Question about Konica Minolta bizhub Office Equipment & Supplies
Bizhub cc284e error reset HDD lock password - bizhub Konica Minolta Office Equipment & Supplies
    New Friend:
    An expert who has answered 20 or more questions within one hour.
  • 79 Answers
Try with 9272927292729272 (9272 four times)
Posted on Dec 13, 2016
2 Suggested Answers
SOURCE: I have a toshiba mini
Try the A-FF HDD unlock software .
Important note on Operating System compatibility:
HDD Unlock Wizard requires a 32-bit OS. It will not function under 64-bit OS.
Download HDD Unlock Wizard - 2,8MB
System requirements:
We recommend that you have at least 300 MHz CPU and 128 MB of RAM. 32-bit Windows XP or Vista is required.
Note: HDD Unlock Wizard does not support external USB and FireWire enclosures. Please attach drives directly to the motherboard.
for more information check this link
HDD Unlock Wizard is a user-friendly application which allows you to easily remove HDD password. IDE and SATA hard disk drives are supported. Both User and Master password can be removed. Please note that while unlocking, HDD Unlock Wizard will erase and re-certify the drive, meaning to say all data in the disk is lost and not recoverable. HDD Unlock Wizard incorporates proprietary unlocking algorithms which allow removing an unknown HDD password and making hard drive usable again.
Posted on Jan 31, 2011
Lenovo laptop HDD locked/Sata port 0 locked, insydeh20 bios locked, can't go to boot selection(it brings me to the HDD prompt password again). help!
Sorry, you're hosed. If you forgot your HDD password the only thing you can do is replace the drive and rebuild your S110. There is no way to remove or reset it without using the original password in the original motherboard. Period.
If you're misinterpreting the screen information and it happens to be the bios user password that's forgotten it is possible to have an authorized Lenovo repair center reset it with adequate proof of ownership. Lenovo themselves will not do it. If it's the SVP password for the bios the only solution is to replace the motherboard. Period.
Having passwords that can be reset like in the old days just by jumpering 2 wires defeats the purpose of having a password in the first place.
May 06, 2014 | Lenovo/IBM IdeaPad S110 Series Laptop...
Locked Laptop
This is from a factory repair and maintenance manual for Acer Aspire Laptops. It may work for you.
Forgotten Hard Disk Password
When the user keys in the wrong password three times, an error message appears. The user must now reset
the password.
1. Make a note of the error code that is displayed with the error message.
2. Run unlock6.exe from the DOS prompt in the following format:
unlock6 XXXXX 00
(XXXXX = HDD password error code, 00 = CRC base - default is 00)
3. Select Upper case ACSII Code from the screen that appears. The HDD master password is displayed.
Make a note of this password.
4. Reset your system. When the Enter Primary Master HDD User Password prompt appears, enter the
password you made a note of in step 3.
Resetting a BIOS Password
The user can reset a BIOS password using the clnpwd.exe utiility.
1. Copy clnpwd.exe to a DOS boot up disk (or flash drive).
2. Boot your system in DOS mode.
3. Execute clnpwd.exe from the boot up disk (or flash drive).
4. Press 1 or 2 to reset the required password as shown on screen.
5. A confirmation message appears when the process is successful.
May 24, 2010 | Acer Aspire 5315-2713 Notebook
Will not except my boot password
if it is not accepting your boot password, make sure your password is typed correctly hence no caps or caps num lock or no num lock etc.
If you have tried all that and failed, reset the cmos by removing the battery on the motherboard and leaving it out for atleast a minute to be safe. Place it back in and start the computer up. Everything should be reset to manufactures default and password should be removed. Please do not try this if your not technically trained or certified in this field.
Dec 01, 2009 | Toshiba Computers & Internet
Bizhub c350 will not scan to hdd
Easiest way is to change to SMB scanning which will give you direct scanning to PC or server. Create a new address in the machines address tab in the browser add the (must be a fixed) ip address of the machine it is going to with the folder name, user name and password and it will work a treat.
Mar 30, 2009 | Konica Minolta bizhub C351 All-In-One...
Konica Bizhub Password Reset
You can try the default admin password which is 12345678
Mar 24, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta Admin Password
Try 12345678.  That worked for me for my Bizhub C250.
Mar 18, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica Bizhub c350 default password is 12345678 give that a try
Mar 11, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub C352 error code C-D010
enter service mode, select state confirmation, select memory/hdd adj, select hdd format, select physical format, press start button, when displays ok turn off main power for 10 seconds, c-d010 will display again, repeat instructions and do logical format, turn main power off for 10 seconds..should be ok
Nov 21, 2008 | Konica Minolta bizhub C250 All-In-One...
230 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
