Had a virus wiped hard drive added partition while formatting bumped keys own no opperating system come up so I sfc/scannow error 50 so chkdsk will not work with f or r error 50
    Top Expert:
  • Computers & ... Master
  • 75,066 Answers
What can I say start over.
Posted on Dec 08, 2016
Lenovo Service Partition has been destroyed! Can not find script file "X:\onekey\main\Irscall.vbs". Error on my H520s?
If you can use command prompt run the tool sfc / scannow as a administrator.
http://pcsupport.about.com/od/toolsofthetrade/ht/sfc-scannow.htm
Or you can run checkdisk also as a administrator.C:\ CHKDSK /F/R this process can take several hours.
Jun 03, 2013 | Lenovo H520s Desktop Computer; Intel...
Tip
Coping with and avoiding Hard Drive Volume Bit-map Errors
If your computer "locks up" or reboots itself, the problem is frequently lost or corrupted files on your hard drive. Most of the time the problem can be corrected by running chkdsk. However, one of the exceptions is when chkdsk reports that the hard drive has volume bitmap errors.<br /> To run chkdsk, click on Start, All Programs, Accessories and Command Prompt. This will open a "DOS Box" where you can enter DOS commands without the results scrolling off the screen before you can read them. Then key in chkdsk C: (assuming that drive C is the letter of the hard drive where your operating system files and applications programs are stored).<br /> Chkdsk will run in the read-only mode and report (but not repair) problems found on your hard drive. Chkdsk will then ask you to run chkdsk with the F switch to fix the file system. Make a mental note whether or not chkdsk reported any problems with the volume bitmap, then key-in chkdsk C: /F <br /> You will get a message that the drive will be checked (and repaired) on the next system restart.<br /> Enter exit to close the DOS box and the restart your system. Chkdsk will run automatically when your system restarts. If no volume bitmap errors were noted earlier, chkdsk should have repaired the problems with the hard drive. You can verify this by opening another DOS Box and running chkdsk without the /F. However, if bit-map errors were reported initially, chances are they will still be there as chkdsk cannot repair them.<br /> If you still have volume bitmap errors, you can either take your PC to a professional who may be able to repair the volume bitmap with specialized software, or you can back-up all of your data, format the hard drive, and reload the operating system and all applications.<br /> A frequent cause of volume bitmap errors is cloning (copying) a hard drive with more than one partition to another (usually larger) hard drive. The partitions should be sized proportionately on the target drive but sometimes the partition sizes are not reported correctly in the partition table and sometimes in the master boot record. <br /> Avoid cloning drives with multiple partitions, or if you do, immediately run chkdsk on the target drive to check for bit-map errors.
on Oct 25, 2010 | Computers & Internet
Nls error
Step 1:
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer also Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file. Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
Feb 21, 2013 | Acer Aspire One PC Notebook
\Windows\System32\Config\
Is there anything else on the error message ?
Which operating system ?
Enable VGA mode
Reboot
Jan 28, 2013 | HP Computers & Internet
Oop's system error has ocurred restarting..,
You could run the chkdsk disk utility Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive. or an easier way to run the chkdsk utility Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file. Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions. http://download.cnet.com/jetclean/3000-18512_4-75627788.html JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again. also download the registry cleaned cc cleaner
http://download.cnet.com/ccleaner/
You can also run a free registry scan using utilities from http://re7.info http://www.download3000.com/showarticles-182-0-date.html System Utilities. http://www.download3000.com/showarticles-178-0-date.html Optimisers and Diagnostics.
Hope this helps.
Dec 23, 2012 | Computers & Internet
Error 50050008 Windows Updates
click start type cmd press enter then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
you should have no input while chkdsk utility is in progress any input might further damage your computer or
hope this helps
Sep 27, 2012 | Microsoft Windows 7 Ultimate Upgrade OEM...
My compaq e500 doesn't start. how can i reformat my compaq?
you cant format a computer if it does not start !
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
hope this helps
Sep 21, 2012 | Compaq 20GB NOTEBOOK HARD DRIVE KIT FOR...
My sony p45333 wont start
the keyboard does not have any commands to format a primary hard drive
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
hope this helps
Sep 15, 2012 | ASUS P4S333-M (P4S333-M SA/LAN)...
I have a error and I cant get my system to boot up. I keep getting this error: " Isaass-system error", The end point format is invalid.
Isass is an important system file I will recommend to get the Operating System disc and boot from it to goto the recovery console, and then run the command CHKDSK /r or SFC scannow. This should be able to replace the corrupted or missing file and the computer should be back in working condition.
once it is run a scan with an anti-virus to be sure there are no viruses on the computer.
Thanks. If this was helpful, then kindly rate me.
Nov 16, 2010 | Computers & Internet
Won't boot up to windows
Hi
Probably sum system file is deleted from ur system and its showing this problem.
Do u hav a bootable OS CDROM. If yes run it and boot ur PC in command prompt.Then type SFC \SCANNOW(remember there is a blank space between SFC and scannow).
It will then ask u to insert ur OS CDROM and hopefully it will restore all origional file without disturbing ur installed OS.
If this does not solve ur problem then unfortunately u hav to reinstall new OS.
Jun 08, 2008 | Compaq Evo N410C Notebook
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
