Question about GE Kitchen Ranges
GE Spectre gas range, the oven stopped working
  • Damian Appert
    Damian Appert Dec 08, 2016
    Just wondering, when you press the oven (bake) button, does the indicator glow? Or do all of the other buttons glow and function except that one?
  • 4 Answers
SOURCE: GE XL44 Range
The pilot light is lit to light the main burner. First off, is your pilot light lit or is the igniter lit. There are two thermal sensor in the oven. One is above your pilot light and will not let the pilot light stay lit unless there is a flame. Secondly, you have a thermal sensor in your oven wired all the way to the switch to turn the oven on. If it thinks that it is at temp, then it will never turn on. This sensor may become bad or the case of my oven break. But if these are good, you many have a clogged burning unit underneath. Cleaning according to the owners manual may correct that. Check your owners manual to see what is user serviceable. Gas is nothing to play with.
Posted on May 18, 2007
  • 3 Answers
SOURCE: Oven wont light
Mine did that and I found the ignitor for the oven was bad. It was the "glow" type for pilotless ignition and it was burned out. It is supposed to glow bright red and the gas comes on and the oven will light. It was easy to tell that it was bad. But to check it I swapped the broiler ignitor with the oven ignitor and the oven worked.
Posted on Dec 20, 2008
jumptrout51
  • 3361 Answers
SOURCE: GE Profile gas range - stove works, oven doesn't heat
Set the oven for bake. Wait a couple minutes and look in the oven. If you see a orange glow the ignitor is working, but, may need to be replaced.
If you see no orange glow the ignitor definitely needs to be replaced.
Posted on Feb 21, 2009
  • 23 Answers
SOURCE: The oven of GE Profile range simply stopped igniting
If it is a ge it would have a glow bar ignitor, either a flat rectangle shaped or a round ignitor. That is want the problem is 95% of the time. It is pretty easy to do. The floor of the stove will come right out and it probably has two screws in the back corners you can see. Remove them and the floor will lift out and you can see the burner and the ignitor.
Posted on Jun 20, 2009
SOURCE: GE Spectra XL44 Gas Kitchen Range - suddenly only top works
where do I find the pilot light?
Posted on Jul 04, 2009
The GE Range stove top is working fine, but why won't the oven or broiler work?
Electric or gas? Does make a difference.
U want assistance but you are not making it easy.
Feb 12, 2016 | GE Kitchen Ranges
My GE xl44 gas range broiler won't work,
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
Gexl44 gas range, oven stopped working for no apparent reason, stovetop still works just fine, no gas smell
Oven not Working or
Oven not Heating
heatman101
Feb 04, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Xl44 GE GAS RANGE OVEN WONT WORK, RED LIGHT IN
heatman101
czvb
May 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
GE profile JGSP44 Oven stopped working
Ignitor needs to be working for the gas valve to open. If the ignitor does not reach the proper amp draw the gas valve will not open. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru performing an amp draw test on the ignitor.
Mar 28, 2010 | GE Profile JGSP44 Dual Fuel (Electric and...
GE gas range model JGBS10BEH2BB oven and broiler
you need to check the ignitor even if the ignitor glows it might not be pulling enough amps to call for gas replace the ignitor and this should take care of the problem
Aug 28, 2009 | GE Kitchen Ranges
Oven digital display does not work after an electrical surge
You may want to put in a claim against the power company, a spike may have burned out the control board
Apr 29, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Feb 20, 2009 | Kitchen Ranges
Oven burner makes a popping or whistling sound during baking cycl
STOP>>>>STOP{>>>STOP>>>
You have a gas leak in the oven.
Get this fixed immediately.
Feb 09, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
51 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
