Powered Acoustimass 9 Speaker System Manual
I NEED Powered Acoustimass 9 Speaker System Manual OR HOW TO POWER ON WITH LIFE STYLE 20 MEDIA CENTER
  • 51 Answers
SOURCE: Bose Powered Acoustimass 30 Speaker System
The master on/off switch will usually be on the back (or maybe even the bottom) of the largest component, which contains the power and control circuits.
Posted on Dec 28, 2008
SOURCE: Need longer ribbon speaker wire for Acoustimass 16
I have the same question. I just called Bose at 1-877-210-3782 (prompt 6) and they have two solutions:
1. 20 foot Input extension - $25
2. Input adaptor - $12 (you can run your own speaker cable to the input adaptor)
Posted on May 08, 2009
  • 19 Answers
SOURCE: Can I connect my Bose Acoustimass 5 - Series II to Bravia unit?
Yes, there should be no issues using your Bose speakers with your Sony receiver. Sony has a "hookup guide" to help here -
http://esupport.sony.com/US/perl/model-home.pl?XID=M:products:crmportal&LOC=3&mdl=DAVHDX265
Please rate my answer, thanks.
Posted on Jun 18, 2009
  • 50 Answers
SOURCE: i want to add the VCS-10 center speaker to an existing bose syst
the vcs is designed to plug straight into the reciever not the acoustimass.
Posted on Aug 09, 2009
dunnbiker
  • 8546 Answers
SOURCE: Is the subwoofer from the Bose acoustimass 10
The entire speaker system is passive. That is, it requires amplification for each channel.
From the manual: "Compatible with A/V receivers rated from 10 to 200 watts per front channel and 10 to 100 watts per rear channel; rated from 4 to 8 ohms".
Posted on Dec 09, 2010
Bose Acoustimass Subwoofer not working; front/center are working
Ok, have you tryed to unplug all of the wires from the sub, including the power wire from the wall. Install of the speaker wires to the sub, and plug back in the sub. Also what are the numbers on the speakers and the sub.
Jun 10, 2007 | Onkyo TX-SV525 Receiver
Please help i have matsui dav50 home cinema dvd player and cannt change it from 2.1 to 5.1
i have Bose - Acoustimass® 20 Powered Speaker System without the lifestyle, can i connect a pre amplify to it
Oct 31, 2009 | Bose Acoustimass 20 System
How do I connect my Acoustimass® 5 Series III Stereo Speaker System to my Onkyo SR506 av receiver?
Well, first of all this speaker system is designed to give you a subwoofer where you do not have a sub-woofer output on your receiver/amp. However, that is not the case with the Onkyo. The way I would set it up (only because of the speakers you have) according to the Acoustimass Manual. You take the left and Right "Speaker" outputs to the Left and Right input on the Acoustimass and the speakers crossover does the rest. The Onkyo is designed to have a powered subwoofer so in this format you would just tell the receiver to turn off the sub channel which would tell the Onkyo to send the low end to LR. That should do it.
Oct 28, 2009 | Bose Acoustimass 5 III System
Can not get any sound to work on my bose 28 life style system first time using it. and got a new tv
If you have no sound from any source (CDs and radio included) then check the Audio Input cable at the back of the media center. Make sure it's plugged into the top portion of the 'speakers' section into where it says "main" and not "BoseLink"
If this is fully connected, but still no audio- check to make sure your Acoustimass module (subwoofer on the floor) is plugged into a working power outlet. If that fails, try unplugging both power cords for the system for about 30 seconds.
May 31, 2009 | Bose Lifestyle 28 System
Apr 10, 2009 | Bose Acoustimass 16 System
Nov 28, 2008 | Bose Acoustimass 15 System
Do I have to have a powered bass module to make the cubes work?
Your Acoustimass 5 is a powered sub with powered surround speakers. If you are not getting sound output, the internal fuse may be open and you will have to replace it. Bose used a heavy multiple output cable terminated in a miniature DIN plug to connect speakers. You may be able to find one on eBay.
Apr 17, 2017 | Bose Acoustimass 6 III System
Bose 321
3 audio inputs (3 analog, 3 coaxial digital, 1 optical digital)
2 video pass-through inputs (composite and S-video)
Video output for TV (composite, S-video, and component)
Media center • 3 1/4"H x 13 3/4"W x 10"D • (8.3 x 34.9 x 25.4 cm) • 6.7 lbs. (3 kg)
Remote control • 1 1/8"H x 2 1/2"W x 9"D • (3 x 6.5 x 22.9 cm)
Gemstone speakers • 2 1/2"H x 5 1/2"W x 4 1/8"D • (6.4 x 14 x 10.5 cm) • 1 lb. (.45 kg) each
Acoustimass module • 14 1/2"H x 8 3/4"W x 19 1/8"D • (36.7 x 22.2 x 48.5 cm) • 23.3 lbs. (10.6 kg)
Total shipping weight • 44 lbs. (20 kg)
gray_hr.gif What's In the Box • Acoustimass® module • Media center • 2 speakers • 3·2·1 universal remote control • Setup DVD • Antenna stand • Stereo cable • Video cable • Speaker cable • Module cable • Rubber feet for Acoustimass® module • Rubber feet for speakers • Batteries • AM antenna • FM antenna • 120V power cord • Quick setup guidepls rate !!!!!!
May 29, 2008 | Bose 321GS Series II System
Acoustimass 9
Acoustimass 10 IV cable
Feb 29, 2008 | Bose Acoustimass 15 System
146 people viewed this question
 Grubhead
Grubhead
