Question about Cell Phones
Trying to find the rear axle ratio on a 2008 ford ranger truck with the code R6 (found on the door)
Any ideas?
  • 6674 Answers
SOURCE: how to tell what gear ratio i have in my truck
No tag on door pillar or door telling you? Or try ( )
Posted on Dec 31, 2008
  • 783 Answers
SOURCE: torque specs 7.5 inch rear axle 96 ford ranger
Differential bearing caps 70-85 ft lb
Ring gear bolts 70-85 ft lb
Pinion bearing preload if using original bearings 8-14 lb-in, if installing new bearings 16-28 lb-in
Posted on Jan 30, 2009
  • 7353 Answers
SOURCE: decifering the "build" codes on Toyota Tacoma
I would call the dealer parts dept. they should be able to tell you what you need to know. there may be a difference in gear ratio for each engine/ trans combination. A salvage yard may be able to help you , they should have a computer system showing what rear is compatible. there should be a code on the axle housing itself.
Posted on Oct 13, 2009
  • 21 Answers
SOURCE: how do i remove c clips in 7.5 ford ranger rear
remove the inspection plate. turn the axles until you can remove the center pin in the carrier. remove pin,rotate axles, remove spider gears, and push axle in towards center of truck, booya, pins should fall right out
Posted on Dec 20, 2009
For the 2008 Ford Explorer ONLY (SUV). Look under the steering wheel. There is a black fuse box near emergency brake pedal. You will need a flashlight and a dental mirror (very tight space. Look between the lower lid of the box on the slim space to the left side. Take your time, you will see a bar code and 5 above it...That's it! I found mine that way. If you are laying on your back looking up, it's the gap above your right shoulder.GOOD LUCK!
Posted on Jun 11, 2011
I have a 2004 Chevy s10 4 door pickup 4 wheel drive rear axle code gu6 and g80 what rear ends interchange with this
ear axle ratio RPO - S-10 Forum
Jul 13, 2002 - 51 posts - ‎41 authors is the place to discuss rear axle ratio RPO. ... GU6=3.42. GT4=3.73. GT5=4.10 ... .... which trucksusually come with 3.42 from the factory ? ..... On an unrelated note, it looks like I havethe GT4 code in my '98 Blazer 4-door, and the G80. More results from
Rear End Ratio RPO Codes Here [Archive] - FSC - Chevy Truck Forum ... > ... > Technical / Maintenance
May 5, 2004 - 100+ posts - ‎100+ authors
I have a 3.08 rear end ratio, I forget the code 4u or something. Then in the next column I ... G80 is the RPO code for the factory locker, not posi ...
How Do I Know My Truck Has A Locking Diff? - 1999-2006 & 2007-2013 ...
Jan 19, 2016 | Cars & Trucks
Yamaha torque specs
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
06 07 R6 Mechanical Tech Info
2008 2009 Yamaha YZF R6 Service Manual R6 Moto Data Project
OEM parts for Yamaha
Jun 15, 2014 | 2008 Yamaha YZF-R6
2006 f 150 axle code b6 what ratio is that
This was current for the 2004 MY, so should work for at least the 04-08 MY range,
Axle Codes (LS=Limited Slip / Traction Lok):
19 - 3.55 Non-LS
18 - 3.08 Non-LS
H9 - 3.55 LS
B6 - 3.73 LS
27 - 3.31 Non-LS
26 - 3.73 Non-LS
84 - 3.45 Non-LS
86 - 3.73 Non-LS
87 - 4.10 Non-LS
89 - 4.56 Non-LS
F6 - 3.73 LS
F7 - 4.10 LS
92 - 3.08 Non-LS
R5 - 3.55 LS
91 - 3.27 Non-LS
96 - 3.73 Non-LS
R6 - 3.73 LS
Nov 10, 2010 | 2006 Ford F-150
Decifering the "build" codes on Toyota Tacoma
Oct 13, 2009 | 2001 Toyota Tacoma
Oem gear ratio for a 1997 ford f 150
look on the door jamb sticker for the axle code and compare it to the chart. please rate as solved if this helps.
The front and rear axle codes are as follows:
  • Rear axle ratio codes (A) are:
    • 18 — 3.08.
    • 19 — 3.55.
    • 26 — 3.73.
    • 27 — 3.31.
    • H9 — 3.55 Limited slip.
    • B6 — 3.73 Limited Slip.
  • Front axle (B) code.
May 25, 2009 | 1998 Ford Explorer
Finding someone to answer my ?
you have a tag on the driver door or door post with an axle code.
1996 codes. don't have earlier. may be the same though.
Apr 20, 2009 | Ford F-150 Cars & Trucks
97 ford expedition 4x4 rear differential.door tag has #9 on axle
there should be a tag on rear end to check rear end, there are 4 different seizes for that car. 16 is 3.73 ,17 is 3.31 ,19 3.55 pos track. and 19 3.55 limited slip.
Feb 09, 2018 | 1997 Ford Expedition
Trying to identify rear differential on 87 ford ranger 7.5 or 8.0 need to replace since teeth from gears were in case.
You most likely have the 7.5, as that was the stock rear axle on older rangers.
There should be a tag on the differential cover bolt that has the gear ratio and differential size on it.
Jan 03, 2009 | 1991 Ford Ranger Supercab
Bird Rear-end Size
Hi meduck4,heres what you need brother as I cant see your diff, 3 ways to tell what you have:
#1 The first is the driver's door tag; there will be a one-letter or one-numeral axle code listed there. You can then compare it to the chart below: CODE Rear Axle Ratio Conventional Locking 8 M 2.73 Y Z 3.08 F R 3.45 5 E 3.27 6 W 3.73
#2 The second is the axle tag, attached to the lower lefthand bolt on the rear axle itself. The bottom left line will give you the gear ratio, and the type of rear end (S for limited slip non-locking, and L for locking).
#3 The 7.5" rear axle height is shorter than the width and the shape appears "oval".
The 8.8" rear axle
dimensions are equal and the shape appears "round".
This will tell you what you have my friend,good luck
Nov 13, 2008 | 1985 Ford Thunderbird
Cell Phones Logo
15 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
