Question about Brother Sewing Machines
How to adjust the needle on the XL2600i brother sewing machine?
akylas
  • 26 Answers
SOURCE: brothers pe150 embroidery machine will not sew
If you tighten up your needle thread, reduce the tension of the needle thread.
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
Posted on Jun 10, 2008
  • 69 Answers
SOURCE: needle getes broken
Check to see if your needle plate is gouged or signs that the needle is hitting the plate. If so, you may be pulling a little too hard when the fabric is feeding. Sometimes when you pull too hard, it pulls the needle back and it will hit the plate instead of going into the needle hole and you will break needles. Try just letting the fabric feed itself and you simply guide it to make sure it stays in a straight line.
Posted on Feb 07, 2009
  • 37 Answers
SOURCE: MACHINE RUNS BS2450 BROTHER SEWING MACHINE BUT
I'm wondering if the bobbin spool is set to wind? Or the clutch is disengaged (older models).
Posted on Jun 05, 2009
SOURCE: Sewing machine bobbin thread issues
i dont found the bobine
Posted on Nov 22, 2009
  • 109 Answers
SOURCE: brothers pe150 embroidery machine will not let the needle pick up lower thread
It sounds like the timing is off and needs an authorized repairman.
Posted on Aug 23, 2010
How to Change the needle position in XL2600i brother sewing machine?
The manual should be helpful:
Brother XL 2600 Operation Manual
FWIW, not all machines have a needle "position" function even though they can make a zig-zag stitch. The home position is the center and the zig-zag selector just sets how wide the stitch will be.
Dec 08, 2016 | Brother Sewing Machine - XL2600i
How do you adjust the bobbin tension?
Factory standard tension for upper thread is the midway point between the high and low number. However, that tension dial is meant to be used for tweaking tension. Generally, tweaking is required whenever the type of fabric, needle, or thread are changed, ie thicker fabric like denim should have a different upper tension setting than fine chiffon. To be successful with tension settings, one must become comfortable adjusting the upper tension.
NOTE: Accurate tension is achieved when the upper thread and bobbin thread meet in the middle of the fabric.
Understanding Bobbin Tension
Jan 20, 2016 | Brother Sewing Machine - XL2600i
Tension problem. bottom thread loopy.
Make sure the bobbin is the correct one for the machine first. Try another bobbin on a scrap of material. Bobbin will fit into the bobbin holder going the incorrect way. Make sure the thread is unwinding in the correct direction. mine has a arrow for the correct position. Hope this helps.
Aug 21, 2014 | Brother XL2600I Free Arm Sewing Machine -...
I have a brother XL2600i machine. It was sewing fine, but now, the bottom thread is all loopy. I have tried reinserting the bobbin, and making sure that it goes through the tension adjusting spring. But it...
try these suggestions
check top tension & try a tension of 3 to 5
rethread the machine
try a new needle-flat side goes to the back of machine--also make sure the needle is the correct one for the fabric & thread
Sep 09, 2011 | Sewing Machines
I want to print a manual off the internet for my brother xl2600i sewing machine
You can download and print the instruction manual for Brother xl2600i in PDF format from this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
May 25, 2011 | Brother XL2600 Mechanical Sewing Machine
How do you change needle position left and right on the xl2600i thank you fran
Go to brother-usa.com and download your manual for free and it will guide you better than trying to explain it.
Sep 08, 2010 | Brother XL-2600I
Can not get the brother XL2600i to stitch the top thread does not catch the thread coming out of the bobbin. so it does not stitch
Make sure the needle has been properly installed - flat side to the back of the machine.
Thread the top thread with the presser foot up - always.
Make sure the bobbin thread is feeding from the bobbin spool in the correct direction and through the correct guides.
Hold onto the thread tail at the needle and lower (by hand and not the power pedal) and raise the needle to pull the bobbin thread to the top of the machine.
Take both thread tails under the presser foot and to the back of the machine before you begin to sew.
Feb 18, 2010 | Brother XL-2600I
Sewing Machines Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
