Question about Home Security
How do i insert the pen into the holder in the circut air.we have it in but it is loose and shaking all over the place
Cant open my programmable key pad safe. the code wont work
Locksmiths agree try replacing the batteries just slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Aug 12, 2010 | Sentry Fireproof Safe
I have a sentry safe model so500 & the batteries are dead, so I can't open it. I know the combination, I just can't open it! HELP!!! thank you, Lesley
Locksmiths agree on How to install sentury safe batteries
Aug 07, 2010 | Sentry Fireproof Safe
How do you replace batteries of a Sentry S0607?
How to install electronic fireproof sentry safe batteries
New advanced electronic lock safe battery replacement instructions
May 05, 2010 | Sentry Fireproof Safe
I have a Sentry OA5835. I am unable to open with factory combo and key. help
Sounds like the batteries are dead.
How to install sentry safe batteries
Mar 11, 2010 | Sentry Fireproof Safe
The Sentry V260 safe will not open. Replace batteries?
Locksmiths agree on how to install sentry safe batteries
reconnect the connector and put back the battery holder. Slide the cover back in place. How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
Change battery of sentry safe
To install sentry fireproof safe battery
reconnect the connector and put back the sentry safe battery holder. Slide the cover back in place.
Dec 01, 2009 | Sentry Fireproof Safe
My Sentry S3807 just will not open. I have the combination right and the key, but it won't open. The batteries could be shot, I suppose, but how do I get in?
Aug 26, 2009 | Sentry Fireproof Safe
Sentry S3807 safe-cannot open
locksmiths agree on how to install sentury safe batteries
to install batteries, turn the electronic lock case to the right and remove.Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Jan 26, 2009 | Sentry Fireproof Safe
Sentry safe
Sentry Home Safes battery location
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, next replace the electronic lock case and turn to the left to reassemble.
Oct 26, 2008 | Sentry Fireproof Safe
Home Security Logo
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
