Question about LG enV VX9900 Cellular Phone
My screen is broken
It is cracked and is black no picture shows just a black screen
The screen on my zeepad jellybean 7.0 cracked how do i know if i need a new lcd display. I already purchased the digitized touch screen replacement
tha't an easy task to handle
See the pictures below
if your whole screen shows an image and the cracks are in front of it then its just a cracked digitiser
if you dont see the whole image and tyou see horizontal and vertical line or an image like spilled liquid then your Lcd is also cracked too
92dabd2f-7f4a-4795-976d-d97d7e32fa0e.jpgthis is a broken Lcd (the screen is distorted by the lines or no picture at all)
83952950-d5b2-47e3-b228-81f41d0190af.jpgthis is just a broken digitiser (the screen below the broken glass works fine )
hope that was helpful
May 20, 2014 | Tablets & eReaders
32L1300U
In what way is the screen broken? cracked, distorted picture, no picture but has sound?
If it is cracked. Replacement of screen is expensive. Cheaper to buy a new TV.
If Distorted. Parts linked to the screen can be the culprit. Most common part to fail is the T-con board. Main board may not be sending signal to the T-con board.
If its no picture but has sound. Back lighting has failed which could be several things that can cause that.
without any other details besides "broken" it will be hard for someone to help with diagnosing your problem. We need symptoms like. has sound but no picture. Picture has horizontal or vertical lines. part or half of the screen is black, black borders don't count. Hope the info here has, in some way, helped bring you closer to what to do with your TV.
Mar 26, 2014 | Toshiba 32L1300U 32" LED TV 1280x720, 120...
There is a black spot on the digital screen. It does not show up in pictures but it is on the digital screen. Any fixes?
Unfortunately this is a permanent damage on the screen display - it needs to be replaced. The LCD glass has a cracked - the black spot is the crack. It should not effect your pictures when you take them.
Nov 12, 2010 | FUJIFILM FinePix Z70 Z71 Digital Camera
Panasonic LCD TV with cracked screen
Sorry,not repairable,because the LCD,PLasma,and DLP screen are limited produced.Replacing the tv pannel screen will cost the same as a new tv.Might even cost more after the labors.The tvs screen is about 90% of the tv,that why when is broken or damage,now it only use for it electronics boards parts,or sell for it electronics boards parts that it.
Mar 15, 2010 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
KDL46W4100 no picture small white crack is visible when turned on. Crack got longer and eventually went across entire screen. People have told me the lcd is broken and it's not worth fixing - ie the part...
Yes, thats correct.
If lcd tv screen got hit by some thing then lcd panel got cracked and does show distorted lines or cracks instead of picture and lcd panel have to be replaced that would cost you 70% to 80% of new tv price.
New TV is better option.
Dec 16, 2009 | Televison & Video
My son threw a ball and hit the screen cracks all over can this be fixed with a new screen or is it junk now really bright light shows through all the crack marks
The front glass is just a protector for the LCD screen. If your TV turns on and the picture looks ok (may be a little color variation around the crack if front glass is pushing on it, variation OK black Bad) If the picture looks within the range described then replace the glass. It is just a piece of standard glass and a pretty easy diy job. If the LCD screen is broken the repair will be more than the replacement cost. Sad fact US TV repairmen make a living wage while the workers that assembled you TV wouldn't be able to buy lunch here with what they made putting it together.
Jun 02, 2009 | Toshiba 42HL67 42 in. LCD Television
Black screen
Assumed that LCD screen is black and what about Eye piece viewfinder? Does it show picture to you?
If LCD Screen is black, it means it has no back-light. check any button to turn back light on & off at LCD portion.
There can be an other reason of black LCD. a flexible cable which connects LCD and Camera circuits and it can be broken/ cracked/ out of order.
May 30, 2008 | Sony Handycam DCR-HC14E Mini DV Digital...
Cracked screen, and other stuff.
Did you know of anything you did to physically crack the screen?
As for the clicking-- that is the hard drive. It is either dead or stuck. you may want to try to "unstick" it the Risky way. To do this, Place a stack of paper on a table, and smack the ipod against it. Obviously you should do it to the back to avoid breaking the click wheel or screen (even though your screen may be broken already.)
As for the "very low battery" thing, just plug it into a computer or Ac adapter and let it sit. It will eventually charge.
Nov 15, 2007 | Apple Mini IPod
It's very likely that when you dropped the iPod and damaged the screen, you also damaged a small component inside of the hard drive. The clicking noises are probably those of the hard drive trying to work and the picture of a "dead" iPod (I assume it's a picture of an iPod with a sad face) is also one that pops up when one is having hard drive problems. If you're comfortable enough opening your iPod, you could probably replace the LCD and hard drive but it might be a better idea for you to just buy a new one and sell the broken one as-is on eBay as you're replacing 2/3 main components of the iPod.
Nov 13, 2007 | Apple iPod MA446LL/A MP3 Player
LG enV VX9900 Cellular Phone Logo
76 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
