Question about Miele Dishwashers
How can I adjust the door tension on my Miele g2472 dishwasher?
  • 209 Answers
SOURCE: Door Tension
just about the most difficult job to do on a dishwasher, not normally a job for the home mechanic, i am an appliance engineer of 20 years and often shy away from jobs like this,
there is often no adjustment, the hinges are sprained, more often that not by people either putting weight on the door to stand back up, or children climbing on to get higher
the only thing i think you can do is to check the springs are in place and nothing is broken or just come off that can be put back?? sorry
Posted on Oct 15, 2007
SOURCE: adjusting the door on a neff dishwasher
I have the same problem with my newly installed Miele integrated dishwasher. The door does not stay open when you are trying to load dishes. I heard that there is an adjustable internal mechanism to adjust the tension on the door. But, I am still working on solving my problem.
Posted on Aug 17, 2008
dragonsthatk
  • 547 Answers
SOURCE: Change miele dishwasher door seal
http://www.partstap.com/ please go to this site for diagram please rate me thank you for useing fixya
Posted on Feb 25, 2009
  • 177 Answers
SOURCE: the door on my miele G481 built in dishwasher won'...
hi,
what you need to do is slack off the spring tension on the door hinges. each side of the unit at the base on the plinth there is a screw with a spring symbol next to it. turn this anti clockwise to reduce the spring tension.
Hope this helps
Posted on May 24, 2010
  • 177 Answers
SOURCE: 23 in. Novotronic G841 Built-In Dishwasher: the door on my miele G481 built in dishwasher won'...
hi,
you need to adjust the door tension springs which is by a screw each side of the hinges on the plinth of the unit at the front. There is a symbol of a spring to show you which screws to release. do them evenly and the door will not spring up,
Posted on Jun 13, 2010
How do I fix or replace the door spring in a Miele G6892 dishwasher?
Step 1: Get Access to the Door Spring Remove the lower panel under the door. Normally, two screws keep the panel in place. These screws are located on top of or below the panel. There are cases wherein you have to initially open the dishwasher door to be able to remove the screws. The door should then be closed in order to remove the panel.
Step 2: Remove Springs To remove the springs, the hook of the spring should be lifted from the anchor point. Use your fingers to do so. If there is a large amount of tension, it's best to use a screwdriver or pliars. Position the shaft under the hook and then pull it down. After pulling down, try lifting the anchor. To make things easier, try locating a leverage point. This should help the screwdriver force the spring out. Be certain to remove the spring from all of its anchor points.
Step 3: Installation of New Springs To install a new spring, you initially have to deal with the positioning of the lower spring hook. It should be placed within the first hole. Take note of the adjustment bracket when doing this. Follow the previous set up. If the spring needs more tension, try positioning the spring hook further towards the back of the adjustment bracket. The end of the spring for the counter balance of the door should be mounted on the door support. Find the slot on the support. Replace all covers and door panels. Test the door to check for any problems.
Jul 16, 2016 | Miele Dishwashers
How do you adjust the door spring on a miele dishwasher?
there are two screws behind the kick plate - one for the right side on fro the left - the screw have a little - and + above them to show which way to turn to increase or decrease the tension
Aug 10, 2014 | Miele G6100SCI 598 mm Clean Steel Built-In...
I've just installed a Miele 5500SCU Dishwasher and the springs that support the door cant be adjusted far enough to take the weight of the door, does anyone have any suggestions?
If the dishwasher is brand new, then there is an issue with the configuration of the springs, i.e not mounted correctly. A factory dishwasher door should not need to be adjusted. However if it is older, it is possible that the springs came off, in which case they can be seen from the underside of the dishwasher and by a panel that unscrews on the bottom of the door. Make sure the springs are there.
Dec 30, 2012 | Miele Dishwashers
My brand new Miele dishwasher door wont saty down when loading and unloading - tonight was the last straw as it shot up and has really hurt my forearm!!! Please tell me what I can do to sort this out =...
you can tension the door springs or release tension by a screw at the top ....you will have to look for it check the book for directions....you probably have a model made for a door panel to be fitted and dont have the panel fitted yet...
Feb 10, 2011 | Miele Inspira G2140 Dishwasher
The door on my miele G481 built in dishwasher won't stay open it's really annoying that it keeps popping up when I'm trying to load.
hi,
Hope this helps
May 21, 2010 | Miele 23 in. Novotronic G841 Built-In...
hi,
May 18, 2010 | Miele 23 in. Novotronic G841 Built-In...
Door does not stay horizontal when opened. How do I adjust the door springs?
Hello Slosh,
The are four torx screws (Two on each side) of the door panel near the bottom. The top screw controls tension and the bottom allows you to position the door. Be careful when loosening the panel as the screws will come out completely and then you will need to remove the outer door panel and reattach the door springs
Sep 15, 2009 | Miele 24 in. G638 Plus Free-standing...
Door Tension Adjustment on Electrolux Dishwasher
you should be able to remove the lower acess panel, and the tension springs are on both sides, cant really picture how to adjust tension( font or back), but there should be enough room to get a flashlight and you hands under there to make the adjustment
Oct 26, 2008 | Indesit 23 in. DV62 IX Built-in Dishwasher
Adjusting the door on a neff dishwasher
Mar 16, 2008 | Neff 18 in. S5943 Slim-Line Built-in...
Open Questions:
Dishwashers Logo
146 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
