Question about Elna Sewing Machines
How do i adjust the tension on elna 2003? - Elna Sewing Machines
  • Dana Powell
    Dana Powell Dec 08, 2016
    where can i find a diagram of the elna 2003
  • Elna Master
  • 10,703 Answers
Not quite sure what you are asking. The upper tension is governed by the tension disk. Higher number is tighter, lower number is looser. Usually, the mid-range is a good place to start. Tension is correct when upper and bobbin threads meet in the middle of the fabric.
NOTE--ALWAYS RAISE the presser foot when threading so the thread will seat in the tension disk!
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
How to Adjust Sewing Machine Tension on Craftsy
Just FYI:
Why my Elna sewing machine is bad Or dont buy an Elna 2007
Posted on Dec 10, 2016
My Elna sewing machine is sewing very loosely and it is very messy on the bottom side of my material, why?, and how can i fix it?
When your bottom thread is messy it is the top thread needing adjustment. Your machine may not be threaded properly and the thread may not be sitting correctly between the tension discs.
Check to make sure your machine is threaded correctly.
Check thread between the tension discs.
After checking, adjust the tension (tighter) and do a test. If it is still messy add some more tension and do another test.
Jul 10, 2017 | Elna Sewing Machines
How do you adjust the tension control on an Elna lotus SP
The tension dial is on the front of the machine right above the needle. The higher the number, the tighter the tension is applied to the top thread. HINT: When threading the top thread, ALWAYS RAISE the presser foot throughout the entire threading process. This allows the thread to seat completely in the tension disk. Tension is correct when the top and bobbin threads meet in the middle of the fabric.
Elna Lotus Instruction Booklet
Elna Lotus SP bobbin case repair Removing cotton jam from Elna Sewing...
Elna SP ST SU sewing machine repair tips (I use liquid Tri-Flow Synthetic Lube or silicone spray to loosen parts seized from old oil. Do NOT use WD-40, cooking oil, motor oil...)
Apr 29, 2017 | Elna Sewing Machines
I have an Elna Elina 40 and bobbin thread on the top when sewing. I have fixed thread tension up top and then when nothing changed I adjusted bobbin tension and nothing changes. Please help!
Please explain more fully the symptoms your machine is displaying and what you are attempting to do when making adjustments.
If the bobbin thread is showing on top of the fabric, the upper thread is too tight and/or the bobbin tension is too loose.
Set the upper tension to the midway point between high & low number, then retest your machine. If the bobbin thread is still showing on top, then the bobbin tension is a bit too loose.
FWIW, it is normal when using 2 different color threads that you can see a "dot" of the other thread from the opposite side (especially with thin, fine fabric). If you try tightening both tensions to get rid of the "dot," the fabric will probably begin to pucker. If you are seeing a dot of each thread on the opposite side, your tension is perfect! Try stitching thicker fabric and see if the dots disappear. When sewing, it is best to use the same color thread for top and bottom or use a thread color that closely matches the fabric. Then the dots blend in and are not as noticeable.
Jan 05, 2017 | Elna Sewing Machines
How to adjust bobbin tension on 6005 elna sewing machine?
Apparently this Elna model has automatic tension settings. May be something you need to have a professional technician address.
Feb 14, 2016 | Elna Heirloom Edition 6005
How to adjust the tension on elna 614 what is the ideal tension and which way is tighther
Most manufacturer tension default settings is the midpoint between the high and low number on the tension dial. Usually the higher the number, the tighter the tension...
Nov 05, 2015 | Elna Sewing Machines
Threads jamming the bobbin case on elna sewing machine
Probably unevenly wound on the bobbin. Or tension needing adjusting, be careful to note where tension spring started before adjusting and do in very small increments.
Perhaps the spring has some fluff stuck on it and thread cannot slide through easily. Take out bobbin and clean
Nov 02, 2015 | Elna 2007 Mechanical Sewing Machine
Hi, my elna lock f4 keeps on breaking the nr2 string. I have treid everything, changing tension...... please help
try changing the needles, also try adjusting the tension, make sure it's threaded correctly
Nov 23, 2014 | Elna Sewing Machines
How to adjust the tension on Elna 614de
try rethreading the machine top & bobbin
make sure the bobbin is inserted correctly into the bobbin case
& that the bobbin is turned the correct way
Aug 25, 2012 | Elna Sewing Machines
Sudden knotting under fabric
I have an Elna 2005 machine and had a similar but opposite problem whereby the tension up top was too tight - thread wouldn't pull smoothly. I found adjusting the feed dog lever slightly helped the stitches a lot, even though the needle tension up top is no better. Hope that helps! :-s
Jul 01, 2007 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
