Question about Radio Communications
N136 bluetooth moto) will charge light purple light comes on while plugged in but i disconnect it and i press the power button but it does not light up to show power on?
While the chargers connected it lights up but I take it off and n136 will not turn on ?
  • 7 Answers
SOURCE: Won't charge up...
I had the same issue. So what I did was get a small screwdriver, opened the A210 case removed the battery. You will notice orange tape (remove it) then attached to the battery is a small board (the defective part) . Cut away the board, then you will need to solder the wires back to the thin metal film leads. And voila it will now charge, make sure to never let it charge for more than 2 hours. Do this at your own risk. Of course this will void the warranty.
Posted on Feb 04, 2008
minteker
  • 52 Answers
SOURCE: Motorola HS850 N136 bluetooth won't go into discoverable mode. I press and hold the call button. The light turns blue for a second but then turns off. I am trying to get my cell phone to discover it.
open the boom (mic) right when it turns to solid blue!
http://www.motorola.com/consumer/v/index.jsp?vgnextoid=4507f7c0c1a0b010VgnVCM1000008206b00aRCRD&ps=y&pg=PG_TYP_00003&show=globalSupport&productID=e4e6e7af976c9010VgnVCM1000008206b00aRCRD
Posted on Sep 08, 2009
SOURCE: Tomtom not switching on
yes pressing the reset button and start while its connected on the computer will sort this problem....
Posted on Jun 11, 2010
SOURCE: bluetooth n136 does blue light flashing mean to
looking for parts motorla N136
Posted on Oct 09, 2010
archaeology
  • 662 Answers
SOURCE: My Duralast Gold Jump Starter does not take a
There is a battery inside which may need to be replaced. To check, run the compressor (it runs off
the battery) - if the compressor dies quickly, then the battery has failed to charge and would
need to be replaced. You may want to check your Warranty Management software (or
shoebox) to see if your Starter/Air Compressor is still under warranty - if so, replace it.
Duralast products are carried exclusively by AutoZone, Inc.
The Duralast web site: www.duralastparts.com is useless - it only shows automotive parts,
and I cannot find the product at www.autozone.com, so it seems that AutoZone fails to support this
product with replacement batteries or other replacement parts (or even an online Users manual).
Posted on Feb 21, 2011
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
My motorola n136 headset will not charge. This is my second headset with both doing the same thing. When pluged in to wall charger the blue light comes on but it is not charging. What am i doing wrong?
I dropped my 4-5 month old Motorola N136 bluetooth under my couch while activated. Took me a week to get it out, and now it will not take a charge. All I get is the red light blinking over and over when plugged into my charger. Any ideas? lotsofstufflv@gmail.com
Jan 03, 2011 | Motorola Mobility H270 Bluetooth Headset
Manual
use this site and put 220 in the search box - your explorer 220 is found and you can download the user guide http://www.plantronics.com/north_america/en_US/support/manuals.jsp;jsessionid=83D442E12D37E83038D66C83670075A9.delta#results
see page 14 for details of the lights
  • Powering on Blue flashes
  • Powering off Red appears and goes off.
  • Charging battery Red solid light.
  • Low battery Red flashes.
  • Pairing mode Blue/red flashes.
  • Missed call Purple flashes. Single press the call control button to cancel.
  • Ringing Purple flashes. Briefly press call control button to answer the call.
  • Press call control button for 2 seconds to reject the call.
Apr 10, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Im trying to sync my H700 bluetooth to my Sprint Palm phone.I have used code 0000 and 1111 and neither is working?
Depending on the phone... try and remove the current bluetooth device. Close the headset. Go to the phone and choose discover, or search. Open the headset and press and hold the big button. It should then turn purple and should be recognized.
Also make sure the battery on the headset is charged before doing this.
If this doesnt work: Start the search on the phone, Keep the boom of the mic closed when you press and hold the button on the h700. the light should turn purple. After this, open the boom
If it asks for a passkey, it will be 0000, four zeros. This is the default passkey for the Moto H700.
Jul 25, 2009 | Motorola Mobility H700 Wireless Headset
May 06, 2009 | Motorola Mobility HS850 Consumer Headset
How to pair moto 700 with samsung delve
moto -700s the vain of my existance. my experiance with this troublesome unit is with the boom mike closed hold call button down till light turns purple, quickly pull mike down and while still purple ( thats discovery mode) pair it with phone and if it askes for a pass key its 0000 ,and 1234 is backup key code. hope you only have 1 of these. i have 7. but they sure are pretty huh? good luck
Jan 26, 2009 | Samsung Wireless Headset for...
Lost N136 Manual
I have an N136 which turns out to be an HS850 (with folding boom}. This model requires the boom to be folded while the answer button is held down, When the light comes on the boom must be extended before the light goes out. The light will now stay on and the phone should find your headset.
Jul 31, 2008 | Motorola Mobility HS850 Consumer Headset
Power won't come on
I am having similar issues. Before you OPEN the boom, press and hold the CALL button in the middle and ensure your Bluetooth is paired/synced with your cell phone.
Press and HOLD about 5 seconds until the PURPLE light illuminates. Then flip it open immediately and begin the pairing process.
My problem is that the purple light won't illuminate at all...
good luck
Jul 01, 2008 | Motorola Mobility H700 Wireless Headset
Radio Communications Logo
62 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
