Fire TV gaming edition
How do I set it up on a TV
My amazon is not opening on the tv how can I fix it?
Basic Troubleshooting for Amazon Fire TV Try these common solutions to resolve issues like a blank screen, app errors, and problems with your display or audio.
Can't Connect to Wi-Fi for common solutions that may help.
Amazon Fire TV is Frozen, Blank, or Won't Power On for solutions.
Change Your 1-Click Settings. Manage Your Apps & Games.Contacting Your TV Manufacturer .
About 4K Ultra HD on Amazon Fire TV (2nd or 3rd Generation)Check the Video Resolution section under Display to make sure your connected TV meets HDCP 2.2 system requirements for watching video in 4K Ultra HD. For more information, go to Watching Video in 4K Ultra HD on Fire TV.
Calibrate Your Display
If part of your display is missing or cut off at the edges of your screen, your TV may be automatically scaling your picture.
You can use the Calibrate Display tool (Settings > Display & Sounds > Display > Calibrate Display) to adjust for this.
When you open the tool, you'll see four grey arrows pointing to the edges of your screen, which you can use as a guide when making your adjustments. Press the Up and Down keys on your Fire TV remote until the grey arrows are completely visible and touching the edges of your screen.
Contacting Your TV Manufacturer .Follow the on-screen instructions to make adjustments with your TV remote. You should still see the grey arrows from the Calibrate Display tool--make sure the tips of the arrows are completely visible and touching the edges of your screen.
Amazon Video Settings and Devices on the Amazon website.
Go to the Parental Controls section and enter a new 5-digit PIN under Amazon Video PIN. Then select Reset Your PIN.
MicroSD Storage for Amazon Fire TV (2nd Generation) .
USB Storage for Amazon Fire TV (1st Generation).If your storage device is compatible, try safely removing and then re-attaching it to your Amazon Fire TV:
  1. Select Settings > Device from the Fire TV menu, and then select your storage device.
  2. Select Eject.
  3. Wait for the on-screen confirmation before safely removing the device.
  4. Re-attach your storage device.
Oct 23, 2017 | Televison & Video
Purchased on 12/9/2009.had no problem until now.
If you can enter the system settings, try to reduce the resolution.
If you cannot access the game settings due to the enlargement, close the game and try restarting the computer and checking for any game or video card driver updates.
Also try either clearing the game.ini file or editing in a program like Notepad++. If you open the .ini file, you can edit the resolution setting in there. There are very good guides for this if you Google: How to find and edit game .ini files
Dec 26, 2015 | Computers & Internet
Accidentally turned off my blue tooth on my fire stick now my remote will not work
1,Before you pair an Amazon Fire TV Remote or Amazon Fire TV Voice Remote, verify that the remote is compatible with Amazon Fire TV, is within range, and has the required batteries installed. 1. From the Home screen, select Settings, and then select Controllers. 2. Select Amazon Fire TV Remotes, and then select Add New Remote. 3. Press and hold the Home button on your remote for five seconds. Fire TV Stick searches for the wireless signal of the remote. After the remote or game controller is discovered, select it from the list of discovered devices using your already paired, existing remote or game controller.
Apr 02, 2015 | Amazon Fire TV Stick
Accidently turned off blue tooth
Turn down brightness on a xbox
Edit one of your TV picture settings and save a game mode with brightness turned down, and use that setting for Xbox.
Oct 01, 2013 | Microsoft Xbox Video Game Consoles & Games
Hooked up the wii to a new emerson tv. no cable is attached to the tv. the wii is showing up in black and white only, how can I get color
no your wii is in pal (UK EDITION) while your tv is NTSC( USA EDITION) so not compactible. So try seeing if tv has setting of switchin to pal if not sorry this means you can only by and play uk games if you got the wii in the usa its the opposite for you.
Jan 12, 2011 | Nintendo Wii Console
Need help setting up gprs on att network
This is for internet and MMS (Picture Texts) This must be followed exactly.
***First Step***
1.Main menu --> Select Services
3.Select Data Account --> Select GPRS
5.Select the first entry
6.Edit the account name to whatever you would like
7.Edit APN to wap.cingular (lowercase)
8.Edit Username to WAP@CINGULARGPRS.COM (UPPERCASE)
9.Edit Password to CINGULAR1 (UPPERCASE)
10.Edit Auth Type. to Secure
11. Save
Select Back --> Select Back
***Second Step***
Select WAP
1.Select Settings --> Edit Profile
3.Select the first entry --> Edit Profile
5.edit the name to whatever you would like
6.Edit Homepage to http://device.home
7.Edit Data Account to the Name you established in the First Step
8.Edit Connection type to HTTP
9.The IP address is 066.209.011.032 and the port number is 8080
10.Edit Username to WAP@CINGULARGPRS.COM
11.Edit Password to CINGULAR1
Select back or done
Select Activate Account
You should now see a Black [G] in the upper left of your screen.
MMS
Select Messages --> MMS --> Message Settings
Select Server Profile
Select Edit Profile
Edit Rename Profile to whatever name you would like
Edit Home Page to http://mmsc.cingular.com
Edit Data Account to the same data account you created for WAP
Edit Connection Type to HTTP the IP address is 066.209.011.032 and the port is 8080
Edit the Username to WAP@CINGULARGPRS.COM (UPPERCASE)
Edit the Password to CINGULAR1 (UPPERCASE)
Select Done or Save
Make sure to activate the profile and you are good.
For full help topics I have a cd available for 10 us dollars. Has 100's of mp3 ring tones wallpapers, and java games and opera java browser. Guaranteed help on every question ever asked on these phones. And all settings for all cellular services. I have answered 100 questions with this CD. If interested contact prestorose@aol.com Pay Pal only, will send out First CLASS Mail in padded envelope. If interested I will send Pay-Pal invoice that can be filled out and returned with instructions. Guaranteed safe transaction.
Apr 27, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Oregon Trail 4th Edition won't install on xp
You better dig that old Win98 machine out of the closet and fire it up. Oregon Trail doesn't want to install properly even when you run the install and set up in Compatibility mode (95 or 98). There is some issue with the version of DirectX it wants to use as well.
Feb 21, 2009 | The Learning Company Oregon Trail 4th...
No menu
Try booting it up without a game in it. It will autorun a game, and skip that screen.
Check your sound connections to your TV, also you will have to select the proper Sound Out in the sound options. Make sure its set for the type of cables you're using.
Feb 15, 2009 | Sony Playstation 3 (PS3) Console
Firing the flak gun (moh spearhead)
If u r talkin bout multiplayer mode and da objective is do deffend or destry da flak cannon, it cannot be used as a wepaon. But it some game types, if there is no where to place a bomb on it and u can press " e " to hop on it, it should fire wen u click. I hope dis helped =)
Sep 29, 2008 | Electronic Arts Medal of Honor Allied...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
