Question about Konica Minolta bizhub Office Equipment & Supplies
K M c654e black imaging unit. Was taken out and put back in. Either says wrong unit replace with right one. Or when it accepts it as right one it prints only about a third of paper. Blank on rest.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 79 Answers
While putting Imaging Unit inside the machine, make sure the contact/chip area is actuating/hitting properly to the contact assy on the body of machine.
Here Black IU has two part- Black Drum and Black Developing Unit. I think only contact of pins causing problem.
At Frond side of drum unit below is Chip.
and same corresponding to developing unit u can find 3 pins assy.
while closing contact should be proper.
Posted on Dec 13, 2016
Imaging unit
konica minolta bizhub c654e in display error c9401
no Utility/Counter key. howcreset I resolve lamp already change
Oct 29, 2013 | Konica Minolta Bizhub C550
What solution for samsung clx3175 asking intall image unit
Dear ,
Kindly refer the following link,
http://www.samsung.com/us/computer/printers-accessories/CLT-R409/SEE
This imaging unit needs to be replaced after it complete its life (6000 color pages/ 24000 mono images)
To replace first you need to takeout the toners and waste toner container ( a transparent/black container on the left hand side)
after that you may take out the imaging unit.
after that put the new imaging unit.
put the waste toner container and put back the toners.
If problem persists please provide your feedback.
Best Regards
Apr 19, 2012 | Samsung CLX-3175FW Multifunction Laser...
The printer did not reset when we replaced the black toner AND the imaging unit
Hi this issue may be casued because when you replace the toner and imaging unit they must be new and not taken from another machine i am sure if you put a new out of the box toner and drum unit out of box it will work
Jan 28, 2011 | Konica Minolta Bizhub c203 Copier
Machine status P-9 what is this message?
Black Imaging Unit failure
• All density readings taken from the density pattern produced
on the Transfer Belt are 0.5 g/m2 (IDC Sensor
photoreceiver output) or less during max. density
adjustment (Vg/Vdc adjustment).
on the Transfer Belt are 4.5 g/m2 (IDC Sensor
Photoreceiver output) or more during max. density
adjustment (Vg/Vdc adjustment.)
Remove and reset the Black Image Unit. If this doesn't help the Image Unit may need to be replaced.
May 25, 2010 | Konica Minolta bizhub C250 All-In-One...
When I take a picture the lcd shows all black? Is there a chance that I'm using the wrong CF card or is it a bigger problem?
Fuji had a problem with the CCD unit and put out a bulletin years ago to send them back and they would replace, but they no longer can do that, as the part is not made anymore. I had the same problem.
Mar 09, 2010 | Fuji FinePix S2 Pro Digital Camera
Black cartridge not working properly
If the Black cartridge gear is not operating you need to get a replacement from the Cartridge supplier.
Else if the black print is not proper then you have to replace the Black developer from imaging unit. followed by firmware update.
Jul 30, 2009 | Samsung CLP 300 Laser Printer
I can view the images taken, but when I try to take an image the LCD screen does not show the image, screen is black
hey my camera just did the same thing, have you tried replacing the batteries - i thought it couldnt be the batteries because the playback screen still showeed up just not the one to take photos but i just put in newly recharged ones and it can take pics again so maybe try that :)
Apr 22, 2009 | Fuji Finepix S6500FD Digital Camera
Technical Black Imaging Unit Replaced,Error message still shows
These units are automatically reset with a fuse. When you put the imaging unit in it will completes a connection which resets the count then simultaniously blows the fuse. Sometimes the fuse blows before the reset, which is what it sounds like happened here. The machine should print normally but the error will persist until the unit is replaced with a new one. Is the the imaging unit an OEM unit or remanufactured? Whoever you got the unit from should replace it as defective free of charge. If it is OEM you might have to go through Xerox to get it replaced. I don't know if the Big Box stores will.
Dec 04, 2008 | Xerox Phaser 7300DN Laser Printer
Kyocera cs1820
c 7980 is a warning that the waste toner container on the imaging unit is full, This usually means the life of the imaging unit is finished or close to being finished. If u dont want to replace it yet, a quick way is just to empty it. on the left and right of the unit at the back you will see 2 screws take those out then remove the small covers and just poor the toner out(DONT BLOW INTO THE UNIT). put tje covers back on, clear off any spilt toner and put the unit back into the machine
Aug 14, 2008 | Kyocera Copystar CS-1820 Black and White...
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
