COREL X6 error message REQUIRED RESOURCE NOT AVAILABLE ... can not open files. reloaded X6 and all five updates and still got error.
5 Suggested Answers
20YrsCompExp
  • 227 Answers
SOURCE: Corel draw files do not open
Try launching CorelDraw FIRST then open the file from the CTRL+O command in Corel. Let me know if this works!!!
Posted on Mar 28, 2009
  • 128 Answers
SOURCE: When trying to open Corel X5 with or without a new
Try reinstalling the upgrade over the existing one to see if something didnt copy the thje corel system folder. Also when installing does the upgrade ask you if you want to install fonts. if so go ahead and install them. dont assume the system will automatically do it for you. Also if this fails go into help and see if add on are available to download from corel.
Posted on Jan 19, 2011
nonontech
  • 4737 Answers
SOURCE: Corel Graphics Suite X3 will
This problem may start when a different workspace is selected or maybe whenever (by mistake) a new workspace has been created. You will need to load the default workspace. Press and hold down F8 on the keyboard once the Corel Draw is loading to open up. This will prompt you to select the default workspace. Select it and the program should work fine.
Let me know if you need further help..
Good Luck..
Thanks for using FixYa.
Posted on Apr 13, 2011
zlatan24
  • 414 Answers
SOURCE: I can't open my corel draw file. When I open
Such message can denotes coreldraw file corruption Make use next tool http://www.coreldraw.repairtoolbox.com which will assist you
Posted on Jun 23, 2012
I need to restore the file to CorelDraw X8.
Corel Draw creates a backup file of your drawings in case of unexpected software crashes. Crashes can occur as a result of a too many programs running at once, or a computer overheating. The backup file has an extension and is created to help you cdr corel draw files repair or lost files.
- Click "Start" located at the bottom of the screen and then click "Computer." Windows Explorer launches.
- Navigate to the C:/Program Files/Corel/Programs/Draw folder.
- Double-click the file that matches the file name you are trying to recover. Your file launches in Corel Draw.
- Click "File" from the top menu and then select "Save As." Select "Corel Draw" in the "File Type" field and click "Save." Corel Draw cdr repair
Apr 24, 2018 | Corel Computers & Internet
How do I repair a corrupted CDR file?
try the following:
- rename the file to ".zip "
- open the zip-file with Winzip or WinRar (these programs has a repair-function for zip)
- try to repair the file
- then extract the riffdata.cdr from content-folder of zip-file and open this file in CorelDRAW
These steps work for me.
Or try use CorelDRAW Repair Kit. CorelDRAW file repair software for recovery of the contents of damaged CDR files. Program helps to repair corrupted Corel Draw project files.
Corel Draw repair file
Jul 18, 2015 | CorelDRAW Graphics Suite X4 for PC...
Corel DRAW X6 problems
I presume you mean CorelDRAW Graphics Suite X6 and NOT technical Suite?
If nothing seems to work I would then do as follows.
1.Uninstall CorelDRAW X6 via Control Panel
2.After uninstalling X6 in the Control Panel - Go BACK to the Control Panel and uninstall "Corel Graphics - Windows Shell Extension".
3.Then go to Documents > Corel folder > Uninstall/Delete anything that says CorelDRAW X6
4.You can also go to C: > Program > Corel and delete anythign that says CorelDRAW X6
5.Repeat step 4, but choose folder called Programx86, and delete anything that says CorelDRAW X6
6.You should now have uninstalled everything that useally could disturb when you re-install from scratch.
7.NOW put in your DVD again with CorelDRAW Graphics Suite X6 - and INSTALL from Scratch.
8.You SHOULD now be able to run your CorelDRAW X6.
9.And NOW you should go online to www.corel.com and download and install Update/service pack and Hotfix for CorelADRAW Graphics Suite X6
10.It should in all normal situations work just fine on your PC with any Windows 7 version as well as any Windows 8 and 8.1 version.
11.Try to use a program to recover and view CDR files. For example, you can try this CDR Open File Tool http://www.cdr.openfiletool.com/
12.Also recommend to come to this forum. Many have useful information on the topic. http://www.filerepairforum.com/forum/cad-tools/cad-tools-aa/coreldraw/479-problems-with-cdr-files
Good luck and hope this helps!
Nov 12, 2014 | Corel DRAW Graphics Suite X5
What is opclib.dll ?
it is a library file that your program needs in order to operate, that is not in your computer library files
there are a few fixes for that
1, check the program you are using or installing for the requirements, not just the windows version, but also the service pack and windows programs that must be installed first and make all necessary updates first
2, download the .dll file from the internet to your dll folder in windows and try it again, most of the time when you do that you'll find there are more files you are missing, so updating is usually better
3, obtain a different or newer version of your program
Jun 18, 2014 | Corel WordPerfect Office X6 Professional -...
How do i reload my OS where can i get it
  1. Connect your smartphone to your computer.
  2. Open the BlackBerry Desktop Software.
  3. In the BlackBerry Desktop Software, click Update.
  4. To download the most recent version of your BlackBerry Device Software, click Get update.
  5. Do any of the following:
    • To keep a backup file of your smartphone data and settings, select the Back up your device data checkbox. This backup file is restored to your smartphone after the software reload finishes. If you don't back up your data, your smartphone data, settings, and email messages are deleted from your smartphone when you reload the software.
    • To encrypt your backup data, click Encrypt backup file.
    • If you want to receive an email when an updated version of the BlackBerry Device Software is available, select the Email me when new versions are available checkbox.
  6. Click Install update.
Jan 26, 2014 | RIM Blackberry Curve 3G 9330 9300 8520...
Activation Code for Corel Draw X6
You will have to refer this to Corel for resolution
May 08, 2013 | CorelDRAW Graphics Suite v.X6 - Complete...
WordPerfect Files Do Not Open with Double Click
Hello, Robindayglen -
Try using a right click on the file name or icon. Then, if a pop-up window displays, choose Open, with a left click.
Best wishes.
Feb 17, 2018 | Corel Computers & Internet
When trying to open Corel X5 with or without a new document the following message appears "a required resource was unavailable". I can start a new document again but I have not acces to fonts, I...
Jan 19, 2011 | Corel DRAW Graphics Suite X5
Computers & Internet Logo
157 people viewed this question
David Payne
David Payne
