Question about Dishwashers
Getting a d06 motor overload error message on a BLANCO Dishwasher BFD9X However the motor is working perfectly to pump in and to expel water but is going to error when starting the first wash cycle.
2 Suggested Answers
SOURCE: Blanco dishwasher error d06 faulty motor.
I have a Blanco BFD10X Dishwasher which had the same D06 error, being a Electrician i investigated the fault which Blanco report as motor over current. After testing the motor, i tested the motor Run capacitor and found it to be faulty, these capacitors are common to failure and will cause the pump to draw more current than usual.
A genuine replacement 2.5uf capacitor was quoted at $120.00, however i purchased a equivalent from RS online for $14.30 + delivery. RS P/N 769-4267
Dishwasher working fine again.
Posted on Feb 12, 2015
Reseting error code on blanco dishwasher
My Blanco BSD9XP displayed the same d13 error. I fixed the problem by replacing the thermistor (Part No. 32X2023). The d13 error remained after the fix but disappeared after I ran the dishwasher through the Test Program. Start the Test Program by holding in the Delayed Start button (has a clock image on it) and simultaneously pressing the Start button ( diamond / C) five times. See the attached description of the Test Prgram to understand how it operates. The second page sets out test parameters for the various elements of the dishwasher.
Nov 29, 2013 | Dishwashers
Nov 15, 2011 | Dishwashers
Hi, i have an LG dishwasher and am getting an e1 error ... it seems to go through the first wash ok, the soap gets used, the water drains away, but then thats it, ding ding ding...ive cleared the bottom,...
e1 error is failed wash motor it sounds like when it goes to do the second wash its overloading the only other thing it could be is the the inlet valve check to see if the water is coming in before it dies. p.s. as a former service agent for lg the general procedure when we get to an e1 error we just order a wash motor for it & replace it & 90% of the time it works but the other 10% is cocroaches got to the computer or the pump or the inlet valve are faulty & are causing it to overload.
Jan 14, 2011 | Dishwashers
Blanco Dishwaser very noisy pump motor
the only thing you can do is take it to the place where they repair motors. like where they fix windings ect . im in ny so you have to check your area for one in your neighborhood. let me know if this washelpful to you
Feb 24, 2010 | Maytag MDBH965AWS Stainless Steel Built-in...
Dishwasher tripped our main circuit breaker.
It may be that your water pump is leaking on to the motor...
Dec 09, 2009 | KitchenAid KUDR01TJ Dishwasher
Water Won't drain fro the dishwasher model Blanco bfdw650s
If you "Lower" the hose to the bucket and it "drains" you are just using gravity to remove the water. The pump may be helping a little but if you raise the hose up and the water stops coming out, it's a good indication that the pump is bad. Unless the place you are attaching the hose to is plugged up, you need a new pump or a new impellor. Since the motor is good, try to get a replacement impellor, that the thing that moves the water. One other thing, you did say how well it washes the dishes? If the impellor is bad, it probably doesn't.
Sep 08, 2009 | Frigidaire 24 in. FDB126RB Built-in...
Getting error message E1 what does this mean
E1 leakage error
The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
Replace the connections of Hose. Check the point of damages and repair or replace the related parts.
Replace the Impeller of the Washing Pump.
Sep 03, 2009 | LG LDF6810ST Stainless Steel Built-in...
Our LG LDF7920st dishwasher (6 months old)makes a whistling noise
Hey, consider the float assembly!
We bought this dishwasher and ran it for the last 1 1/2 months and it made a grinding and whistling sound from day one (it's supposed to be nearly silent in its operation). Turns out the drain pump was cutting in while the machine was still filling, thereby emptying the wash tub of any water. Then, when the cycle proceeded to wash, the dumb thing had no water and made a horrible noise. So I had to pitch in at least 2-3 litres of hot water, and then it worked quietly! Had to do this every time there was new water intake.
After working with the repairmen - four visits later, we isolated the float assembly as the problem and they set about replacing the part. Turns out the two parts were markedly different. LG HAD INSTALLED an older model float assembly at the factory and it was the problem. The replacement part was the correct float assembly and things worked perfectly after that - thank goodness. No more babysitting the dishwasher.
Don't let anyone tell you the motor assembly needs replacement. I have seen that cop-out 'fix' all over the web. But use deductive reasoning to find out where the problem is in the cycle, and explore this option first - it's a quicker and cheaper fix than replacing the whole motor assembly.
'Mr. Float' as he is now called works like this:
-expels any residual water in the tub from the last wash
-intakes water for the wash or rinse
-whirs 2-3 times prepping for the cycle
-begins to wash, quietly
-expels at the end of the wash or rinse.
He used to:
-expel residual water
-intake new water for wash or rinse
---drain pump would cut in WHILE still filling
-machine would whir once, realize it didn't have enough water
-perform a brief top-up intake shot
-begin to wash and whistle and GRIND (this is where I would have to add the water)
-expels water from wash or rinse, and start all over again.
It's a good dishwasher and it will work, but the right model parts have to be in place!
Jun 27, 2009 | LG Dishwashers
LG LDF6810 Dishwasher Starts filling with water then pumps water
Because you are not getting an error message, I agree that the controller card is malfunctioning. Almost everthing else would triger an error.
Recommend replacing the controller card.
Feb 19, 2009 | LG LDF6810 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
