Is there a driver or patch for an original motu 2408 with a pci 324 for windows 7 pro 32 bit and 64 bit,
IM USING AN I7 PROCESSOR WITH 16 GIGS OF RAM AND A 3 TB HD MY DAW IS SONAR 8 PRODUCER IF THIS IS ANY HELP
Basilio00920
  • 155 Answers
SOURCE: Upgrade NEC Versa VX
You can insert the Windows XP CD while logged on Win 98 and run a test from the CD. Obviously you need a larger Hard Disk and at least 126 MB RAM to bring XP to a usable speed. You can look for RAM upgrade options in this page.
Posted on Apr 18, 2009
SmartAviator
  • 449 Answers
SOURCE: unable to connect my pci 324 motu card to my pc
Uninstall the drivers and try re-installing the drivers. Also check there is no conflict in the hardware resources. (ehteshamhusain@gmail.com)
Posted on Jul 20, 2009
  • 17 Answers
SOURCE: Windows Vista Ultimate 64-bit
SEARCH THE 64 BIT DRIVERS IN GOOGLE SEARCH.
Posted on Sep 09, 2009
spiffyrodent
  • 85 Answers
SOURCE: I have a asus AV7 with a amd 64 bit processor 2
There is a glitch on those AV7 boards ata controler I think. Check the website for the new drivers supposedly they help, but all they did was crash my raid after I installed them. I ended up cloning the whole raid over to a single large sata drive and put in an ide to sata card (non raid unfortunately) and the problem went away. I only had the problem under very heavy disk loading. It seemed to not be quite so bad when I added some additional cooling aimed at the motherboard. As to if it will help your software problem I am unsure. However the only time mine did the mini dump was when I was doing heavy video editing work and after nixing the raid it fixed it, But then again a bad drive in a raid can cause that also.
Posted on Sep 10, 2009
  • 42 Answers
SOURCE: blue screen with 4gb, OK with 3gb of RAM on 6720s
A 32bit OS and Processor is able to Identify and work with upto 3GB of memory.
That may be the cause of the issue
Even if any computer has more then 3gb of ram it will showup only upto 3gb.
if you install 4gb or more then also it will not show up.
.........and second reason, may the ram that you are using are not identical or one of them is not working properly.
Check the specifications of the ram and also try using one a time.
Thanks and Regards
Posted on Jan 03, 2010
Will Platinum 16 run on my new windows 7 computer
From their web site:
Windows® XP SP3/Windows Vista® SP1/Windows® 7¹, Pentium® III, 500MHz processor or faster for Windows® XP and Windows Vista®; 1GHz or faster 32-bit or 64-bit processor for Windows® 7, 128MB RAM (1GB Windows Vista®, 1GB Windows® 7 32-bit, 2GB Windows® 7 64-bit), 8x DVD-ROM Drive or faster
Looks like it should work.
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
Sep 26, 2011 | HP Computers & Internet
Tip
Windows 7 Migration Guide. Minimum Hard Requirement · 1 gigahertz...
  • · 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • · 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • · 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • · DirectX 9 graphics device with WDDM 1.0 or higher driver
Versions of Windows 7
  • · Windows 7 Home Premium
  • · Windows 7 Professional
  • · Windows 7 Ultimate
Select either 32 or 64 bit Operating system (Based on requirement)
Last but not least select viable Windows 7 Migration Software.
on Dec 16, 2009 | Microsoft Windows XP Migration Services
I am unable to install in windows 7
Did you pass the minimum requirements on installing windows 7?
Windows 7 system requirements
If you want to run Windows 7 on your PC, here's what it takes:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit(x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
CLick here for more info.
Sep 15, 2011 | Computers & Internet
Can it support windows 7
yes, its supported by windows 7.
but need more setting to make it fast. maybe tune up utility will help increase the performance.
help me by rate my answer.
Mar 06, 2011 | MSI K9MM-V Motherboard
Lag lag
Have you tried to review the systems requirements for Windows 7? In case you don't, try to review this system requirements and see if your PC falls in. If not, then its the primary cause of the "lag" computer.
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
Apr 27, 2010 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
Tosheiba Netbook NB205-N210 2 GIG, upgrade to Windows 7
I personally have not but if you are concerned how it will run, you should be fine, windows 7 is very efficent on resources.
    These are system specs so if you exceed these then your laptop will run great.
    Hope this helps
Mar 20, 2010 | Toshiba NB205-N310/BN Netbook
Asus notebook windows 7 totally frozen..."not responding" Can't even exit without holding power off.
This is due to the fact that your ASUS Eee PC 701 PC does not offer minimum System requirements to run windows 7
Microsoft has published their minimum specifications for a system running Windows 7
as
  • 1 GHz or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 GB RAM (32-bit) / 2 GB RAM (64-bit)
  • 16 GB available disk space (32-bit) / 20 GB (64-bit)
  • DirectX 9 graphics processor with WDDM 1.0 or higher driver
But I suggest following as min to run smoothly
  • A Dual Processor (AMD or Intel) – you can use a lower Celeron or Pentium Processor, but you will regret it
  • 2 GB RAM (operating memory) – you can use less, but you will regret it
  • 16 GB available disk space and another 20 to 30 GB if you plan on running applications
  • A Vista compatible graphics card (DirectX 9 graphics process with WDDM 1.0 or higher)
  • A Vista compatible sound card
  • Vista drivers for any other unique hardware you have on or connected to your computer
If this helps please do leave a vote and rate for the solution.
Feb 21, 2010 | ASUS Eee PC 701 Notebook
Will the D915GEV support window7
Yes: Windows 7 can be used with this board.
Here's the specs on the D915GEV
(See PDF Manual)
Click here:
D915GEV Technical Product Specification [PDF]
The Intel 915G chipset consists of the following devices:
• Intel 82915G Graphics Memory Controller Hub (MCH) with Direct Media Interface (DMI) interconnect
• Intel 82801FB I/O Controller Hub (ICH6) with DMI interconnect
• Firmware Hub (FWH)
The MCH is a centralized controller for the system bus, the memory bus, the PCI Express bus, and the DMI interconnect. The ICH6 is a centralized controller for the board’s I/O paths. The FWH
provides the nonvolatile storage of the BIOS.
Supported Memory Configurations.
Up to : • 4 GB maximum total system memory.
Processor:
The board is designed to support Intel Pentium 4 processors in an LGA775 processor socket with an 800 or 533 MHz system bus.
Note: All processors available for this board are in excess of the 1 gigahertz (GHz) minimum requirement for Windows 7. (see here) http://www.intel.com/support/motherboards/desktop/d915gev/sb/CS-026957.htm
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks.
Feb 08, 2010 | Intel D915GEV Motherboard
Will the Aspire 5100 run Windows 7?
if your laptop meet the requirements of windows 7 it is good>>. it can run the windows 7>>> i will give you the system requirements of windows 7>>>>
  • Processor: 1 GHz 32-bit or 64-bit processor
  • Memory: 1 GB of system memory
  • Hard drive: 16 GB of available disk space
  • Video card: Support for DirectX 9 graphics with 128MB memory (in order to enable Aero theme)
  • Drive: DVD-R/W drive
Dec 14, 2009 | Acer Aspire 5100-3357 Notebook
I can upgrade to windows 7 in my n1000
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Personally i would recommend to upgrade ram then install win 7
Regards
Uttam
Windows 7 requirement If you want to run Windows 7 on your PC, here's what it takes:
http://www.microsoft.com/windows/windows-7/get/system-requirements.aspx
Here is you laptop spec
Processor Processor Intel Pentium M 733 / 1.1 GHz
  • Core voltage technology Ultra Low Voltage (ULV)
  • Data bus speed 400.0 MHz
  • Processor features Enhanced SpeedStep technology , Power-optimized processor system bus
  • Chipset type Intel 855GME
Cache Memory Type L2 cache
  • Cache size 2.0 MB
RAM Installed Size 512.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM - 333.0 MHz
  • Memory specification compliance PC2700
Video Graphics Processor / Vendor Intel Extreme Graphics 2
  • Video Memory Dynamic Video Memory Technology 2.0
Operating System / Software
  • OS Provided Microsoft Windows XP Professional
  • Software Drivers & Utilities
Dec 10, 2009 | Averatec 1000 Notebook
Computers & Internet Logo
David Payne
David Payne
