Question about GE Dishwashers
GE dishwasher model gdf570ssf0ss will not fill.
I changed the water inlet valve still does not fill. Can't find a float cut off on this model. the diagram in user's manual shows a flood sensor. Any help would be appreciated.
  • 50 Answers
Check to make sure there isn't something holding the flood switch up. It is a hat shaped tube in the bottom of the dishwasher that can be blocked up by soap an kept in the upright position. If it moves freely check to make sure your water valve has stopped working or has a block screen.
Posted on Dec 08, 2016
  • Call Bill
    Call Bill Dec 08, 2016
    thank you i couldn't find the float. merry Christmas
Bosch S9G1B dishwasher doesn't fill with water
The valve will not energize if the float is up at the limit. Sometimes a bit of soapscum can leave the float in the up position. When this happens no water is allowed into the chamber. Move the float up and down and clean the travel using a bleach spray.
Jan 18, 2015 | Bosch Dishwashers
No water in dishwasher
I would suggest to check the information by clicking here if you are planning to DIY.
May 20, 2008 | Dishwashers
Wan't take on water after first rinse
see this steps and fix it. God bless you
Water Inlet Valve
The dishwasher has an electrical water valve called a water inlet valve. If the dishwasher won't fill with water, the water inlet valve might be defective. These valves are not repairable and will have to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Float
The float assembly is normally inside the dishwasher near the door on the floor of the dishwasher. If something gets stuck underneath it and holds the float assembly up, the dishwasher won't fill with water. If the float assembly moves freely up and down, the float switch might be defective.
Float Switch
The float switch is actuated by the float assembly. It is a protection device designed to prevent the dishwasher from overfilling. If the dishwasher won't fill with water, it may be because this float switch is defective or stuck.
Water Supply Problem
The dishwasher is connected to the hot water supply from the house. Check to be sure the household water supply valve is turned on. Over time, calcium deposits can build up in the water supply valve or in the small filter screen inside the water inlet valve. The water supply line may need to be removed from the water inlet valve of the dishwasher, then run some water into a bucket to see if there is enough pressure. Be certain to turn off the water before working on the water line.
Jul 30, 2013 | Whirlpool 24 in. DU1055XTPS Stainless...
Mine DU1055XTSS3 is not taking on water after initial rinse.
test this steps and fix it. GOd bless you
Water Inlet Valve
Float
Float Switch
Jul 30, 2013 | Dishwashers
Kitchenaid kuddo1dppa
test this steps and fix it. God bless you
Water Inlet Valve
Float
Float Switch
Jul 22, 2013 | Dishwashers
Does not fill with water.
follow this steps and fix it. God bless you
Water Inlet Valve
Float
Float Switch
Jul 08, 2013 | Thermador 24 in. DWHD64CS Stainless Steel...
Dishwasher will not fill have changed the inlet valve but still not filling.
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Jul 20, 2011 | Bosch Dishwashers
Dishwasher panel displaying fe when turned on
Hi and welcome to FixYa, I am Kelly.
FE is a fill error. This can be cause by a problem with the water supply, the inlet water valve, the Float sensor or the Flood sensor. Check the float sensor usually in the front left or center positon of the tub. It should lift and drop for a distanct of about 3/8 inch. If they get coated with food stuffs on the stem they stick. The flood sensor is usually mid point right or left side of the lower tub. Same thing here... if they get stuck in the UP position they waill not allow water to be introduced into the tub. Since you did not include a model number... I have to include all types of sensors. Some float and flood sensors are finger like and have a small slot in them to sense water level. The small slot clogs and they no longer sense properly or hold water when the tub is empty giving erronous inputs. Wipe off the finger slots.
IF the Float and flood sensors are ok the next step is to first POWER off dishwaher circuit. Then turn off the water supply and disconnect the water line at the inlet water valve to inspect for debris. Also you should briefly test the water supply line by placing a rag over the input line and turning on the water while catching the water in a short sided baking dish. (
If there is not a problem with water supply or debris then the final step is to measure continuity of the inlet water valve solenoid. No continuity = open coil and will require the inlet water valve to be replaced.
Since you did not include a model number this is a very generic response.
Thanks for choosing FixYa,
Kelly
May 25, 2011 | LG Dishwashers
My Kenmore Portable Dishwasher model number 665.17769K600 will not fill with water, I have to manually fill with water and it will then work. What could be causing this?
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly.
Hope this helps... Please post back for any further assistance.
Daniel
Mar 24, 2011 | Kenmore Dishwashers
No water
If you want specific information we need a model number please to better help you. Otherwise we can only speak in generic terms. No water is usually caused by either a failed water inlet valve .. a clogged water supply line that has plumbing debris in it from the hot water hater or a stuck float switch.
The plastic float switch assembly inside the dishwasher that if there is food debris on the stem it will hold the float in the UP position and the dishwasher will not fill at all. Some models also have a flood switch. The switches work by being lifted up as a result of the water level. Make sure the switches function by gently lifting them up and down. If they stick up it will cut off power to the inlet water valve solenoid. Some float switches have an outer cover that must be removed to gain access to the actual dome shaped float.
Kelly
Feb 27, 2011 | Dishwashers
Dishwashers Logo
124 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
