Question about Hoover Vacuums
My hoover max extract 77carpet cleaner is NOT spraying water!?
  • 184 Answers
SOURCE: bissell carpet cleaner won't spray water or cleaner
If I may! In most cases the heater is clogged. It might be clogged with soap that has harden over time. You need to take the handle apart. You will see a metal box(thats the heater) besides the wires there are two tubes connected to the heater. remove the tubes but label or watch which tube goes where. now turn the heater upside down. there are 6 screws on the side and 1 in the middle. remove them carefully. the 6 on the side have a small gaskets under don't want to lose them. the 1 in the middle has no gasket, now the bottom plate of the heater can be taken off (there is a gasket with that plate careful . you will now see the long channels inside the heater and need to clean it. the holes where the tubes where connected have to be clean also but carefully. the metal is it bends. now put it all back. hope this helps. if you want to keep this from happening.the best way is to run clear water after you are done.this will remove any soap in the machine which will harden after the machine drys out. hope I helped .
and to mr. reddevil6 I am learning lots from you. Thanks
Posted on Feb 13, 2008
  • 10 Answers
SOURCE: bissell proheat 7 will not spray water or cleaner
Thanks to many others who have posted on similar problems -- water and/or solution sprays through the handheld tools, but not through the main machine.
As others have suggested, I removed the water reservoir, which exposes the 2 main water sprays mounted above the rollers. Using, pliers, I carefully slid the clips back. Gently but firmly removed the two red nozzles.
Elsewhere I have read suggestions to just do one nozzle at a time. However, I found out that if you remove both red nozzles, you can then blow through one side and it will come out the other. In my case, that dislodged a nice collection of crystal-like chunks (guessing it may be crystallized residue from the cleaning solution).
There was also a bit of blockage in one of the red nozzles, which I cleaned out. Make sure you can blow through both of them with little resistance.
Reassemble: Push red nozzles back into hoses. Using pliers, reposition sprung clip back over the red nozzle. Snap nozzles back into place. Refill tanks and power it up.
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!! g
Posted on Sep 26, 2009
SOURCE: fairly new Platinum series Hoover Max extract wont turn on
I have the same problem. Fairly new machine, only been used a handful of times and now it wont turn on.
Posted on Aug 09, 2010
  • 240 Answers
SOURCE: i cant get the brushes
Remove the brush assembly and insert a flat screwdriver into the square hole and be sure it turns. If it is seized up, the turbine assembly will require replacement. If it turns, be sure the brush control is set to the brush position and the filter is clean. The filter may be on top behind a clear plastic cap, or underneath in red plastic holder depending on the model. The brush will also not turn unless the lower tank is in place, and the handle released and tilted back.
Posted on Jan 28, 2011
SOURCE: Hoover Steamvac hose won't spray water
SOLUTION#1 If the attachment wont spray water, the white plastic nozzle tip may be clogged. Take the brush attachment off, remove the two screws from the gray retaining cover (BE CAREFUL THE WHITE TIP UNDER THE BLACK PLASTIC TRIGGER MECHANISM IS SPRING LOADED and WILL GO FLYING). The trigger mechanism can be taken apart by lifting the black part off (may have to slide it back slightly), remove the spring from the white plastic valve insert, then take a flat screw driver and carefully pry the two white pieces apart and blow out both ends. You may have to find a hair size piece of wire to push threw it to clear it. The whole process is really simple once you take it apart and see how it works. Putting it together is in reverse order. The white piece will only go in to the black part one way and with the spring on you need to push it through the hole and the trigger part hooks on, slide it back on to the hose, then while holding it all, and put the gray retaining cover back on. Sounds more difficult than it really is. If your not mechanically inclined take some pictures as your taking it apart to refer to.
Solution#2 If the nozzle and trigger are clear, with the trigger assembly off the hose, plug the hose into the shampooer and turn it on (if the hose inside the suction hose is clear you should start seeing water flowing out the hose. If not run a piece of wire through that hose to unclog it. If its still not flowing then the Pump on the unit needs to be replaced.
Solution #3Cost Around $20 with shipping online. Google your make and model, and upholstery attachemnt pump. Mine was called AP4561692 (43582018) PUMP ASSM, from (there real good about the live chat and helping you find the part).There are Youtube videos on taking apart the shampooer, which is pretty easy. The one place that might give you problems after you get down to taking the pump off, there is only one screw holding but there is on the bottom side of the pump a black bump that clips in to the base of the shampooer and you need to stick a screw driver from the bottom up and pry the base one way and pull the pump the other to unhook it.
Posted on Feb 16, 2012
Hoover f7458-900 leaking when placing tank on
Hello! Test the clean water tank to see if it is leaking. Fill the clean water tank with water on both sides. Hold the tank up and observe if water leaks from the valves underneath the tank. If either of the valves are leaking the clean water tank will need to be replaced. To order a replacement tank follow this link > Search Results. If the tank is not leaking, but the cleaner leaks when the tank is placed on it, this may indicate an internal issue with your pump. We would recommend taking the cleaner to a Hoover authorized service center. Follow the link to locate the nearest service center to you. > Service Center Locator Hope this helps!
Jul 26, 2014 | Hoover F7458900 Max Extract All Terrain...
Hoover max extract 77 manual
Hi! Follow the link below to view the manual for the FH50240. Hope this helps!
Jul 19, 2014 | Hoover Max Extract 77 Carpet Cleaner -...
Hoover max extract brushes wont spin
Check that the brushes are not jammed up with hair and fluff.
Remove the brush from the housing and clean throughly including the bushes/inserts and belt
Hope that helps
Feb 09, 2014 | Hoover Platinum Carpet Cleaner With...
My max extract 77 hoover wont spray
Make sure all water lines are not clogged with anything 1st. Then check to see if the switch/lever or button that actuates the spray is functioning/working. If it's a mechanical switch/lever etc, see if you can take it off and clean it thoroughly and check to make sure there are no broken parts. If it's an electrical switch/button or lever, you need to check and make sure it's clean, and all the contacts to wires are NOT broken or damaged. You may have to replace parts if they don't function.
Oct 15, 2013 | Hoover F6055-900 SteamVac Maxextract LS...
Will not supply water from tank to brushes
Pulling trigger pushes a rod which opens valve to allow water to flow. Follow from trigger down to try to locate problem
Sep 29, 2013 | Hoover Max Extract Steam Cleaner
Wont pickup water
check dirty water tank make sure lid is on correctly and that the plunger is not stuck.
Jan 20, 2013 | Hoover MaxExtract Deep Cleaner
My hover extract deep cleaner won't spray water or cleaning solution
If you have the receipt from when you bought it, take it to the closest Hoover warranty center and they will fix it under the warranty at no cost to you.
Jun 11, 2017 | Hoover F7431-900 SteamVac Vacuum
Hoover SteamVac isn't extracting solution from carpet. Motor runs and the brushes weren't turning at first but do now
That vacuum is fine on liquid extraction but often gets clogged by debris when it hits a solid. It would be better to do the clean with the steamvac then follow it with a wet/dry shop vac to be sure you got all the water. I say this because the vac built into that hoover is way too easy to clog.
Mar 13, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Vacuums Logo
26 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
