Question about Maytag Washing Machines
Maytag Bravos Quiet Series 400: F01 Error code
Moving to a different cycle selection has gotten me passed the error/machine can function fine. Error sequence: Selection of cycle (wrinkle free or Normal cycle typically), the lid locks, small amount of water added to tub, slow drum turn (load sensing), then F01 error and stops.
  • Maytag Master
  • 5,323 Answers
Maytag washer with error code F01 means a obstruction in a hose or tube, not a control panel issue like people say. How can I clear the small tube? see pics
Maytag Bravos Quiet Series 400: F01 Error code - 26390115-bszy215dbxllk1sw2ym4qmfg-4-0.jpg
Posted on Dec 08, 2016
Maytag Bravos Dryer quiet series f01 code
F-01 Means the main electronic control board is likely to have failed.
Unplug the dryer for 5 minutes and the plug the dryer back in. If the code reappears, replace the main electronic control board.
This is where I would start.
Maytag Dryer Circuit Board Timer Parts
Dec 19, 2017 | Maytag Dryers
I have a Maytag bravos 300 quiet series dryer that had a error code of F73. Lights come on without code but still doesn't start. Problem?
The F73 error code means that one or more of the control buttons on the touch pad is defective. You can clear the error code by the pushing clear/cancel button, if it doesn't reoccur all is well. If it ever happens again, you will need to replace the touch pad
Apr 05, 2017 | Maytag Dryers
I have a maytag bravos quiet series 300 dryer with the error message f73. What does that mean?
Maytag Bravos 7.0 Cu. Ft. Electric Dryer F73 - Questions ...
have a bravo dryer , wont start shows error code f73 ? lights come on but dryer ... I think there was an F73 or F93 error message but we did not write it down.
Sep 22, 2015 | Maytag Dryers
Can a lid switch on a maytag bravos quiet series 400 model MVWB800VU0 be bypassed for testing, lid switch passes continuity tests but machine won't finish a agitate cycle?
the switch can still be bad manually even though it shows good electronically. How ever if its bad you seldom get some agitation then goes off unless ur opening and closing it? once its bad u get nothing, hence ur problem may be elsewhere. but Im u pics on how to jumper it, I myself think ur problem is in the timer perhaps sticking? if u have no agitation then check the water pressure switch and the door switch
Jun 22, 2015 | Maytag Washing Machines
I have a Maytag Quiet Series 400 and I can't get it to run on Normal,lite or other. I get a code 82 that appears. What does this mean?
My Maytag quiet 400 series is doing the same thing-buttons aren't responding or working. And now a second has become very loud and sounds like it is chewing up all the dishes.
Jan 10, 2010 | Maytag Dishwashers
Maytag Bravos Steam dryer that reads service error code F1
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.,wkwdffkrdwtbgwsxgtqsskgwtqkq,vi/ksskgsfwrxksrttqdqr/1/1303472/5961857/image12923img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 30, 2009 | Kenmore Elite HE4 Electric Dryer
Washing Machines Logo
321 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
