Question about Canon Office Equipment & Supplies
Hello I need exposure lamp for canon pc 941 how much and how many time my zip code is 00949 please send priority mail thanks santos
  • 8617 Answers
SOURCE: Directions for lamp time reset
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Posted on Jun 17, 2008
  • 17 Answers
SOURCE: Minolta EP2030 exposure lamp timing wrong
"Exposure lamp timing wrong" simply means that the lamp is coming on at a time when it should not be coming on. It is not a problem with the lamp itself. It is most likely a power supply problem. There is probably no simple fix.
Just because Konica Minolta no longer will sell you an agreement does not mean that you cannot get the copier serviced. There are plenty of independent repair agencies that would love to service your copier, unless you are in a really remote location.
The EP2030 was one of the last Minolta analog copiers, and parts are still readily available.
Posted on Nov 14, 2008
Angry Milton
  • 40 Answers
SOURCE: konica 3135 error code f 43 ( exposure lamp)
The exposure lamp is located in the scanning area beneath the glass. If you choose to do it yourself you can purchase a lamp here
You can get the manual here
Be sure to follow the steps closely it is easy to do more damage than good in that area if you try to wing it. Good Luck
Posted on Apr 20, 2009
SOURCE: hello. please send me unlock code Adobe reader LE.
TRY 12345 OR call the customer care number by telling ur sim number (written in sim) and mobile number to the officer.we can get the PUK code..
Posted on Jul 28, 2010
  • 1326 Answers
SOURCE: hi i have a canon np2020
There are a few possible problems? One is that the scanning lamp is blown or the thermal fuse for the lamp is blown. The question is will the scanning lamp turn "ON" and move and then codes out. If that is the case and most likely the power cable for the scanner lamp is cracked and it is shorting out to the frame of the copier. If you have a meter to measure resistance. You need to turn the copier off & unplug it & take the copy board glass off & put the meter on the ends of the lamp, to read it's resistance. If you have No resistance then the lamp is blown. You will need to replace it. Keep in mind you are working on a copier at least 15 - 20 years old, odds are the power cable is cracked. Good Luck.. If that is so, it is not a easy part to replace or find
Posted on Aug 14, 2010
You have to find and order it for yourself. We just answer questions voluntarily, we don't provide service! These folks should be able to help you.
Canon PC941 Supplies and Parts All
Dec 07, 2016 | Canon Office Equipment & Supplies
Error code h2
Pre-exposure lamp
Does the pre-exposure lamp turn on during copying operation?
Check the wiring from the DC driver PCB to the pre-exposure lamp; if normal, replace the pre-exposure lamp.
Nov 16, 2013 | Canon imageRUNNER 6020 Copier
Zip code of dubai
Dubai doesn't have a zip code system. UAE relies on Post Office Boxes A PO Box number will suffice if you need to send a mail/parcel to Dubai. If you are sending something really important, you can send it through registered mail or FEDEX and similar agents. That way you can track your parcel/mail whereabouts.
So if asked for a zip code for any forms online, you would use this, plus Dubai as the city. There is no home mail system as such, simply po boxes that you must collect your mail from. if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Jan 30, 2011 | Kitchen Ranges
Sir, my canon ir 400 machine shows an error code 803. how can i solve the my problem. give detailed information to my mail. thanking u.
the code 803is for faulty exposure lamp or fault in composite power supply(the power supply to exposure lamp is not sufficiant to operate the lamp).to remove exposure lamp, remove copyboard glass,remove back cover ,slide scanner in the line of rear exahaust fan at the right side of scanner, remove rear exahaust fan, remove lamp holder(one screw).slide out lamp on the rear side replace new one and reverse the whole process.
Jan 27, 2011 | Canon imageRUNNER 400S Copier
My canon d320coping black no image. what is the
Hello sir; It seems like the exposure lamp burn out, lift up the cover and hit print , if it scan with on light means the exposure lamp out, replace it.
Dec 05, 2009 | Canon PC-920 Black and White Copier
Canon PC 941 dark copies. has new toner cartridge. dark and light control wont work. what is the problem ?
Clean the optical section,mirrors,lamps.Open the front cover and you see one adjust switch or rotative button placed in the center under dispalys.For light/dark rotate to adjust.
Nov 20, 2009 | Canon PC-941 Copier
What does error code 2E 20 mean when the copier just cuts off with the paper halfway through.
Hello dmdymer... The e2-20 error code usually indicates an exposure lamp or a composite power board.... It is most commonly the exposure lamp and as a genuine article will set you back less than $100AU... You will have to get a repair done on it I am sorry to say!
All the best...
For further help please contact me at
Oct 24, 2009 | Canon PC-940 Black and White Copier
Intex offers two drivers for this line of webcam, one of the two should work for you :)
Feb 17, 2009 | Computers & Internet
Canon 745
hello sir
machine error code zero is the first digit when its blinking,there is another # to show? must be 2 digit,but base on your explanation you must change the exposure lamp or scanning lamp
Dec 12, 2008 | Canon PC-940 Black and White Copier
32 people viewed this question
old marine
old marine
