Question about Fisher Dishwashers
The door on our Fisher and Pykel Nautilas dishwasher falls down. It appears that the springs may be faulty. How can I fix this and do I need any parts? Thanks, John.
SOURCE: Door falls open
I have had this issue TWICE now on a three year old dishwasher, and Sears charges you $150.+ to fix it. It is quite simple to fix, there is a special part that has all the pieces attached to it, except for the spring. You will have to remove the screws that are holding your dishwasher under the counter. This could be behind the rubber on the sides. I had to remove a gray plastic circle piece on the inside to see the screw (it pops right out, don't loose it!). Pull out the machine enough to see the out side- side. You will see a (plastic) white roller, string(rope), and a piece that attaches to the dishwasher. There is a number on the white plastic piece that looks like a L (it just slides out). Thess pieces are called the Dishwasher Door Balance Link. You will need to order these pieces, they are all inclusive, and come for both sides of the door, at a whopping price of $15.00. VERY simple to install. Attach one end to the spring, line up in roller then attach to the dishwasher. It is easier to look at it and follow what is on the dishwasher than me clearly explaining it. I feel that paying $1000.00 dollars for a dishwasher would warrant using metal pieces instead of substandard plastic, for this application. These door are very Heavy and like I have said I have replaced them twice with a waiting time of three weeks for the repair man. Please try it, you can do it.
Posted on Dec 31, 2007
SOURCE: KitchenAid Dishwasher KUDSO2FRSS
I recently had the same problem. One of the cords that attaches the door to a spring had snapped. I purchased cord replacments at the following URL and completed the repair myself. http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1059756&PPStack=1
Good Luck, Tim K.
Posted on Jul 07, 2008
  • 409 Answers
SOURCE: mdb7601aws dishwasher door drops down
hi there,
go to www.whirlpoolparts.ca to get the exploded view for your model #. it will be the located under Repair Parts.
Posted on Sep 23, 2008
SOURCE: Where can I buy the cable repair kit for my Kitchenaid dishwasher
OK, pretty easy fix. Look at diagram 10 here: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5164885
The link (#24) probably broke and the spring (#18) probably shot off and is lying somewhere behind the dishwasher. Just pull out the dishwasher (careful not to disconnect or crimp any of the hoses) and check to see if both springs (one on each side) can be located. Just replace the old links and re-hook the springs and all should be well.
You can order the link replacement (part #8194001) from kitchenaid at 1-800-422-1230.
Posted on Feb 20, 2009
  • 552 Answers
SOURCE: I have a nautilus dishwasher by fisher and pykel
This video explains how to repair a double and single drawer fisher and paykel dishwasher.
http://www.appliancerepairlesson.com
Posted on Feb 26, 2011
Why does my dishwasher door fall freely when opened?
There are springs and pulleys that assist the door. They use a nylon rope that is very thin to connect the pulleys door and springs. The rope is most likely broken.
Jan 10, 2016 | Dishwashers
Error 49 on a Fisher and Pykel washing machine, what can i do to resolve this?? Thankyou.
Your cold valve is faulty. The rubber membrance inside the valve can damaged after certain period of time. The problem may be inside the controller if replcement valve can't fix the problem. There is a resistor on the current path to the valve. It is on the control board. Some timems it can go open. Good luck with the repair
Regards
Sarath
Apr 15, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher pykel dishwasher not cleaning dishes properly
Avoid overloading the dishwasher.
Ensure the spray arms can rotate freely.
Remove scraps from dishes before loading.
Hope this will help
Feb 07, 2012 | Fisher and Paykel Dishwashers
Drawer won't open and get beep code 2 short 1 long
The drawer door seal is locked in. This could be either because the controller has lost power or the seal actuator motor is faulty.
You will have to force open the drawer before you can do anything. (Turn off the mains power when you work on the dishwasher)
Let me know if you can handle electric/ mechanical repairs so that I can guide you further. Otherwise you should call a technician. If you are getting beeps then most likely the door seal system is the problem.
Are you able to use the top drawer?
Jul 26, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
The door spring is broken and the door falls open
there is springs on left and right side held by string and spring. one is broken.letme know how it turned out.
Feb 26, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Repair door springs - LG dishwasher - LD-2040WH.
my lg door keeps on falling done something wrong with door springs ; how do i repair it.
Nov 28, 2009 | LG Dishwashers
Dishwashers Logo
Top Fisher Dishwashers Experts
Tony Houde
Tony Houde
Ronny Bennett Sr.
Ronny Bennett Sr.
Alan Matzke
Alan Matzke
Are you a Fisher Dishwasher Expert? Answer questions, earn points and help others
