Im using an I7 Processor with 16 gigs of ram and a 3 tb 7200 rpm hd with cakewalk sonar 8 producer
SOURCE: HD Audio Hardware Problem
just try to go in the bios and load default setting ,,,if issue persist then update the bios
I have a Deskop Board DG965RY. Sound device is problem the error is "device object not present" & "you are attempting to insall"
SOURCE: Sonar 4 Producer Edition Vista drivers
I looked all over the Cakewalk website and could find no info pertaining to using sonar 4 with Vista, however I did find a link to e-mail there tech support it is free and they claim a 48 hour responce time here is the link http://www.cakewalk.com/Support/SONAR/SR4.asp
I woll tell you this I am running Vista and have found there are some programs that just wont work with Vista, this is not nessaseraly true for you but just be prepared in case they tell you to upgrade to version 7
Hope this helps
Carl
SOURCE: Sonar Producer 6 - Audio/midi devices/controller-surfaces..Which settings??
o always run at 0 on play back recording -3 with drums use anlog cables then select anlog 48000 24 bit if u can if its digital cable might use 96000 bit rate ok spdif watch it close on digital for digital clips never go in red keep steady balence cheak your sorse tape how loud is that adjust your stuff to sound good at peaks never hit red in digital mode does this help sum
SOURCE: My computer comes up with a black screen
try and start in safe mode
then see if your driver is correct in my computer property hardware devices
