Question about PRINTER Office Equipment & Supplies
  • 6966 Answers
SOURCE: wont printer test sheet
Hi, On a similar brand/different model, this type of problem was caused by the the USB cable from printer to PC. Since this particular model does not include a USB cable, perhaps what you are using is faulty. Try another cable known to be good (say from another or your old printer). If the cable checks out, try plugging into your PC's other USB ports. You may have likewise to verify that your USB ports. hubs and controllers are installed properly with no problems or errors in your Device manager. Some issues may be inherent to your operating system,l please check compatibility with your OS. Hope this be of some help/idea. Pls post back how things turn up or should you need further information. Good luck and kind regards. If this also fails, you may have to re-install the necessary LM1750 drivers.
Posted on Sep 20, 2007
  • 3 Answers
SOURCE: keeps printing test sheet
I just had the same problem after putting in a new black cart. Try this:
  • Open HP Director
  • On the main window select Settings>Print Settings>Printer Toolbox
  • Open the Configuration Tab
  • At bottom right click "Factory Settings" button then "Apply"
A configuration warning popped up explaining that 'd be changing settings used by the driver. I clicked ok. AOK. (I did do an alignment just before this, but it's probably not required to fix the prob.
Posted on Jan 18, 2008
  • 1113 Answers
SOURCE: keep printing test sheets
A lot of HP printers print a page to enable the print head alignment and calabration. This normally orcurs when a cartridge has been changed. If the alignment page fails then it will reprint alignment page until it can align.
So, you need to get that page it prints and place it on the glass and press scan, then it will complete alignment and be ready to rock.
See Here
Posted on Jan 24, 2008
  • 787 Answers
SOURCE: error 41 brother all in one
Machine error 41 is "defective print head".Try to turn off the printer and wait 10 min.Then turn on, if the error continue showing your printer need service.
Posted on Oct 13, 2009
  • 193 Answers
SOURCE: (HP Laserjet 1018) This printer
please visit the following link.
Posted on Jan 10, 2011
Printing error message The printhead appears to be missing, not detected, incorrectly installed or incompatible.
Here is how I would approach this.
1. Open the cover and look at the print head. Are the cartridges installed properly and locked into place? You may wish to re-install them to make sure.
2.Inspect the print head to see if any cables appear to be pulled away or damaged.
3. Unplug the printer, and let it sit for about 30 seconds, and then apply power and turn it on. Let it run through it's initialization and then see if it provides any error codes. You may also wish to try printing a test page to generate an error code.
Good Luck,
Feb 10, 2015 | HP CB863AB1H Officejet 6100 H611A Inkjet...
Error code 5010 indicates carriage lift mechanism error. That means that the carriage did not move up or down properly. You need to replace PR lift shaft assy, Sheet feed unit, Logic board assy, Carriage lift sensor unit. Before replacement of the logic board assy, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or more, also replace the ink absorber kit when replacing the logic board assy.
Feb 21, 2011 | Office Equipment & Supplies
How to test the MD 1300 , also look on how to get error codes...
One test you can run is the self print test. Discount the printer from your computer. Load a single sheet of paper and the CMYK cartridges. Turn on the printer. Press and hold the "reset" button until the lights begin to flash. Release the "reset" button and the printer should do a self print test.
Dec 26, 2010 | Alps MD 1300 Thermal Printer
Epson Aculaser C1100 error code C0084. How is this code cleared.
The issue cause due to temporary "data error" that is easy to resolve. :-
  • A corrupted or interrupted print job, or:
  • A data or interface cable that is not connected correctly.
So, follow these steps:-
  1. Disconnect the printer from the data source
  2. Does the printer pass its ROM, RAM and Self Test checks?
  3. Test the printer standalone by printing a Status Sheet
  4. Cancel all pending print jobs on the network or computer
  5. Reseat and reconnect the data cable at both ends
  6. Test the printer
For more description view the following link:-
Feb 15, 2010 | Epson Aculaser C1100 Printer
Error 41 brother all in one :Performed Print Quality Check Sheet $ times. The test sheets became closer and closer to being 100% correct, then error 41 pops up
Oct 13, 2009 | Brother MFC 420CN All-In-One InkJet...
Error code A7 on brother mfc-420cn
Hi there
(A7 One-line feeding timeout error. )
Brother Error Codes RAM clear (most models)
Quickly press function * 2 8 6 4
Display should read maintenance
Press 0 1 for a full ram clear, or 9 1 to retain user data
Display should read reinit for a few moments then redisplay maintenance
Press 9 9 to exit the maintenance mode
Other maintenance mode switches:
01 ram clear (see 91 below)
02 scanner initialize (feed a white sheet, then a black sheet)
05 white level
09 print test
10 modify soft switches
11 print configuration list
16 panel test
19 CML test
20 signal test
21 tonal test
23 filter RX
54 scan edge
55 scanner area
66 test print memo
75 display drum life (if enabled on laser models)
76 reset drum life counter (laser models)
91 parameter initialize (user programming remains intact)
95 protection
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 05, 2009 | Brother MFC 420CN All-In-One InkJet...
Whats error code 3501
According to Kodak, that error just means the cover was open. I noticed when I print a diagnostic sheet that error shows up whenever I change the ink.
Sep 02, 2008 | Kodak ESP 5 Printer
Laser jet 5 will not print from my laptop. was fine until yesterday. now get error message. did all tests. printer printed out test sheet. computer printed out test sheet. just cannot print a document.
Looks like this is second printer installed on ur lappy... if that is so open Printers and Faxes and make ur laser jet 5 as default printer. Can give more accurate solution if u'll mention what error msg u got...
Plz Rate Me... Thanks.
May 13, 2008 | Office Equipment & Supplies
network cable,Thanks
Feb 23, 2008 | HP LaserJet 2430dtn Printer
23 people viewed this question
Top PRINTER Office Equipment & Supplies Experts
Roger Knight
Roger Knight
Level 1 Expert
R Daniel Wolfe
 Andrew Henderson
Andrew Henderson
Are you a PRINTER Office Equipment and Supply Expert? Answer questions, earn points and help others
