
Twin pack Woods 2-prong polarized
http://www.amazon.com/59419-Appliance-2-Prong-Outlet-24-Hour/dp/B002Y1KZHQ
Woods 2 prong polarized
http://www.amazon.com/Woods-59200-Appliance-Settings-2-Prong/dp/B001Q9EFTG
GE twin pack
http://www.amazon.com/dp/B0015GKI96/?tag=picc-20
Dec 12, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
Hardware & Accessories Logo
257 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
