Pc input grayed out - why? - Televison & Video
Sharp aquos 60" TV has sound but only a gray picture. Was fine then, went gray. Help?
Do you see the menu when you press the menu button. If the menu looks ok, then you may have a problem with one of your inputs. Try a different input port and change the TV to that input. Also try a new cable and try a DVD input or other video source to help isolate the problem.
Feb 12, 2015 | Sharp Televison & Video
Gray picture for all RGB inputs
Check the connections. If connections to RGB has conected wrong, this type of fault will occur. Follow the color codes of wire ends both at tV and DVD.
May 27, 2012 | Samsung DynaFlat TX-P3064W 30" TV
Why is 'TV' selection grayed out in the input mode choises?
It is grayed out because you do not have anything connected to the tv input. If you connect an antenna to it or even a coaxial cable it will not be grayed out, and you will be able to access it.
Sep 23, 2011 | Panasonic Televison & Video
I turn my plasma on and the screen turns gray then shuts off right after. whats wrong
Optimistically, you might have set it to PC input; which will turn off the screen if it thinks the computer isn't displaying anything (or is disconnected).
Try changing the input / source as fast as you can when you first turn it on.
Mar 04, 2011 | Samsung PPM42S3 42 in. Plasma Television
Wiring diagram for BOSS AVA 1209 equalizer. It was given to me dont know where the 4 wires connect red,black,white,last wire is orange or pink.
Your wiring is as follow's :
The Red wire is your (+) Positive that connect's to the power source
The Black wire is your (-) Negative that connect's to the ground
The Orange wire is your Auxillary (+) that turn's on Amplifier's or Power Ant.
You should have a Green wire, a Green wire with a White stripe,a Gray wire, and a Gray wire with White stripe
The Green wire is the LEFT channel input (+)
The Green/White wire is the LEFT channel input (-)
The Gray wire is the RIGHT channel input (+)
The Gray/White wire is the RIGHT channe (-)
PS. I have no idea where that White wire you mentioned goes.
Feb 03, 2011 | Boss AVA1209 7-Band Car Equalizer
Input not supported - floating gray message Win 7
You haven't specified what monitor you use but the gray message is most likely due to your screen not being able to handle the high resolution. Try setting it to a resolution below 1600 x 1200.
Best wishes,
Dec 15, 2009 | ZT Group Cisnet PC Desktop
I need to know how to install a Boss Audio
Hello viperman2004,
Just connect your speaker leads to the input of the B65N (gray and gray/white pigtail leads), run the RCA cables to your amp (red=right) inputs, adjust the left and right level controls to match the amp input without distortion, and mount the unit.
Hope this helps.
Aug 11, 2009 | Boss Car Audio & Video
Map sensor wiring for Chevy s-10
Well after looking it up it's the the map input wire is light green on both 4 and 6 cylinder models.
On a 4cyl the map has black gray and light green, the black is ground, the gray is a 5 volt refrence from the pcm(power control module), and the light green goes to to ECU for MAP input.
On a 6cyl the map has black gray and light green, the black is goes to the automatic transmission, gray is a 5 volt refrence from the pcm(power control module), and the light green goes to to ECU for MAP input.
Hope this helps and good luck
Jul 01, 2008 | 2000 Chevrolet S-10
PC to TV Picture
try a DVI/digital cable on the HDMI inputs
Jan 11, 2007 | Samsung LN-S4092D 40 in. LCD HDTV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
