Question about Boating
1990 30 hp outboard motor thermostat located - Boating
  • 65 Answers
SOURCE: where is the thermostat and waterpump located on a sears 9.9hp gamefisher outboard motor
water pump is in the lower end of out drive and there is no t-stat
Posted on May 08, 2009
SOURCE: Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
Posted on Jul 25, 2009
  • 86 Answers
SOURCE: Spark plug gap 150 hp Yamaha outboard
The correct gap is .035
Posted on Oct 16, 2009
SOURCE: Does an 85 johnson outboard motor 15 hp have
breaker/maker. set @ 020" @ the highest point but what is you're real problem. Run only champion spark plugs. We spenta dAY @ omc'S SERVICE CENTRE BEING SHOWN WHY. tHEY KNOW BEST!!
Posted on Oct 20, 2009
  • 91 Answers
SOURCE: suzuki outboard motor 65 hp --oil sensor keeps
assuming you are not out of oil in your oil reservoir you probably have a bad sending unit in the reservoir. never bypass it or eliminate it as you could permanently damage your motor or ruin it if you ran it out of oil.
Posted on Jun 20, 2010
Location of thermostat on a 1990 30hp evinrude outboard boat motor
Located on the cylinder head above the #1 cylinder, near the top. Will have 3 bolts holding the thermostat cover to the head. There is a spring holding the thermostat to the seal.
Dec 08, 2016 | Boating
What year is a evinrude outboard with serial number 1451821
The motor HP is critical in such searches. Here are all the resources you need to find the information yourself.
About this result
How To: Outboard Engine Serial Number Year Match, iboats.com How ...
www.iboats.com/basics/serial_number_year.html
  1. Cached
  2. Similar
For engines prior to 1969 refer the the Johnson 1960-1979 serial number year chart located here. If you have a commercial model refer to the Johnson commercial serial number year chart located here. Evinrude changed how they indicate year in the model number in 1980.Mercury Outboard · ‎Evinrude Outboards 1950-1979 · ‎Johnson Evinrude Commercial
[PDF]5006145_Model Number Reference.fm - Evinrude
shop.evinrude.com/media/document/ModelNumberReference.pdf
  1. Similar
MODEL NUMBER DESIGNATION - OUTBOARDS. Model Years 1980-1998. V E 70 T L ED A. MODEL VARIATION. A = Australia. B = Belgium. C = Canada.
Evinrude Outboard Motor Model Numbers & Codes - Marine Engine
www.marineengine.com/manuals/evinrude/
  1. Cached
  2. Similar
The nameplate should contain a model number and a serial number. The model number will identify the year and certain details of that motor. 1980-Present: Evinrude outboards from 1980 to the present use a model number that can help determine the year and features of the motor. See the model number code here.0.5HP · ‎0.9HP · ‎1HP · ‎1.1HP
Marine Motor Look-Up Guide - Auto Repair Manuals
www.autorepairmanuals.biz/page/599222
  1. Cached
  2. Similar
keywords: Find year, serial, number, model, number, #, outboard, motor, marine, motor, look-up, Johnson, Evinrude, Mariner, Mercury, Force, OMC, Yamaha, ...
EVINRUDE OUTBOARD MOTOR MODEL YEAR LOOKUP GUIDE ...
www.maxrules.com/models/OMC_models_files/EVthru79/ev_index_79.html
  1. Cached
  2. Similar
WHAT YEAR IS THAT OLD EVINRUDE? FIND OUT HERE ON OUR MODEL YEAR LOOKUP CHART! evinrude outboard with serial number Google Search
Nov 29, 2016 | Boating
How do I replace the thermostat on a 1999 Johnson 50 hp outboard.
Thermostat on a 1999 50 HP Johnson is easily replaced. It is located at the top of the cylinder head at the top rear of the motor, just above the spark plugs. The thermostat also functions as a pressure relief valve so when you remove the old thermostat make sure there is no debris, (shell, weeds, etc.), where the thermostat seats. If there is anything preventing the thermostat from sealing the engine will run cold at low speed. This is a problem because it will cause a lot of carbon deposits in the combustion chamber. Eventually the carbon deposits will cause the piston rings to stick in the piston hindering their ability to seal to the cylinder wall. This will damage the cylinder and the piston and the engine will need to be rebuilt. Replacing the thermostat is easy to do. Make sure all components are clean and use new O-rings and/or gaskets.
Oct 28, 2014 | Boating
Evinrude 40hp outboard
usually in the head. Check a parts book.
Jul 11, 2014 | Boating
No water flowing out my 40hp envenrude outboard water exaust port
Plossibly clogged intakes (grim in intakes) or thermostats not opening. I would suggest pulling the lower unit and then your thermostat housing and use a water hose to back-flush it out. Also check the thermostats in boiling water to make certain opening.
May 09, 2014 | Clymer Evinrude/johnson 2-40 Hp Outboards...
Where is the thermostat on a 1993 mercury 40 hp classic outboard motor
If it has one,it will be at top of block on port side close to the top plug,cover plate held in by 3 bolts
Jan 25, 2014 | Boating
50 hp yamaha outboard mid 1990's
2 stroke ?? choking up do you mean ? what oil make and mixture ratio ?
May 11, 2013 | Yamaha 40N/50N 40 and 50 HP Outboard Motor...
I have a 2008 25 hp Mercury 4 stroke outboard. Will the manual tilt assist you offer work with this motor without needing to modify the lever?
I have one of these tilters and it's on a 2009 25Merc. I had to modify it because the pull handle is located lower on the back of motor.
Jun 27, 2011 | Cabela's Adjustable Outboard Motor Tilter
Where is the thermostat and waterpump located on a sears 9.9hp gamefisher outboard motor
May 05, 2009 | Boating
Boating Logo
113 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
