My dvr is not turn on - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 75,311 Answers
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Dec 08, 2016
Pacom pdrh-420 4ch digital video recorder forgot password how to reset again
To reset the unit, you will need a straightened paperclip:
  1. Turn the DVR off.
  2. Poke the straightened paperclip in the unlabeled hole to the right of the Alarm Output connector, and turn the DVR on.
  3. Hold the paperclip in place until the DVR turns on and live monitoring screen appears.
  4. Remove the paperclip. All of the DVR's settings are now at the original settings it had when it left the factory. There is no default password.
Sep 11, 2013 | Cameras
Tip
DISH Solo DVR VIP612 Change Limited Mode
Changing DISH Solo DVR VIP612 Limited Mode
What is DISH Solo DVR VIP 612 Limited Mode?
To turn Limited Mode on or off, follow these steps:
  1. Press and hold the correct mode button (for example, TV) until all of the mode buttons light up.
  2. Release the mode button.
  3. Press PAGE UP to turn Limited Mode on, or PAGE DOWN to turn Limited Mode off.
  4. Press POUND (#).
Note: Limited Mode is not used with amplifiers (AUX mode).
I hope that helps.
________________________________________________________________
DISH Solo DVR VIP612 Manual Download
DISH Solo DVR VIP612 Quick Reference Download
DISH Solo DVR VIP612 Remote Code Scan
DISH Solo DVR VIP612 Program TV VCR Remote Codes
DISH Solo DVR VIP612 Program AUX (Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier Control
DISH Solo DVR VIP612 What Is Limited Mode
on Jul 05, 2010 | Televison & Video
Tip
  4. Press POUND (#).
I hope that helps.
I have a toshiba ct 90159 - I need the code for a coby dvr model dvd 627
u should be able to
turn the dvr on
press and hold the setup until the light stays on (remote)
hit the dvr botton on the remote the light should blind once
hold the remote towards the dvr keep hitting the on and off button on the remote until the dvr turns off can take up to 300 times once the dvr turns off press the select button and that should fixya up
Mar 31, 2012 | Toshiba CT-90159 Remote Control
The list button doesn't work and I am unable to
turn off your cable box
turn off the dvr
disconnect cable box from wall outlet
disconnect dvr from wall outlet
unplug e-sata cable from dvr
replug e-sata cable back in to dvr
plug dvr into wall outlet
turn on dvr
plug in cable box to wall outlet
turn on cable box
wait for cable box to go completely thru startup procedure
...then try your list button again.
Mar 01, 2010 | Televison & Video
Tip
DISH VIP612 Remote Code Scan
Would you like to autoscan program the Universal Remote that came with your Dish Solo DVR VIP 612 to control your TV, VCR, receiver, or stereo?
To auto-program device codes into your Dish Solo DVR VIP 612 Universal Remote by searching for the code, follow these steps:
  1. Turn the device you would like to control on.
  2. Press and hold the mode (TV, VCR, or AUX) button until all the other buttons light up, and then let go. The mode button will flash.
  3. FOR AUX MODE ONLY - Press 0 for a 2nd TV, 1 for a 2nd VCR, or 2 for a receiver, amplifier or tuner. Then press the STAR (*) button.
  4. Press POWER to put your remote into scan mode.
  5. Press the UP or DOWN ARROW repeatedly until your device turns off. Each arrow press tries the next code your remote knows for your selected device type. When your device turns off, you have found a compatible code. When the remote runs out of codes to try, the device will flash rapidly eight times.
  6. Press POUND (#). The mode button will flash three times as it stores the found code.
  7. Turn the device back on and try some of the other buttons to make sure they work. If all functions work, your remote has been successfully programmed.
  8. If the code didn't work, repeat this scanning procedure to find a more compatible code. When your device turns off during your next scan, press the arrow key again until the device turns back on to signify you have found the next compatible code.
Your device's remote control codes for your TV, VCR, or receiver are now programmed into your DISH Solo DVR ViP 612 remote control.
(The other way to program your DISH Solo DVR ViP 612 remote control is to look at the tables in back of the user manual, and enter the code directly.)
I hope that helps.
Tip
I hope that helps.
on Jul 05, 2010 | DISH Network ViP 612
Tip
DISH Solo DVR VIP612 Program TV or VCR Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR 612 to control your primary TV or a VCR? (Instructions to setup a receiver, tuner, stereo, second TV or second VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a primary TV or a VCR:
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR 612 User Manual.
  3. Press and hold the mode button (TV or VCR) until all the other buttons light up, and then let go. The mode button will flash.
  4. Enter one of the three-digit codes from the tables in the manual.
  5. If you want to program Limited Mode, press 1. If not, skip to the next step. (You can add or remove Limited Mode later.)
  6. Press POUND (#). The mode button will flash three times.
  7. Press POWER to turn off the device. If the device does not turn off, skip to step 9.
  8. Turn the device back on and try some of the other buttons to make sure they work. If the code works, stop here.
  9. If the code didn't work, repeat steps 3 through 8 with the next device code from the tables in the manual.
Your device control codes for your TV or VCR are now programmed into your DISH Solo DVR VIP 612.
Help for programing a tuner, receiver, 2nd VCR, or 2nd TV using the AUX mode button can be found here.
I hope that helps.
Tip
  4. Press POUND (#).
I hope that helps.
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
