Question about Pool & Spa
I have a used solarus far infared 2 person sauna,yesterday the power went out for a few hours ,the unit was pluged in and it was near minus 15 celsuis ,the unit displaces an error code 01
The unit is getting power 110 vac 15amps,but canot set any ,tempurature ,or time into the controller
  • 116 Answers
SOURCE: Mitsubishi WS-65313 - Will not turn on
The most common failure are the two convergence integrated circuits part # 267P173010. The two pico fuses may be open as well, which come from the power supply and provide +24 volts and -24 volts.
Posted on Mar 05, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: error code 12
Error code 12 is a genaric "Flame Failure" code. I suspect that the flame is not hitting the flame sensor or that the sensor is bad. You will need to get to the sensor located on the far left hand side of the unit. If you have the owners manual, it's part #123. Remove it and clean it off. Make sure it is placed back in the heater properly aligned and all the way in. Then try and light it. If it does not stay lit, it may need to be replaced but check out the burner tray for debris not allowing the flame to travel all the way to the sensor. You will have to remove many parts to get to the burner assembly.
Posted on Jun 03, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: My display reads -SE-
-SE- error means you have a shorted keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 02, 2008
  • 9 Answers
SOURCE: Whirlpool Duet Front loader mdl WFW8300SW00 will not start
I had a variety of error codes show up on my duet, and I'm not sure but I seem to recall a 31, but the most constant was 02. I took off the front cover, pulled the white plug out from the unit, put a bucket under it, unscrewed it and drained it. It may be the MCU is having problems because the washer got plugged up.
Posted on Apr 24, 2009
  • 244 Answers
SOURCE: code C876 I un pluged the unit waited two minuits
You get a C8 and then a flashing code 76?
Posted on Nov 01, 2009
Replacement heating element for life smart 2 person sauna
usually in power control box in chrome tube
Oct 17, 2017 | Smart Pool & Spa
How do I get the back heaters to turn on, I would like to find a manual for my sauna
Natasha, honey, I don't know your make/model; but go to their web site and download it.
Oct 13, 2014 | Eacon Far-Infrared Sauna Cabin - 3 Person
The big infared panel does not work, what can i do?
be looking for fuses or connections .. does it have power??
Dec 20, 2013 | Dynamic Sauna 1-2 Person Far Infrared...
Sauna
I think you have the wrong category.
Apr 29, 2013 | Computers & Internet
I have problems with the power of mij sauna. were
Did you get an answer to your question. I am also looking for s126smd3 to buy.
Mar 11, 2011 | RTO 1 Person Ceramic Heater Far Infrared...
I have my GPS pluged in and the little red indacater light is on. but the unit will not turn on it has been stored for about 6 months. does it have to be pluged in for a few hours before i can use it...
hi buddyd56
press and hold the power button for up to 15 seconds...the 6000T 3000T and the 3050 all require you to hold the power button for up to 15 second if its in the off position or the battery is dead.. most all other magellan gps will start within 7 seconds if the battery is totally drain or its in the off position.
let me know if that doesnt wok, but it works if there
is no damage to the gps like a bad screen ect
good luck
bill
Nov 11, 2010 | Magellan RoadMate 6000T Bluetooth GPS...
Fir sauna used for 1 hour, appeared to overheat and blew circuit breaker - now blows circuit breaker every time its plugged in. checked wiring and all seems fine. any suggestions guy
Does the circuit breaker match the load? And the wires match the load? Is this on a GFT protected breaker?
You say all the wires check out, how about the heater, did you take it apart or at least the cover to see if there is a short?
Please let me know what you find.
Thanks for using FixYa.com
a
Oct 28, 2009 | RTO 1 Person Ceramic Heater Far Infrared...
Intermittent A/C outage
your climate control unit is bad you can get a used one from the salvage yard it should work fine
Aug 18, 2009 | 2001 Chrysler Sebring
No power in my Maxtor 3200 external HD
Maxtor hard drives have sometimes have problems. When you say it didn't work, can you here the drive spinning? Do you feel a G effect if up pick up the drive? Are any lights on? If all these are no then the unit is dead. Now all may not be lost. This drive may be able to be slaved to another and then accessed to remove your data. Do you have the capability of removing the drive from the case and slaving it to another CPU? If not then the unit needs to see a reputable repair person.
Apr 10, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Pool & Spa Logo
51 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
