Keyboard bug
Typical keyboard problems such as this can be attributed to dust and other foreign material that get lodged in between the contact switch of each key. Since the repair cost sometimes exceed the cost of a new keyboard, it may be to your advantage to simply purchase a replacement (that is of course if the errors outweighs the use).
A trick you can try is lengthen the time between repetitive keystrokes (but this will apply to all the keys not only ' and ~). This is done in your BIOS (assuming this feature is available with your motherboard). On powerup, press del or the key designed to enter the BIOS setup. See if you have the option to control your "Typematic Rate Setting" and select enable, in the "Typematic Delay:, select 500 or higher. Save and reboot.
Hope this works for you. Good luck and kind regards.
